Done light swap snafu....bulb stuck in headliner
Discussion in 'Lighting' started by HBdirtbag, Mar 9, 2017.
  1. Mar 9, 2017 at 5:09 PM
    HBdirtbag
    HBdirtbag [OP] New Member
    Walnut Creek, CA
    2017 limited cm
    swapped in LED's today and went full retard. When I pulled the first bulb out it flew out and went into the headliner. Then my dumbass did it with the second light.
    Is the dome light sealed in there or are these things now floating around the headliner?
    mdavis, Patriot and Black Wolf like this.
  2. Mar 9, 2017 at 5:19 PM
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    damn it!!! lol!!! did you laugh after you said "oh snap!!!"?
    Patriot likes this.
  3. Mar 9, 2017 at 6:02 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Absolutely. Then cried when I turned a corner and heard something move around
    Patriot, Black Wolf and GNTundra like this.
  4. Mar 9, 2017 at 6:08 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Which means I answered the question I asked of if the dome light is contained. At least now I have an excuse to sound deadening the ceiling. Anyone have instructions for roof liner removal?
    Black Wolf likes this.
  5. Mar 9, 2017 at 6:38 PM
  6. Mar 9, 2017 at 7:43 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I have a dome light living in there too. Luckily no rattles when I turn.
    040Tundra and Black Wolf like this.
  7. Mar 9, 2017 at 9:24 PM
    rockjockey
    rockjockey Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    Below is a drawing from the 2015 manual showing what the headliner looks like on the inside when removed (this drawing is for roof without sunroof - let me know if you need the one with sunroof). After reading the procedure in the manual for headliner removal, I'd rather stick needles in my eyes than take on that job. The procedure starts with removing the scuff plates at the bottoms of the doors. From there, you basically take your interior apart to remove the headliner.
    A suggestion to stop the lost bulb from rattling around - drop the roof console box and the room light assembly and stuff a wad of masking or painters tape in several places. Maybe push the wad of tape out to the edges of the roof using a coat hanger or some other flexible/bendable tool, using the drawing to help you avoid any wiring or other internals. On the front edge, you might be able to stuff the tape up to the front edge of the roof with your fingers. If you're lucky, the bulb(s) will roll into contact with the tape and get stuck. The tape and bulb shouldn't hurt anything being up there indefinitely. Just a thought.
    The original photo of this drawing is much clearer. If you need to see more detail, PM me and I'll email you the original.
    040Tundra likes this.
  8. Mar 9, 2017 at 11:58 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    David
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Is it possible to get it out using a magnet? Wonder what metals they use in the bulb.
  9. Mar 10, 2017 at 4:30 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    RockJockey, great post. Thanks a lot!
  10. Mar 10, 2017 at 4:46 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Note to self- pass on this mod. I don't need or want to ever remove my headliner due in part to a fat finger moment.:rofl:
    joonbug and HBdirtbag[OP] like this.
  11. Mar 10, 2017 at 4:56 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  12. Mar 10, 2017 at 5:37 AM
    Stig
    Stig New Member
    Maybe a magnet on anew extension can pull it out
  13. Mar 10, 2017 at 1:14 PM
    rockjockey
    Spring, TX
    The trick is to drop the roof console box and room light assembly before replacing the bulbs. That way you're not working with parts up inside your headliner. Neither is very hard to get out (unlike the headliner).
    I screwed up my LED install the first time due to NOT following this advice. However, I wouldn't hesitate to do it again, knowing what I do now. Here's a link to my first time frustrations and some detailed pics I posted showing how to drop the roof console box (I think the removal/install pics are on page two of the thread :
    https://www.tundras.com/threads/how-to-turn-a-5-min-job-into-a-3-hour-job.8157/
    Patriot[QUOTED] likes this.
  14. Mar 10, 2017 at 2:02 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Could try this technique:
  15. Mar 10, 2017 at 3:18 PM
    Patriot
    Patriot Member
    This is one dam funny bunch of posts...
  16. Mar 10, 2017 at 3:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Sticky Bandits!!!
    Patriot likes this.
