Door Mechanism Help (AGAIN)
Discussion in 'General Tundra Discussion' started by toekneem, May 22, 2024.
  1. May 22, 2024 at 7:51 AM
    toekneem
    toekneem [OP] New Member
    Tony
    2005 Tundra Access Cab SR5
    None
    '05 Access cab, SR5 V8
    Drivers door mechanism started to stick and is now STUCK. Actuator works, but I now have a door the will not open. I have read through the forums and tried several methods to get the door open. If I could get the door open I could replace the defective parts, but since it wont open, I can't get the door panel off, so on and so forth.
    Any help to get this door open would be greatly appreciated.
  2. May 22, 2024 at 7:57 AM
    2mchfun
    Last time I saw this problem, I suggested check with a body shop. The owner did and it was resolved. Was a little costly though, I wanna say about $700:eek:.
  3. May 22, 2024 at 10:50 AM
    toekneem
    Tony
    None
    I read that thread and was hoping to avoid that. Maybe someone has a work around.
    2mchfun[QUOTED] likes this.
  4. May 22, 2024 at 10:52 AM
    2mchfun
    @shifty` would know. Wait a little bit.
  5. May 22, 2024 at 11:13 AM
    shifty` In South Dakota Trouble ain't hard to find
    I've got no workaround. I've only seen it happen when someone makes the unfortunate mistake of using aftermarket latches. I posted the only workarounds/methods I know in that thread referenced, I believe. i.e. pushing in on the door from outside to relieve pressure on the latch and using the outside and even inside handle, Popping off the interior latch/handle cover and pulling the bars, maybe wedging the outer seal with the window up and manually trying to jimmy the latch.
    2mchfun likes this.
