Dobinson's hydraulic bumps for IFS
Discussion in 'Long Travel Suspension' started by Marvthehamster, Jun 24, 2025 at 2:06 PM.
  1. Jun 24, 2025 at 2:06 PM
    Marvthehamster
    Marvthehamster [OP] New Member
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI sliders
    Hey guys,
    I know this isnt solely for the long travel crowd, but figured I'd post here since this is where the best knowledge base is.
    Looks like Dobinson's is offering a kit designed to replace factory bump stops on the front of Tundras (or any IFS vehicle). I had wondered about this in another thread a while ago and the consensus was that there weren't any commercially available options. Obviously this kit would require cutting the stock bumps off and welding, but if the mounts are fabbed correctly, could be a relatively easy way to get hydro bumps on the front end. I love my rear hydro bumps and would love to have that same plush bottom out on the front without putting undo stress on the coil buckets.
    Has Dobinsons packaged something worthwhile for the DIY'ers here? What are your thoughts?
    https://exitoffroad.com/product/dobinsons-2-2-hydraulic-bump-stop-ifs-weld-on-mount-kit/
    @snivilous @Vizsla @reywcms @KevinK
    reywcms likes this.
  2. Jun 24, 2025 at 2:29 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I think that price is insane. $400 for that "mount" that doesn't fit anything in specific? Their whole "kit" is $1050, for $740 I can get some ADS bump stops with cans that just need some brackets welded on----and the Dobinson setup still needs brackets welded on since it's a generic setup.
    I wouldn't buy that. Now if you want their bump stops alone, that's a different question, but their weld on bracket looks like just added hassle. Adding bump stops to the front should be pretty easy, it's just a bump can with two triangles welded to the sides of the can in most cases. If you can install the Dobinson setup, you can install any hydraulic bump setup and save a lot of money and probably have something more elegant looking.
    reywcms likes this.
  3. Jun 24, 2025 at 2:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    snivilous likes this.
  4. Jun 24, 2025 at 8:52 PM
    Marvthehamster
    CO
    2018 CM
    Exactly why I posted here!
    I see what you guys are saying. I was thinking the mounts looked pretty generic. Just wanted to make sure I wasn’t missing something.
    @snivilous I think a pre made bracket that’s all ready to weld on is something that Sniv’s speed shop should look into! I’m too lazy/incompetent to figure out the geometry, but I’d buy a set ;)
    snivilous and reywcms like this.
