Does this look like it's going to be an issue sooner than later?
Discussion in '1st Gen Tundras (2000-2006)' started by Hi06silver, Jan 1, 2021.
  1. Jan 1, 2021 at 1:58 PM
    Hi06silver
    Hi06silver [OP] Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Just poking around under the truck looking for stuff to grease/film. Brake line junction caught my eye. seems a little crooked on the right side. Probably been that way for a while...
  2. Jan 1, 2021 at 2:02 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It's fine hard lines get bent sometimes. As long as it isn't kinked you're good.
    koditten likes this.
  3. Jan 1, 2021 at 2:05 PM
    koditten
    Kirk
    Midland of the Mitten
    Same. It ain't leaking, it's fine.
    Good on you getting under your truck to look things over.
    Tundra2 likes this.
  4. Jan 1, 2021 at 2:10 PM
    Professional Hand Model
    Hand Protectors
    As long as its not leaking and the brakes are working as they should, then just leave it alone.
    Otherwise, you could straighten it up at your own peril by kinking the line causing a leak and therefore a total brake bleed.
  5. Jan 1, 2021 at 2:37 PM
    Wsteven
    Wsteven New Member
    2007 White SR5 Single Cab
    I know others say Leave it alone and that I would do if you are not prepared to replace the line and more because sometimes things just don't come apart the way they should so with that said if you decide to touch do not plan on just reaching in and pushing it even that should not be done anyways. I personally would just spray a good thread pentratrating oil on all of the fittings find a good source for all 3 lines and the "T" fitting and leave it be. I do that because I know it is going to bug me right up to the day I replace it.....:oops:
  6. Jan 1, 2021 at 2:53 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    should be fine... if it aint rusty or kinked. its good
