Does the model of truck affect the ability to tow?
Discussion in 'Towing & Hauling' started by Lunercrab, May 16, 2020.
  1. May 16, 2020 at 12:14 PM
    Lunercrab
    Lunercrab [OP] New Member
    So I've been looking at a tundra sport model. But now I'm starting to wonder if the sport tuned suspension would more or less sag more towing a camper vs the stiffer suspension of an off-road model. I'm getting this truck mostly for towing my camper which the current camper is only 4800lbs dry, but in case I get another camper one day I don't want to be limited. I prefer not to put on airbags as with my wd hitch I have no sag currently with my Tacoma I'm using.
  2. May 16, 2020 at 12:24 PM
    Sp33dNut
    Sp33dNut New Member
    2019 White Tundra DCOR
    I believe the sport suspension is stiffer than the OR suspension. At least that’s the way it was for my Tacoma.
  3. May 16, 2020 at 12:27 PM
    FatSal
    FatSal New Member
    STL, MO or ATL, GA
    2020 DC TRD OR Limited
    Full tank of gas never
    Yeah my OR seems softer in the ass end than my older brothers sport
  4. May 16, 2020 at 12:32 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    The OR suspension should be a little softer than non OR for better articulation when going off road .
  5. May 16, 2020 at 12:34 PM
    Lunercrab
    Yeah I'm just curious if there's any advantages or disadvantages to either suspension when towing. Like obviously I want comfort but I don't want headaches or regrets down the road. I mean I could add the sway bars down the road on like a limited model and slowly get rid of the chrome on say a limited model.
  6. May 16, 2020 at 12:36 PM
    FatSal
    FatSal New Member
    STL, MO or ATL, GA
    I just got out of a Tacoma and in to this tundra. No matter the trim, this truck is going to pull your trailer just fine. Find a tundy you like, you won't regret it.
  7. May 16, 2020 at 12:46 PM
    Lunercrab
    Well I hate chrome and yeah o can get rid of it lol. But I was looking at the Platinum models but didn't realize they actually tow less then the limited by almost 1k. So platinum is definitely out. I mean any tundra can handle my little camper but if I get a bigger camper down the line I don't want to short myself now lol.
  8. May 16, 2020 at 12:50 PM
    Lunercrab
    Dang so I read that crewmax tundras tow even less then the other styles. Is that true?
  9. May 16, 2020 at 1:02 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
  10. May 16, 2020 at 1:07 PM
    Sunnier
    Sunny
    San Diego, CA
    Yes. A DC cab Tundra has higher capacity than a Crewmax.
    As for towing, most on here that tow a lot end up adding airbags. No matter what package you start out with, the rear springs will sag over time even if you don’t tow. Our trucks are very heavy; adding payload in the bed or towing hastens the sagging.
    glowblue likes this.
  11. May 16, 2020 at 1:19 PM
    FatSal
    FatSal New Member
    STL, MO or ATL, GA
    I think bags will be in my future for sure. I had them on the taco and they helped a lot.
  12. May 16, 2020 at 1:27 PM
    Sp33dNut
    Sp33dNut New Member
    I tow a 17’ Coachman 192RBS with a loaded weight of about 4500 lbs and use a WD hitch. It levels out nicely and tows great. Over the winter I installed a TRD rear sway bar and just installed airbags (we want a larger TT). I can’t wait to tow with it to see how much better the ride will be. The rear sway bar definitely flattens the truck out going around corners.
  13. May 16, 2020 at 1:30 PM
    Lunercrab
    Was the sway bar hard to install?
  14. May 16, 2020 at 2:03 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    ^This. Also FWIW, 3rd gen Double Cabs have better safety ratings than Crewmaxs.
  15. May 16, 2020 at 2:04 PM
    glowblue
    VA
    Super easy - probably a 30 min to 45 min install tops.
    Sp33dNut likes this.
  16. May 16, 2020 at 2:06 PM
    Sp33dNut
    Sp33dNut New Member
    Not at all. The directions were easy to follow. It took less than an hour.
  17. May 16, 2020 at 2:17 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    I began with a stock 2018 DC TRD limited and added Firestone airbags and a TRD sway bar. For me this is a great combination. It provides a soft ride when I'm not towing or carrying a load but under a load (My 5th wheel pin weight is 1,060 lbs.) it doesn't sag or sway from side to side. I also towed a huge bumper pull trailer (Don't know hitch weight) without a WD hitch and it towed perfectly. If I were starting over with a bumper pull trailer, I'd spend my WD hitch money on airbags and a rear sway bar. I hauled a load of topsoil last weekend and the airbags worked well where a WD hitch would have been useless. Installing the rear sway bar is so easy that it should be a test. If you struggle with installing it then sell your tools and don't ever touch the truck again. :)
    Sunnier likes this.
  18. May 16, 2020 at 2:21 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    If the engine, transmission and rear gear are the same in each model then it all comes down to curb weight vs. remaining payload & towing capacity. The lightest model will carry & tow more than the heavier model with the same engine, transmission and rear gear.
