Don't be (very) afraid to build Bilstein 6112
Discussion in 'Suspension' started by justfortun, Dec 1, 2018.
  1. Dec 1, 2018 at 3:50 PM
    justfortun
    justfortun [OP] New Member
    James
    Boston
    2016 SR5
    Ever jam your hand down the disposal to get the spoon that's fallen in? And even though you can see the on/off switch on the wall, and KNOW that it's off, you're still afraid the rest of your life you'll be wiping your arse with the other hand?
    Thats sort of like my experience today building the 6112s.
    I'm going to walk you through what I bought to get er done. And then what I did.
    Spring compressors.
    OEMTOOLS 25550 MacPherson Strut Spring Compressor
    $28, Amazon. They got good reviews, and for those who hate suspense, they were rock solid.
    However they don't fit over the coils.
    So, I trimmed them. I figured they weren't doing the heavy lifting, they were more to keep the puppies in place. Nobody ever praised my brains.
    Once I was happy with the fit. I was onto cranking them down. I spent a while trying to figure out how to mitigate the possible explosion that every how-to video describes. I decided to tighten the springs vertically. I liked the down pressure idea. Here's what I did.
    Vised a 6' clamp down and covered it with pipe insulation - looking back, the insulation wasn't necessary, but at this point I was trying to pad everything.
    What I wanted to achieve with this setup was a direction for blowout. ie if this thing went bad and exploded, it would explode up. (and then most likely brain me as it ricochets off the ceiling)
    Did a little wetting the whistle. Oh ya. Nice and slippery. Omnomnom
    Next I needed a 19mm socket. Some female to male converters and an impact gun.
    Alternating from right to left, I began the tightening. All the while envisioning somebody flipping the switch to the disposal.
    Put the shock parts together (without the coil) so I would know what measurement I needed to achieve before I could stop.
    I was setting my shocks to the second setting - the 1.3" - and that was just around 14"
    Most people do the third setting of 1.9" so that would be 13.5" compression.
    I'd measure back and forth between the two compressors. I've watched videos where they explain that if you go too far on one side the threaded bar would start to bend, but that didnt happen with me. They also said that you should do this by hand, but if you did, you'd end up looking like popeye when you got done. So I used impact driver. Half way around turns on each side in the beginning, then, when it started to get closer to the 14" spot, I'd just do a burst, alternating sides.
    Once at 14" I moved it over to the bench and slid the shock inside it.
    Followed the diagram that came with the shocks as far as how to put these together. Used a vise grip to move the setting to the 1.3" second spot. doohicky this and washer that. easy.
    Bought these:
    Lined up the "Out" label on the mount with the writing on the coils and the bottom.
    Then I power wrenched it until the rubber gasket started to balloon, then I switched to the torque wrench - 20lbs per foot til it clicked.
    Grabbed the inner shaft with vice clamp while tightening the nut, or else the whole thing just spins. So torqued with the right hand and held the vice grips with the left hand.
    released the tension on the coil
    done and done
    I didn't install them yet, I'm awaiting the coachbuilder .5" shim for driver side. Thanks to all 30 people for ordering from Coachbuilder, they are en route. Pop that sucker in and get er aligned.
    Bob's your uncle.
    Still have both hands.
    Don't be afraid.
  2. Dec 1, 2018 at 3:58 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Outstanding writeup. Thank you!
    justfortun[OP] likes this.
  3. Dec 1, 2018 at 5:40 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Anti seize is the best. Nice write up
  4. Dec 2, 2018 at 3:45 AM
    justfortun
    James
    Boston
    2016 SR5
    coachbuilder .5" shim and 1" shackles arrive this Wednesday!
  5. Dec 2, 2018 at 4:54 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Great job, no way I would attempt that without a safety cage....
  6. Dec 2, 2018 at 11:01 AM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    Thanks for the great write up including pics!!!
  7. Dec 2, 2018 at 11:06 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I do have an Uncle Bob.
    Great job! Thanks for sharing.
    Law323 and justfortun[OP] like this.
  8. Dec 2, 2018 at 11:18 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Yeah, great write up! I used ones off of Amazon for $26, in my driveway.
  9. Dec 2, 2018 at 3:46 PM
    justfortun
    James
    Boston
    2016 SR5
    @MotoTundra I think everyone has an uncle Bob. I have one. And a brother Bob. Dont hear the name too much anymore.
    update to this thread. I did the drive side lean measurements and I was 3/16" lower on driver side, with over 30 gallons of gas, so I decided to put the 6112s in today and if my drive side sags later, I now know how to put it in later.
    And man am I mad.
    I've driven around the last 17 years in tundras with absolute shit suspension! These things are like taking off a pair of loafers and putting on Nikes. I installed the 5160s the other day, and the difference was minimal. These 6112s in the front make a huge difference!
