Does a lift kit void warranty on 2018 Tundra?
Discussion in 'Suspension' started by lone_wolf, Apr 7, 2020.
  1. Apr 7, 2020 at 9:27 AM
    lone_wolf
    lone_wolf [OP] New Member
    Cape Coral, FL.
    2018 Tundra SR5
    Stripes. cap, alarm, marker lights, reflectors.
    Greetings isolationists! I bought a 2018 left over in November 2018. Does Toyota sell a lift kit and will they install it to honor a warranty?
    Thanks in advance!
  2. Apr 7, 2020 at 9:30 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    A properly installed lift won't void your warranty. There would need to be proof that any modifications caused a failure in order for Toyota to deny a warranty claim. That said, your mileage may vary.
    I had a CV boot go bad after installing some takeoff Pro shocks, and my dealership had no problem replacing it under warranty.
    Boerseun likes this.
  3. Apr 7, 2020 at 9:31 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Sure, they will install it, for a premium. No, it doesn’t void your warranty. They have to prove the lift is the cause of your potential issues. They will, however, try to play games and claim it’s the lift unless you have a great dealer.
    What type of lift are you looking at?
    lone_wolf[OP] likes this.
  4. Apr 7, 2020 at 9:36 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Each dealer is different. We have two dealers in town, owned by the same guy, but the managers are totally different in management style and that trickles down through all departments.
    One dealer refused to work on my TSS sensor recall because of my leveling; they even wanted to disconnect it. The other dealer had no problem doing it. The same would be for lift or leveling components - one will probably try to blame any issues on the lift and the other will gladly replace parts under warranty.
    You will have to talk to them and see how they feel about it if you are concerned about the warranty.
    DM 2018 Tundra and lone_wolf[OP] like this.
  5. Apr 7, 2020 at 11:19 AM
    lone_wolf
    Cape Coral, FL.
    2018 Tundra SR5
    Thanks. Probably just leveling (raising) the front.
  6. Apr 7, 2020 at 11:24 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
  7. Apr 7, 2020 at 11:33 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    Its really relative to the warranty claim. If they can link your modifications to the failure (i.e. broken CV axle with 37" tires) then they have grounds to not honor warranty claims.
    lone_wolf[OP] and Tchase like this.
  8. Apr 7, 2020 at 12:26 PM
    lone_wolf
    Cape Coral, FL.
    2018 Tundra SR5
    Toyota says they can raise the front 3" to level it for $800.00 but have a 25% off service special right now that they're seeing if they can apply to this too. Waiting for reply. A reputable truck accessories shop locally say they can do it for $500.00.
    Toyota also said they can raise the front 3" and the back 2" for $1200.00 but I think this wouldn't look right on a 2WD SR5. Thoughts?
    Thanks again
  9. Apr 7, 2020 at 12:27 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If that's just for spacers and blocks, screw that. Did they say what they'll be using for the lift?
  10. Apr 7, 2020 at 12:31 PM
    lone_wolf
    Cape Coral, FL.
    2018 Tundra SR5
    I'm not sure what parts it is. I looked on line about buying parts for a front 5" lift and it's about $100.00. I've lost much of my mechanical ability in my 66 years and wouldn't try it myself or go for a "Joe's Garage" lowest bidder either.
  11. Apr 7, 2020 at 12:37 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    you’re probably getting RIPPED off with some garbage spacers. Go somewhere else and do it right with leveling shocks etc. 3” up front will give you a serious California lean. 1.9 inches is pretty level and they can’t really screw with you on just a level. The PRO comes leveled from the factory.
  12. Apr 7, 2020 at 12:42 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm assuming your warranty is through Toyota. My warranty came from my CU and they've been super gracious on my repairs. Sometimes they send out an inspector but I've only been shot down once and that was because the dealer wanted 4 hours of diag time. I purchased the higher coverage that applies to lifted vehicles. Stipulation though: I cannot go higher than 6" and 35" rubber (I've squeaked by that lift height though)
  13. Apr 7, 2020 at 12:44 PM
    lone_wolf
    Cape Coral, FL.
    2018 Tundra SR5
    Perhaps but I would think (and hope) Toyota would do it with the right parts. They have the combo front and rear kits in stock and say the front only parts takes about a week to get in.
  14. Apr 7, 2020 at 12:46 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This.
    Throw some 5100/6112 Bilsteins on there. For the rear I'd go with +3 Coachbuilder shackles
  15. Apr 7, 2020 at 12:46 PM
    lone_wolf
    Cape Coral, FL.
    2018 Tundra SR5
    Yeah, still toyota factory warranty.
  16. Apr 7, 2020 at 12:47 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Toyota is only as good as the dealer you use. Crap dealers will give crap service.
  17. Apr 7, 2020 at 1:05 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    So talking with my local dealer, I found they used a local lift shop. Then found out that the "leveling kit" they used was a spacer kit by RC. $800+ is what I saw it generally go for. But most people pay it since it's financed into their loan. I got a 6" ReadyLift and was told same that everything is still covered under warranty unless proven lift caused issue. Then was told that ReadyLift would take care of it then.
  18. Apr 7, 2020 at 1:28 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I would get that in writing from RL if possible.
    texasrho83 and Fotnot[QUOTED] like this.
  19. Apr 7, 2020 at 5:42 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    BTBAKER likes this.
