Does it get worse?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pac12AfterDark, Aug 30, 2021.
  1. Aug 30, 2021 at 2:43 PM
    Pac12AfterDark
    Pac12AfterDark [OP] New Member
    Put e eated 295/60/20 on my truck to support my FWC.
    Lost about 4 mpg. I have 2 questions
    1) I am running ~35 psi average, will higher pressure lead to higher milage
    2) since I'm already running at ~12 mpg. Has the hit already be felt? Is it safe to assume I wont see any additional ill effects of leveling? I have been noodling doing 5100s.
    Bonus - would going to a lighter wheel help with unsprung weight and see a little boost in milage.
    I am happy with the truck, and milage believe it or not - just curious...
    Thanks!
  2. Aug 30, 2021 at 2:45 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Lighter wheels and higher pressure will definitely help with gas consumption. You’ll never be a Prius.
  3. Aug 30, 2021 at 2:48 PM
    Pac12AfterDark
    Thanks - totally agree.
    Any thoughts on the leveling kit?
  4. Aug 30, 2021 at 2:54 PM
    AZBoatHauler
    So.Arizona
    I’m trying to figure out how you stuffed 34” tires on a stock height rig. Any pics?
  5. Aug 30, 2021 at 2:56 PM
    Pac12AfterDark
    DOH - 275. Sorry!
    hi_rawb and AZBoatHauler[QUOTED] like this.
  6. Aug 30, 2021 at 3:01 PM
    AZBoatHauler
    So.Arizona
    I agree going to 5100 wouldn’t change much (if anything) at this point but there is still MPG to be lost with the right mods! Think bigger tires, sliders, armor… we will have you down to 10mpg by the time this is over.
    I’ve found 40 psi to be a nice balance between comfort and tire wear.
    batman900 likes this.
  7. Aug 30, 2021 at 3:05 PM
    Pac12AfterDark
    I have my eye on all of them, but with the truck camper I try to watch GVWR. Would LOVE some nice sliders, tow mirrors.
    Maybe if I go flatbed I can save a few pounds. The 81087 is only 270#. On with the madness!
    Thank you for the pressure suggestion
  8. Aug 31, 2021 at 3:58 AM
    racer01
    racer01 New Member
    Geoff
    Aiken South Carolina
    23' TRD Pro
    295/70-18 Nitto Recon Grappler, RB 20 running boards
    If you haven't corrected the speedometer and odometer due to the 3.4% larger tires your indicated MPG in the display will be artificially lower than reality since you are actually traveling 3.4% further than the odometer is registering. Lighter wheels definitely help mpg, but not as easy and effective as lighter tires. MPG hit with heavier and larger wheels and tires seems to affect MPG at all speeds. Leveling will get you another but smaller hit on MPG, but seems to affect the truck worse at higher (hwy) speeds due to aerodynamic inefficiency of lifting the nose.
    Oey12 likes this.
  9. Aug 31, 2021 at 8:51 AM
    Pac12AfterDark
    Interesting, I have not. I hand calculated using On X. Seemed to be pretty close.
    That makes sense with the 5100s. Cant make itouch worse than the wind resistance from the teuck camper. I might just do it anyways.
    Thanks everybody.