    Went with the 1.3" second setting and when everything was put together, it was darker than a raccoon's asshole outside, so this picture will be updated tomorrow.
    From what I can see, she sits pretty level. Still going to put in the 1" Coachbuilder shackle but I'll have a better sense in the morning.
    If I go with bigger tires than these 275/70r18's I'll just take these guys apart and bump them up a setting or two.
    Tomorrow I'll get it aligned. I did have some rubbing when backing up, hard over to port. But I'm going to sus that out in the AM.
    Broncobroke, equin, aminter0 and 3 others like this.
  10. Dec 3, 2018 at 8:13 AM
    justfortun
    James
    Boston
    2016 SR5
    Bilstein 6112 at 1.3"
  11. Dec 3, 2018 at 8:28 AM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    Great job and excellent write up. I have to ask though, WTF happened to you fingernail in the anti seize picture?!?!?!?
  12. Dec 3, 2018 at 8:28 AM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I was nervous just reading/looking at pictures! Nice write up!
  13. Dec 3, 2018 at 8:43 AM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    i always do the on the truck method. i've used those spring compressors in the past, but so much easier to just take two bolts off the lower arm and let a jack do all the work for you!
    kparrow likes this.
  14. Dec 3, 2018 at 9:28 AM
    justfortun
    James
    Boston
    2016 SR5
    Ah, the fingernail. I was picking my nose and the snail got it.
    panicman likes this.
  15. Dec 3, 2018 at 9:32 AM
    justfortun
    James
    Boston
    2016 SR5
  16. Dec 3, 2018 at 9:45 AM
    justfortun
    James
    Boston
    2016 SR5
    That’s sounds efficient. I’d never done it before, so I figured I’d go by the rules before I learned to break them. Really couldn’t have been easier putting the shocks together though. I guess it’s never a big deal until suddenly it is.
    Next time you do it, take pictures please!
  17. Dec 3, 2018 at 9:52 AM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    Dude! As a kid my mother threatened me with the Silverstein poem. I'm still nervous.....
    Also, this write up was awesome.
  18. Dec 3, 2018 at 12:30 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    already done...and there are a few others and videos as well...
    http://www.toyota120.com/forum/showthread.php?t=3270
  19. Dec 3, 2018 at 12:50 PM
    justfortun
    James
    Boston
    2016 SR5
  20. Dec 3, 2018 at 2:19 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    haha, i cant take any credit other than searching the intarwebz for that post! but its a good one and what i have followed on my trucks for years now. very easy. just make sure you have red locktite and a 250# or whatever tq wrench (can be rented for free at vatozone or orieleys) to reinstall the lower bolts to the spindle.
  21. Dec 7, 2018 at 9:36 AM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    What a great write up @JustForFun! I just purchased a 2019 Tundra and I too have the 6112 on order. When I remove the factory yellow Bilsteins, I want to keep them assembled for future use. I don't want to take them apart just to use the 'top hat.'. With that, how do you like the KYB top hat product? Would you mind sharing the KYB part number you used, if you like and approve it, I'll buy them today! You have a good photo of th box but I don't see a part number anywhere. Thanks in advance!
    Thanks,
  22. Dec 7, 2018 at 10:12 AM
    justfortun
    James
    Boston
    2016 SR5
    Heya George,
    This brand top hat was what Amazon recommended as the most popular purchase for those who had purchased the 6112s. They seemed well made, but I guess only time will tell.
    KYB SM5737 mount kit.
    Good luck!
    georgiey22 likes this.
  23. Dec 7, 2018 at 10:17 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good work on the writeup. Those spring compressors look much better than the harbor freight ones i have used.
  24. Dec 7, 2018 at 10:18 AM
    csuviper
    Broomfield, CO
  25. Dec 7, 2018 at 10:19 AM
    csuviper
    Broomfield, CO
  26. Dec 7, 2018 at 10:56 AM
    georgiey22
    georgiey22 SW Idaho
    Thank you justforfun. Does two sets come in the box or should I purchased to boxes? Will order them today. Thanks man!
  27. Dec 7, 2018 at 11:12 AM
    georgiey22
    georgiey22 SW Idaho
    James - I live in Southern California but travel to Framingham a few times a year for work. I noticed you are in Boston, that is a fun place to live.
  28. Dec 7, 2018 at 11:21 AM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Well done write up
  29. Dec 7, 2018 at 12:19 PM
    Hellafied write up!
  30. Dec 7, 2018 at 12:43 PM
    15whtrd
    15whtrd Mr. Blonde
    Did the vice grips on the shaft scratch it up pretty good? Hopefully it’s not in the area of travel for the shock and seals. I thought the square end of the shock shaft was used to keep the shaft secure when tightening?
    Shaft shaft shaft shaft LMFAO
    HighDesertSurfer and Law323 like this.
