Door locks
Discussion in '1st Gen Tundras (2000-2006)' started by bkri, Aug 2, 2019.
  1. Aug 2, 2019 at 10:53 AM
    bkri
    bkri [OP] New Member
    2002 Tundra SR5
    My door lock switch isn't working. Both drivers and passenger side door lock switch doing nothing. Any ideas?? Thanks.
  2. Aug 2, 2019 at 11:21 AM
    Professional Hand Model
    Hand Protectors
    Maybe your drivers side master door module is bad?
    Does your mirror operator work?
    How about the pass side? Does it lock that side?
    Check fuses?
    OR18TRD likes this.
  3. Aug 2, 2019 at 11:40 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Can you hear it trying to do anything?
  4. Aug 2, 2019 at 11:58 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Probably the actuators. This was a known problem in the 4runners. I had to replace all four of mine within a 7 week period in my 2014 4Runner - got so bad I kept spares on hand. It’s easy to replace; takes about 20 minutes. Can get the mechanism on Amazon for under $50. Dealership will charge you in excess of 300-400 dollars.
    NewImprovedRon likes this.
  5. Aug 2, 2019 at 3:20 PM
    bkri
    2002 Tundra SR5
    Everything else works. Just the door lock buttons do nothing on both passenger and drivers side, no noise nothing. Also when unlocking with key it doesn't unlock both sides as it once did.
  6. Aug 2, 2019 at 3:27 PM
    Hand Protectors
    We have a Toyota mechanic that is having a similar problem on his passenger door.
    @Dark Knight
    OR18TRD likes this.
