Dome fuse blowing
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ronymore, Dec 21, 2022.
  1. Dec 21, 2022 at 5:34 PM
    Ronymore
    Ronymore [OP] New Member
    Rony
    2018 tundra crew max trd off road
    None
    What’s up guys i need knowledge from u guys. My 2018 tundra keeps blowing the dome fuse. I already checked all the dome cabin and visor light bulbs and anyone knows it they any more light bulbs in the cabin other then the ones I already checked? Any input will be much appreciated thankz
  2. Dec 21, 2022 at 5:42 PM
    Taco-Spike
    Two Trucks
    Are they stock bulbs?
  3. Dec 21, 2022 at 5:44 PM
    Ronymore
    Rony
    None
    Yes they are all stock
  4. Dec 22, 2022 at 9:26 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Replace bulb and see what happens. Then look for obvious shorts. Check switches. Measure resistance of circuit with and without bulb to isolate if before or after bulb
    1lowlife likes this.
  5. Dec 22, 2022 at 10:24 AM
    Ronymore
    Rony
    None
    Ok sounds good thank you will try my best
  6. Dec 25, 2022 at 3:42 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you figure this out yet?
    My dome fuse keeps blowing as of 3 days ago.
    I can replace it, and everything works fine, but it eventually blows again by the next day.
    My alarm keeps going off when the fuse is good because it thinks a door has been opened.
    But when the dome fuse is blown, the alarm doesn't go off.
    I've got aftermarket interior LEDs in stock fixtures, LED footwell lights, and LED puddle lights, on that circuit, but it has been working just fine for several years...
    The only thing that has changed is the single digit temps we had at night the last few days.
    Merry Christmas...
