Door sill removal
Discussion in '1st Gen Tundras (2000-2006)' started by Confused_02_base, Jun 30, 2023.
  1. Jun 30, 2023 at 9:24 AM
    Confused_02_base
    Confused_02_base [OP] New Member
    2003 Base V6 - various nicks and dings
    STOCK
    Alright...got the easy part done...5 screws iut and neatly put away. Now, how do I get the sill panel off without destroying it? Are there clips? Do I just pull up from the interior side? Wedge plastic trim removal to pop it off slowly? I dislike breaking things lol.
  2. Jun 30, 2023 at 9:28 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Just pull straight up normally from one end. Doesn’t matter if it’s the inside or outside corner, the plastic tabs are symmetrical.
    Don’t yank it though, just pull it up slowly if you’re concerned.
    Confused_02_base[OP] likes this.
  3. Jun 30, 2023 at 11:30 AM
    Confused_02_base
    STOCK
    Wondering if it is worth the time suck to clean these up or buy new ones. 20 years of restaurant grime and grease.
  4. Jun 30, 2023 at 12:32 PM
    Jack McCarthy
    Bill
    North of Boston
    Pics? How hard is it to clean?
  5. Jun 30, 2023 at 12:43 PM
    Confused_02_base
    STOCK
    Not difficult to "clean" per se. It just won't be up to my standards and my OCD arse would be out ther all day trying to get
    the grime out of the nooks and crannies. Still may not be happy with the result :annoyed:
  6. Jun 30, 2023 at 12:45 PM
    Jack McCarthy
    Bill
    North of Boston
    When you pull them, you can clean them thoroughly and the carpet where they cover. I've done it multiple times although you may want new screws so the heads look perfect. lol
    NewImprovedRon likes this.
  7. Jun 30, 2023 at 12:57 PM
    Confused_02_base
    STOCK
    Before and after I hit it with a damp MF. Now I want to break out the brush and get everything out of the patterned ridges lol
  8. Jun 30, 2023 at 1:06 PM
    Jack McCarthy
    Bill
    North of Boston
    Yikes! Yeah, looks like you've got some staining there. Mine will just clean off with a scrub brush. Maybe pull them and soak overnight?
    But you should be able to just get your fingers under the edge on the end of the sill and just pull straight up. I may have been wrong about there not being any metal clips. It may just be center tabs with clips (been quite a while since I've pulled them)
  9. Jun 30, 2023 at 3:08 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I don't remember any clips when I worked on mine, maybe they're just stuck??
    Jack McCarthy likes this.
  10. Jun 30, 2023 at 3:45 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As mentioned, there are no clips. Once removed, you'll see that every screw has what's circled below. Anytime I have removed(many times), I make sure I push those 2 points together best I can before re-install, considering they are ~20 yrs old. Once removed you'll also see the roughly 1/2" squares cut out of body that the 2 points are going in. When you replace screw, it's simply spreading the plastic points outward, so don't put a german tight on em, somewhat finger type is good.
    NewImprovedRon and Jack McCarthy like this.
  11. Jun 30, 2023 at 3:46 PM
    Jack McCarthy
    Bill
    North of Boston
    I can’t remember if there were or not, but they’re definitely easy to get off without breaking them.
  12. Jul 1, 2023 at 1:41 PM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    tvpierce and Jack McCarthy like this.
  13. Jul 1, 2023 at 1:52 PM
    Jack McCarthy
    Bill
    North of Boston
  14. Jul 1, 2023 at 4:20 PM
    abcinv
    Tommy
    South of ATL
    I too did this repair - I grabbed a bag from Napa. Solid repair!
