Does it effect towing capabilities?
Discussion in 'Towing & Hauling' started by Old Alan, Jun 22, 2017.
  1. Jun 22, 2017 at 4:23 PM
    Old Alan
    Old Alan [OP] New Member
    San Jose
    2017 SR5 Crewmax
    Toytec Boss lift, Black Rhino Warlords wheels, 295/70/18 Nitto Ridge Grapplers, SDHQ Sliders, RBP grill, color matched surround and bulge, Kendwood head unit.
    Now that I have your attention, does a moderate (3") lift kit have an effect on the truck's towing capabilities? Does it lessen the max or change anything vital? Are there adjustments to be made?
    What size lift would start to have an effect?
    What about wheels?
    I want to lift a tad for some bigger tires, but I don't want that to kill the towing.
  2. Jun 22, 2017 at 4:38 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  3. Jun 22, 2017 at 5:12 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The lift will have little effect on towing, larger wheels will.
    How much depends on how large. As wheel diameter increases, torque (as it is applied at the road) decreases.
  4. Jun 22, 2017 at 5:22 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    The weight distribution hitch would have to be readjusted if one exists or height adjustable tongue..or lift the trailer by same height..lol
  5. Jun 22, 2017 at 6:37 PM
    PNW-Tundra
    PNW-Tundra New Member
    Brent
    Washington
    2017 Crew Max SR5 TRD
    This guy has it down!
  6. Jun 22, 2017 at 6:38 PM
    PNW-Tundra
    Brent
    Washington
    In all seriousness, this advice is spot on.
    kenomouth64 likes this.
  7. Aug 4, 2017 at 10:46 AM
    Gearman
    Gearman New Member
    2017 tundra Limited TRD
    If your going to tow light, a small lift will be ok.
    If you want to tow heavy, leave stock height, get LT tires, upgraded shocks, possibly air bags
    If just got my tundra for towing. Down sized from a F350 crew cab long bed.
    Tundra does ok with light loads...... but getting up in the 5-6k lbs.... starts to be more of a white knuckle drive
    The big question, how much are you going to tow and how much reduction of towing performance are you willing to give up for “looks”???
    QuikreteTundra likes this.
  8. Aug 4, 2017 at 2:16 PM
    The Juice
    The Juice THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    I have a 2.5 inch lift on the front and airbags in the back.....my wheels are 285/65r18 on custom 18inch wheels...... I tow 6000lb travel trailer(that is loaded) and it tows like a princess....... I also have a blue ox sway control hitch...... Bilstein 6112's up front set at max height...... I will be adding a toy tec add a leaf to the rear that lifts the rear 1" to 1.5"...... My rear shocks are the ARB® - OME™ Nitrocharger Sport shocks....... best suspension I've had of my 3 different Tundras..... I'd imagine the ARB OME front suspension would be great as well and would lift the front 2.5 to 3 inches...................... The key is to get the airbags with on board air compressor if you can afford it!!! She Drives Like A Princess.....:burnrubber:
