Does your pano roof open all the way with one touch?
Discussion in '3rd Gen Tundras (2022+)' started by Tundranewcomer, Oct 25, 2023.
  1. Oct 25, 2023 at 11:09 AM
    Tundranewcomer
    Tundranewcomer [OP] New Member
    ‘22 MBM Platinum w/ power running board and advanced package
    So I recently noticed that my sunroof doesn’t actually open all the way when you push the button once. After it finishes opening I noticed if I hold the button longer it will open another 3 inches or so. Anyone else seeing this?
  2. Oct 25, 2023 at 11:16 AM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    I've thought about asking this question myself. Yes, mine stops just short of a full open, and if I hit the button again it will open all the way. It also seems pushing the button up to tilt the panel barely cracks it at all. I keep forgetting to do the same in the Highlander to compare, though to be fair that isn't a pano roof.
    matthinkle likes this.
  3. Oct 25, 2023 at 11:43 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    That is how its designed. It opens as much as it does with one touch for "wind noise" purposes. If you pull it back all the way it just gets louder in the cab.
    Tundrastruck91 and matthinkle like this.
  4. Oct 25, 2023 at 11:52 AM
    Ron23
    Ron23 New Member
    Ron
    2023 1794 TRD OR
    It stops short of fully open to reduce wind noise. Oddly enough, the manual documents this for the regular sunroof but not for the panoramic sunroof.
    Tundrastruck91 likes this.
  5. Oct 25, 2023 at 12:11 PM
    g4waldo
    Makes sense, but why not just make that the max open distance? I usually only drive 40 or under when I have it open, so I don't notice much wind noise difference. Granted, I usually open the rear window at the same time.
  6. Oct 25, 2023 at 12:29 PM
    locoj
    locoj New Member
    Strange. Mines open all the way with a longer push. Even if I have the shade cover it all retracts and open after one push. Mind you mines is a 22 not sure if they changed it for other models
  7. Oct 25, 2023 at 12:36 PM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    My wife’s Outback does the same thing. I had assumed this was fairly common.
  8. Oct 25, 2023 at 1:11 PM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Yes it is normal, my STI does it too.
  9. Oct 25, 2023 at 3:37 PM
    Tom976
    Tom976 New Member
    Tom
    Mine does exactly the same
  10. Oct 25, 2023 at 4:04 PM
    DaveE
    DaveE New Member
    2023 Platinum Hybrid, Magnetic Gray
    My sunroof is one touch to full open.
  11. Oct 25, 2023 at 5:04 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Every Tundra I ever had opened to a certain point and then an extra touch brings it back a little further. My 22 Platinum is the exact same way. I’m sure it’s for optimal wind noise but when I open the roof I always bring it back as far as it goes. Totally normal….
    astrength22 likes this.
  12. Oct 25, 2023 at 8:23 PM
    Breathing Borla
    Northern Illinois
    when you think it’s all the way open and done , hit the switch again , it will go back further
    DaveE[QUOTED] and pwpblue like this.
  13. Oct 26, 2023 at 3:53 PM
    DaveE
    DaveE New Member
    Just tried this. Nice, learned something new :thumbsup:
  14. Oct 26, 2023 at 5:35 PM
    Tundranewcomer
    I guess when I have it open I’m not going fast enough to have the noise be any different between the two positions. Alternatively, I usually open the back glass too so maybe that negates the different positions.
  15. Mar 13, 2025 at 1:29 PM
    Noobo Baggins
    Noobo Baggins New Member
    Glenn
    2025 Platinum Lunar Rock
    OE 3" Lift, 35" BFG KO2
    Just now noticing the "tilt up" barely opens it at all.
    I thought maybe it was getting stuck but seems others are the same way from what I'm reading in here.
  16. Mar 13, 2025 at 2:15 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Yeah, the tilt up barely opens, not enough to throw an empty beer can out. :rofl: But it does create some air movement in the cab. Would probably be noisy if it opened more.
    hinkle, Blufin and Breathing Borla like this.
  17. Mar 13, 2025 at 2:18 PM
    Breathing Borla
    Northern Illinois
    thats why we have a full roll down rear window :burp:
    hinkle and Raven67[QUOTED] like this.
  18. Mar 14, 2025 at 8:24 AM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    I know this is slightly off topic, sorry....but is there a way to get it to stop at maybe 1/4 way open? I'd like it to open up some but still have the sun shade benefit. thanks.
  19. Mar 14, 2025 at 12:39 PM
    Noobo Baggins
    Glenn
    I agree, it would be nice to open the moonroof a small amount and still have the sunshade 3/4 closed.
    I wasn't able to figure out a way to leave the sunshade partially closed while having the moonroof open any amount at all.
    Seems like the sunshade has to be all the way open to operate the moonroof at all.
  20. Mar 14, 2025 at 12:43 PM
    Noobo Baggins
    Glenn
    I've had other vehicles where the tilt up was much higher.
    I think the reason ours work this way is that it would have been harder / more expensive to design it to tilt up higher.
    The way this functions, it looks like the tilt up is merely the initial motion of the slide open feature.
  21. Mar 15, 2025 at 6:39 PM
    Raven67
    Kentucky
    The workaround I used for this is to tint your whole roof with ceramic tint, it keeps all the heat out of the cab. With shade open you won't burn up in the sun. Ive always avoided sunroof for that reason. My truck came with the pano roof & my shade is open 90% of the time now with that tint. Totally enjoyable.
