Does anyone know where I can get something scanned and 3d printed?
Discussion in 'Off-Topic Discussion' started by TucsonTundra1794, Feb 21, 2023.
  1. Feb 21, 2023 at 6:38 AM
    TucsonTundra1794
    TucsonTundra1794 [OP] ASCM #6-11 I'll buy if you're willing to ship
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I have the pro holder phone mount for my tundra and it comes with a clip that snaps between the radio and drivers side trim to hold the phone securely. I would like to have a matching one on the opposite side of the radio for my work phone or my wife's phone. Pro holder only makes the driver's side one so I was hoping someone could scan the driver's side clip and reverse it for the passenger side. Any help would be appreciated. Thanks guys.
    https://www.amazon.com/dp/B08L698D64
  2. Feb 21, 2023 at 6:42 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
  3. Feb 21, 2023 at 6:48 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  4. Feb 21, 2023 at 7:18 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
  5. Feb 21, 2023 at 7:23 AM
    M3Tundra-JK
    Scott
    2005 GX470
    That's gonna get expensive. Have you tried emailing the manufacturer and see if they could, or have done that already? Likely cheaper to research more mounting options for the other side.
  6. Feb 21, 2023 at 7:36 AM
    RobertD
    Robert
    DFW, Texas
    TucsonTundra1794[OP] likes this.
  7. Feb 21, 2023 at 7:38 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yeah I figured as much, I was hoping maybe someone on here had a printing business or a machine at work they are allowed to use. I have the rago dash mount I just wanted the phones down lower then that.
  8. Feb 21, 2023 at 7:57 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I could definitely give that a shot. That will work with the phone mount and hopefully support the weight. I'll buy that today and give it a shot. Thanks! The only other options I found were drilling or running a long arm down from the dash mount.
    RobertD[QUOTED] likes this.
  9. Feb 21, 2023 at 9:27 AM
    A passenger side would be nice, especially for the wireless charging. I had to modify and JB Weld mine because it bounced and vibrated so bad. I wish they had one for the 4Runner too.
  10. Feb 21, 2023 at 10:34 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    There isn't much real estate in my 2000 4runner and I really don't want to waste a cup holder on it so if this sticky mount works I'll try and find a spot for it in the 4runner as well.
  11. Mar 24, 2023 at 6:00 PM
    Florida AF
    Logan
    North Florida
    PM me. We can go back and forth and then I can get something printed to test. If it works, I can send the file to a buddy with a resin printer. I wouldnt trust filament long term with the sheer force.
  12. Mar 24, 2023 at 6:13 PM
    What part of FL?
  13. Mar 24, 2023 at 6:20 PM
    Florida AF
    Logan
    North Florida
    St. Pete area.
  14. Mar 25, 2023 at 5:49 AM
    Nice. I'm on the north end of PP...Bryan Dairy and 66th
    Florida AF[QUOTED] likes this.
  15. Mar 25, 2023 at 6:43 AM
    Florida AF
    Logan
    North Florida
    Beautiful truck and super close by lol... I am sure I will see you around! Ill be at Quacker Steak today and IRB tomorrow. I love off 94th and MLK. But play all over for various reasons.
  16. Mar 25, 2023 at 6:54 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I’ve used this surface mount..been holding up for a couple years now..
  17. Mar 25, 2023 at 7:12 AM
    coTony
    Tony
    Montrose, CO
  18. Mar 25, 2023 at 7:16 AM
    coTony
    Tony
    Montrose, CO
    The Rago console “Bridge” provides nice places to mount things but it blocks the glove box from opening. I have the molle rail system mounted on the sides of my console and have an arm coming up from there to sit next to my knee. I do not need my phone in view, it comes on the stereo screen anyway when a call/text comes.
  19. Mar 25, 2023 at 8:58 AM
    JRS
    JRS New Member
    2012 DCLB
    The idea of 'scan and print' is really a misconception and the mfg likely won't give you a mirrored STEP. You're going to need a CAD file made for it and often the part has to be designed with the intent of being printed. Your best bet is to give that to someone so they can reverse it with calipers.
    Like above, a resin print would be nicer, but filament printed on 45deg has worked well for me on parts that require getting around the weak interply bonding. I'd make that in two pieces - base and ball mount. The base can be printed vertically and ball on 45deg.
  20. Mar 25, 2023 at 9:19 AM
    Florida AF
    Logan
    North Florida
    That is my plan. Take one, measure and design, flip and print in two pieces. I may even see how much I can just buy a ball mount for and then screw it in, still maintaining two pieces. That would also eliminate some of my concerns for the sheer points.
    If this turns out worth a damn, and passes resting, I'll post up the file and link. Fingers crossed.
  21. Mar 25, 2023 at 9:35 AM
    JRS
    JRS New Member
    2012 DCLB
    I made a part for my 2.0 with column shifter to horizontally hold my phone using the pocket below the TC selector. Doesn't look like it's there for the 2.5. Was going to suggest that as another idea.
  22. Mar 25, 2023 at 12:26 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I definitely thought about this but I uh... need to grab my insurance and registration far to often to lose access to my glovebox.
  23. Mar 27, 2023 at 5:41 PM
    You see the story on the plastic surgeon from Largo that killed the attorney? Damn dude hauled the body with his Tundra. :eek:
  24. Mar 28, 2023 at 8:43 AM
    Florida AF
    Logan
    North Florida
    Was just reading about it! crazy!
