Door Glass Adjustment
Discussion in '2.5 Gen Tundras (2014-2021)' started by TGTundra, Nov 14, 2017.
  1. Nov 14, 2017 at 10:24 AM
    TGTundra
    TGTundra [OP] New Member
    Does anyone know if the door glass or tension can be adjusted? My passenger front door glass drops slightly after raising it all the way and caused a lot of air leak noise. I can hold up on the button to raise the glass and most of the air leak will go away.
  2. Nov 15, 2017 at 4:23 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The first thing that I would do would be to pull the interior door panel to check to see if the regulator and all associated mechanical bits are secure and haven't loosened up. I've seen that happen.
    NewImprovedRon likes this.
