Door Lock
Discussion in '2.5 Gen Tundras (2014-2021)' started by pctundratx08, May 25, 2017.
  1. May 25, 2017 at 3:17 PM
    pctundratx08
    pctundratx08 [OP] New Member
    2014 Tundra TTS
    Drivers door will not lock, unlock on 2014 Tundra, remote and auto locks work fine on all other doors. Also, driving lights do not flash when locking doors. Ideas??? I'm thinking fuse because of the fact that the lights don't flash anymore either. Please help...
  2. May 25, 2017 at 4:36 PM
    You can change the driving lights to flash/horn in vehicle setup
    You can check both fuse panels- engine bay and interior cab fuse panel
  3. May 25, 2017 at 5:40 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    actuator probably bad in that door, lights wont flash because the door isn't locked. if you manually lock that one as you get out close door and hit lock the lights will flash. that's just how Toyotas work
    ride2wheels and T-Rex266 like this.
  4. May 25, 2017 at 5:42 PM
    ride2wheels
    ride2wheels New Member
    Nathan
    2016 Tundra SR5 4x4
    Weathertech mats , S&B intake, soon Tacotunes SQ1
    Probably just an actuator, wire's for lights might be linked to that lock? On my remote a single click only opens driver side. Maybe with that one down it's not triggering?
  5. May 25, 2017 at 5:44 PM
    ride2wheels
    Nathan
    2016 Tundra SR5 4x4
