Does this trim look right?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Netmonkey, Feb 10, 2017.
  1. Feb 10, 2017 at 10:08 AM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    so, I had my windshield replaced this morning and I knew that some trim around the window had to be moved/removed. but looking at it now, something just doesn't seem right. I cant put my finger on it, but something seems off. for those of you with 3rd gens, can you look at your truck and see if it is the same as mine?
    on the drivers side, do you have this large gap looking under the hood?
    I can see light through to the other side.
    this rubber piece is lose and doesn't seem to be tucked in right?
    the rubber piece is lose on the passenger side as well. and the holes? is something missing there? how is that rubber piece supposed to tuck in and fit with the surrounding pieces?
    I know I an obsessed with my truck, but am I being crazy here? o_O
  2. Feb 10, 2017 at 11:08 AM
    Netmonkey
    Georgetown, TX
    thanks for the pics.
    On your truck, it looks like the rubber pieces are adhered somehow (or at least tight fitting). on my truck, they are lose and have gaps.
  3. Feb 10, 2017 at 11:23 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    I had the same issue after having my windshield looked at as I had (And still have) a wind howl and 100km (60mph) or higher. The rubber pieces caught my eye after that and appear how yours kind of look. I was able to fix it a little bit when I got handsy with it, but not a large improvement.
  4. Feb 10, 2017 at 2:53 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    When ever I polish my truck I take those rubber pieces out. It fasten/snaps into place and yours looks normal.
    831Tun and NewImprovedRon like this.
  5. Feb 10, 2017 at 2:58 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Looks like mine too.
  6. Feb 10, 2017 at 3:34 PM
    What those wires zip tied??? o_O
  7. Feb 10, 2017 at 4:27 PM
    Jus wanted to poke fun Ron lol
    NewImprovedRon likes this.
