Door Handle Mod Help
Discussion in '2.5 Gen Tundras (2014-2021)' started by sbbrown333, Dec 30, 2018.
  1. Dec 30, 2018 at 2:59 PM
    sbbrown333
    sbbrown333 [OP] MGM Wrecking Crew
    Blake
    2018 MGM Limited CM 4x4
    The videos made this look really easy but I’ve been unable to line up the screw the the lock piece on the driver’s door. Any advice?? Need to get this fixed ASAP.
    2016BlackPlatinum likes this.
  2. Dec 30, 2018 at 3:03 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    There was a post about this. There is something to do with a clip that falls out of place.
    waynescaggs likes this.
  3. Dec 30, 2018 at 3:06 PM
    Iceman09
    Iceman09 New Member
    2018 Platinum in Blazing Blue
    Undercover Ridgelander Tonneau cover
    I had the same problem bro. Don’t worry, super easy fix.... Get your finger behind where the screw should go. Pull towards you. This piece will pop out and will now align. I had that happen on 2/4 and found the fix on a different forum post.
    waynescaggs and OR18TRD like this.
  4. Dec 30, 2018 at 3:08 PM
    Iceman09
    Iceman09 New Member
    Search for a forum called help door handle replacement. They have pictures.
  5. Dec 30, 2018 at 3:10 PM
  6. Dec 30, 2018 at 3:53 PM
    sbbrown333
    Blake
    I’ve found and read that forum and still can’t get the damn thing to line up. Idk what I’m doing.
  7. Dec 30, 2018 at 4:00 PM
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    betting that the plastic part has slipped back towards the interior of the truck. stick your finger inside the hole where the threaded screw is and push it back towards the outside of the truck. it should have four small post that clip on the exterior of the door. make sure your gasket is lined up as well.
    or go take another handle off and look at it and you'll see exactly what you need to do.
  8. Dec 30, 2018 at 4:03 PM
    Apinion
    Apinion New Member
    2015 Black Tundra Platinum
    Of no help here, but might make you smile....
    .... At least Clemson won, right?!
    Moon Puppy likes this.
  9. Dec 30, 2018 at 4:06 PM
    sbbrown333
    Blake
    Yeah that was pretty nice. Also got my black emblem overlays, a pillar with drivers grab handle and paint to match mirror caps installed. Didn’t think this would be the hardest of all the mods this weekend.
    OR18TRD likes this.
  10. Dec 30, 2018 at 4:06 PM
    sbbrown333
    Blake
    Push the screw or the piece around it?
  11. Dec 30, 2018 at 4:10 PM
    DJFaninTN
    I THINK its all connected. Go take off another handle and it will make sense
  12. Dec 30, 2018 at 4:12 PM
    sbbrown333
    Blake
    TBH I’m pretty nervous to take another handle off at this point.
    OR18TRD likes this.
  13. Dec 30, 2018 at 4:13 PM
    Apinion
    Apinion New Member
    My hande swap out couldn't have been any easier. Maybe try backing out that bolt a good bit.
  14. Dec 30, 2018 at 4:14 PM
    DJFaninTN
    I understand but once you see it, you'll want to kick yourself. At least that's the way I felt.
  15. Dec 30, 2018 at 4:14 PM
    sbbrown333
    Blake
    The bolt is super loose at this point almost to where I could pull it out if there weren’t clips there.
  16. Dec 30, 2018 at 4:14 PM
    Blueknights75
    Ron
    Clayton, NC
    The screw and adapter should never come out. Wish I could help but when I changed mine out I just loosened the set screw and wiggled the handles off.
    And with the lock just make sure you don’t have it upside down when reinserting the lock.
  17. Dec 30, 2018 at 4:15 PM
    sbbrown333
    Blake
    Ok I may have to wait until the morning now that it’s so dark. Thanks for the advice.
  18. Dec 30, 2018 at 4:16 PM
    sbbrown333
    Blake
    I had watched the Sparks Parts video and used a drill like they did. Wondering if I loosened it too much using the drill?
  19. Dec 30, 2018 at 4:17 PM
    Blueknights75
    Ron
    Clayton, NC
    I would NEVER use a drill on this. When you loosen that screw you should be able to just wiggle the handles out. That screw should not be able to come out from it’s adapter.
  20. Dec 30, 2018 at 4:17 PM
    DJFaninTN
    go out and take a pic of just the hole where the handle goes.
  21. Dec 30, 2018 at 4:19 PM
    sbbrown333
    Blake
    The screw can’t come out from the adapter since it has the clips holding it in place. But still wish I would’ve just used a screwdriver.
    Blueknights75[QUOTED] likes this.
  22. Dec 30, 2018 at 4:20 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    I didn't have any problems changing mine. The only thing i can think of is your handle pushed forward far enough so that it lets that piece line up. I was like you. Nervous the whole time i was doing this.
  23. Dec 30, 2018 at 4:30 PM
    Just take off the door panel and reposition it
  24. Dec 30, 2018 at 4:30 PM
    sbbrown333
    Blake
    I can easily get the long handle piece in place and lined up. Should the lock piece snap in when it’s in place? Currently when I try it just kinda sits beside the other piece.
  25. Dec 30, 2018 at 4:57 PM
    sbbrown333
    Blake
    Yeah I’m just gonna do the others and see how the other doors are lined up to see if it helps me figure out the others. Did you use a drill with this project? I think that really messed me up on the driver door. Also the black barrier piece you mentioned already came off when I took the original handle off. I’ve been holding it place when trying to put the handle back in place.
    OR18TRD[QUOTED] likes this.
  26. Dec 30, 2018 at 5:05 PM
    sbbrown333
    Blake
    Exact same I’m thinking lol. I’ll be up until this is fixed tonight I guess.
  27. Dec 30, 2018 at 5:56 PM
    sbbrown333
    Blake
    Thanks for all of your help guys. Per your advice I took off the back door of drivers side and I could clearly see what the issue was with the piece not pushed all the way through that lines up the door handle with the torx screw. I went ahead and fixed the driver door then swapped out all the handles in the dark. Will check them in the morning to assure they’re all lined up correctly but other than that we’re good to go. I noticed that right now I can slide the bigger part just the tiniest bit from the small piece so I’m thinking it may need re-aligned tomorrow in the light. Thanks again. Love our community.
    NewImprovedRon likes this.
  28. Dec 30, 2018 at 7:23 PM
    RoujePN
    RoujePN New Member
    2019 Platinum CM 4x4 5.7L 1G3
    Good read. Glad things finally worked out for ya.:yes:
  29. Dec 31, 2018 at 7:22 AM
    Lesroadking
    Lesroadking New Member
    Doral, Florida
    2020 MGM Toyota Tundra Trd Pro
    Diamondback SE Cover, Interior LEDS, Wet Okole Seat Covers,
    Glad everything worked out for you. I had the same issue last week. I woke up the next day and did all four doors within 15 minutes.
    sbbrown333[OP] likes this.
  30. Aug 5, 2022 at 8:20 PM
    2016BlackPlatinum
    2016BlackPlatinum New Member
    Tom
    2016 Tundra Platinum on 3" level kit & 33" Tires.
    I ran into same issue. The driver side door will not line up with the door lock. I cannot screw it back in. I have reset the door handle and come close to alignment, but still I cannot screw in the door lock. Any advice or articles on this? The videos made it look so easy, but with my Tundra it has not been the case.
    -Tom
