Does anyone make an 8 to 10mm wheel spacer shim?
Discussion in '3rd Gen Tundras (2022+)' started by Joe T, Jun 16, 2024.
  1. Jun 16, 2024 at 7:24 AM
    Joe T
    Joe T [OP] New Member
    Proper hub centric type. Can install longer studs if necessary.
    This is for an LX600 but they share the spacing and hub size with the 2022+ Tundra. Zero activity on those forums and I have owned a Tundra before. :thumbsup:
  2. Jun 16, 2024 at 4:01 PM
    Bnewman077
    Bnewman077 Happy 2023 Owner
    2023 Tundra TRD OR Lunar Rock
    18” Method Wheels, 35x12.5 Toyo AT3, TRD Pro suspension with Westcott preload lift and Icon rear springs
    Joe T[OP] likes this.
  3. Jun 16, 2024 at 4:06 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Sounds like pretty hokey idea on a 100k car
  4. Jun 16, 2024 at 4:31 PM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    https://motorsport-tech.com/bora.html
    Bora spacers are a high quality spacer. They will make whatever thickness you want but you’ll definitely need extended studs that thin.
    I reached out to them about 8mm spacers a while back and ended up going down a different route bc I didn’t want to replace studs.
    TRD VO and Joe T[QUOTED][OP] like this.
  5. Jun 16, 2024 at 6:07 PM
    Joe T
    Ok I will contact Bora.
    Hokey would be the 1 inch ones. 8-10mm would be subtle (to the edge of the mudflap). And it was 120 and I plan to put 10 in mods :thumbsup:. Want to run the stock Fsport wheels with hwy tires at times and they are way up in there backspacing. No salt or mud to worry about on the highway around here.
    I may be confused but people run tundra rims on these and I figured the bore size is the same and its a typical hub centric setup.
    Almost no traffic on the lx600/lc300 forums.
  6. Jun 16, 2024 at 6:59 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I run 1.25 spacers for the last 3-4 years on this truck. Havent had an issues with them.
    they are bigger, however i like that they match up to the hub centric aspect of the wheel mounting surface and then also add that hub centric mounting point on the spacer as well just like stock. A thick washer like the 8-10mm would negate that hub centric flange right?
  7. Jun 16, 2024 at 7:12 PM
    Hella Krusty
    Hella Krusty New Member
    We slammed a 2009 Venza and that has been running spacers on the wheels ever since.....never an issue.
    Saltyhero13 and Joe T[OP] like this.
  8. Jun 16, 2024 at 7:18 PM
    Joe T
    Thats the thing it should have the flange to be proper.
    Hella Krusty and Hbjeff[QUOTED] like this.
  9. Jun 16, 2024 at 7:49 PM
    TRD VO
    TRD VO Fix It Again, Tony
    Louisiana
    2015 Inferno CrewMax TRD Pro
    I highly recommend motorsport-tech. They make great quality spacers or adapters for your needs. Been using them across a handful of my vehicles since 2012. From the daily drivers to the abused track cars, the spacers/adapters have always held up great! Only con really was having to replace wheel bearings more often than I'd like, but that's expected.
    :notsure:
