Dobinson C59-837V feedback
Discussion in '3rd Gen Tundras (2022+)' started by t300, Jul 10, 2023.
  1. Jul 10, 2023 at 12:50 PM
    t300
    t300 [OP] New Member
    Manitoba
    22tundra
    Has anyone running the c59-837v aka 220-440lb 1" lift ran them for any length of time unloaded? Curious how they ride unloaded, if they are bearable or simple too harsh without a load.
  2. Jul 11, 2023 at 3:07 PM
    lamaquina11
    lamaquina11 New Member
    lamaquina
    2013 Toyota Tundra Rock Warrior / grey
    N/A
    Just ordered them and will let you know in a few weeks once I've got some miles on them
  3. Jul 11, 2023 at 9:05 PM
    arizonayeti
    arizonayeti New Member
    2023 Silver Limited
    So I installed the 2" "stock weight" c59-834 front and 1" "stock" c59-839v rear springs with the IMS struts/shocks. I was trying to level the truck and have a leer cap 175lb on the back, but it actually raised the rear a bit as compared to the front over the stock rake...ya, not exactly what I was going for. With a trailer (450lb tongue wt) the truck sits pretty level and sags about 1.5in and doesn't hit the bump stop like the stock springs did when towing over some rough interstate sections. So, I guess my point is that the Dobinson "stock" spring rate is a bit heavier than stock and I don't notice any sag with an extra 175# topper on. That said the rear springs are soft (a bit firmer than stock) and soak up speed bumps even better than the front. The rear springs are variable rate, don't think the front ones are. Not sure this helps you but if you are planning on 400# extra I bet the c59-837v will still feel pretty good.
  4. Jul 12, 2023 at 1:05 PM
    t300
    Manitoba
    22tundra
    thanks, ordered a set, true test middle of august camping trip
