Does lowering the rear window make your headlights stay on?
Discussion in '2.5 Gen Tundras (2014-2021)' started by AleutianTaco, Jun 2, 2023.
  1. Jun 2, 2023 at 2:06 PM
    AleutianTaco
    AleutianTaco [OP] New Member
    2021 Crewmax. I loaded it into a conex for shipping and had to climb out the rear window (not the back door window but the one that spans the cab in front of the bed).
    The headlights would not shut off. Had to disconnect the battery. They were set to auto, I did not try turning the headlight switch to off. Just wondering if them staying on when the window is down normal or not? Thanks guys
  2. Jun 2, 2023 at 2:10 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I've definitely left the back window down if I run somewhere at night and have not had this issue. The headlights have a delay to turning off once you get out and lock it, but should not be staying on. If you hit lock on the key fob twice it actually gets rid of the delay and shuts off the lights as well.
    GODZILLA likes this.
  3. Jun 2, 2023 at 2:16 PM
    AleutianTaco
    Thanks for the reply. I left it unlocked and keys in it By the time I was able to slither under the truck to get to the battery about 10 minutes had gone by. Lights were still on. Was the first time I've put the back window down. Previously the headlights worked fine with the auto shutoff delay. Any ideas what I should start looking for to correct the problem? Truck only has 3000 miles on it.
  4. Jun 2, 2023 at 2:22 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    If I press my lock button a second time right after locking the truck, it shuts off the headlights. But I’ve never tried it with the rear window down. I leave my headlights on the Auto setting almost exclusively.
    PomDad likes this.
  5. Jun 2, 2023 at 2:49 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Why not?
    Tripleconpanna likes this.
  6. Jun 2, 2023 at 4:26 PM
    AleutianTaco
    Because the truck was inside a 40' conex and I didnt want to crawl back inside it lol. Its getting barged to an island. Ill see it again in a few weeks
  7. Jun 2, 2023 at 4:41 PM
    Hopefully you'll be able to open the hood and jump start it.
  8. Jun 3, 2023 at 8:56 PM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    Was it a push button start with a key fob? If so it is probably because you left the key fob in the truck. I have a 2019 with a keyed ignition (no button) and a head ache rack mounted on back so you can't crawl in or out of the truck through that window so sometimes when is real hot in summer I can leave that window down with out worrying about getting broken into and have never had any problems with the head lights staying on.
  9. Jun 3, 2023 at 9:41 PM
    AleutianTaco
    It is a push button start with keyfob. I always leave the fob in it and never had an issue with the lights not shutting off. Same with my 2022 tacoma. Will be interesting to see what the cause is when i get the truck again
  10. Jun 3, 2023 at 11:14 PM
    Jack_A_Lope
    Aaron
    One behavior I noticed is when I pull in my drive way at night and shut the truck off and get out of the truck and leave the drivers door open the head lights will stay on until I close the door. I noticed this while unloading groceries but I have never experienced any issues with the rear window and head lights.
  11. Jun 3, 2023 at 11:16 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Pretty sure it's because you never opened a door after turning it off. Timer starts after the door opens. :notsure:
  12. Jun 3, 2023 at 11:27 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Yup, exactly. Even opening the door an inch is enough.
  13. Jun 4, 2023 at 1:42 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If not he'll be crawling back in through the window, dropping it into reverse, crawling back out, and then pulling it out of the conex by the tailgate!
  14. Jun 4, 2023 at 3:54 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I don't think there is anything wrong, so no reason for concern. The window being down has nothing to do with the lights. It is just because you left the lights on auto and didn't open the door or lock the truck.
