Does 2017 Tundra Tell you about misfires?
Discussion in 'General Tundra Discussion' started by dananderstein, Jan 2, 2024.
  1. Jan 2, 2024 at 2:03 PM
    dananderstein
    dananderstein [OP] New Member
    17tundra
    I have a 2017 Tundra. I replaced the spark plugs today, had to rebend one spark plug prong thing. Anyways I initially forgot to plug half of the distrubutor connectors back on and started the engine for a few seconds and it had a check engine light. I then reconnected the 4 connectors and started the truck again and it sounded normal but the light and traction control off was still on. So I disconnected the battery for 20 minutes and then I started the car. It initially instantly died. the second try it stayed on and the idle was low but it got to normal. Then I turned the car on and off and the idle remained normal and their are no lights on it.
    If I screwed something up and a cylinder is not firing will it give me a warning?
