Dobinson C59-302 on 2001 RWD
Discussion in '1st Gen Tundras (2000-2006)' started by -soysauce-, Sep 11, 2020.
  1. Sep 11, 2020 at 5:51 PM
    -soysauce-
    -soysauce- [OP] New Member
    2001 SR5 2WD
    Will these springs fit on a 2001 2WD with 5100’s? I know I could’ve just used my Oem but they were rusted. I bought these off 1st gen and they didn’t specify it was only for 4x4 but on the invoice it says 4x4. Will I have any problems? Thanks!
  2. Sep 11, 2020 at 6:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Here is what I have on my 2002 V6 RWD Tundra.
    Dobinsons / Bilstein 5100 2-2.5"
    Front Lift Kit 2000-2006 Tundra
    Color Spring: Teal
    Add 1/4" Shim Spacer To Correct Drivers Side Lean
    Dobinsons Part Number: PS59-4030
    SKU: C59-302/24-261425/C59-4030
    Blue is the Dobinsons springs, Pretty sure red is the Bilstein 5100s, and pink is the drivers side lean spacer.
    I've had zero issues with this, and absolutely love the ride. Much better than the worn out OEM set up.
    Edit: Also in the rear I have Alcan leaf packs at 2inch lift also. Bilstein 5100 shocks in the rear.
    Edit: I ordered mine through 1stgenoffroad.
    Darkness likes this.
  3. Sep 11, 2020 at 6:15 PM
    -soysauce-
    2001 SR5 2WD
    Ok, that’s good to hear. I am about to do this swap but I don’t have that driver side lean spacer. Is it really necessary? I never noticed a lean if I’m in or out of the car
  4. Sep 11, 2020 at 6:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I guess it depends on if its leaning? Mine was leaning just a wee bit.
    Here is a before shot. Sorr that it is not the same angle.
    Here is the after shot.
    Here is another aftershot after its settled a little bit. I've been told it still leans a little towards the dirvers side. I'm not sure if its the parking lot or if I need another shim.20200713_194146.jpg
    Darkness and N84434 like this.
  5. Sep 12, 2020 at 5:29 AM
    Professional Hand Model
    Hand Protectors
    Yeah. The Starship is leaning to the Portside Scotty. Need full warp speed in the front left quadrant.
  6. Sep 12, 2020 at 10:31 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well then... not to hijack this thread, but...
    I wonder how much more of a lean correcting spacer I would need?
    Or just wait until I rebuild my front end, and see what it does?
    Maybe @Darkness can shed some light.
  7. Sep 12, 2020 at 11:23 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm firmly against any sort of spacer or "shim" in suspension.
    bmf4069 and Tundra2 like this.
  8. Sep 12, 2020 at 12:32 PM
    -soysauce-
    2001 SR5 2WD
    Why?
  9. Sep 20, 2020 at 8:01 PM
    1GOR
    1GOR New Member
    Josh
    2004 Tundra
    6" lift, Addicted Off Road Bumper, Winch, BD lights, dual batteries, solar, Fuel wheels with 34s. probably forgetting some things.
    I don't like spacer lifts, but you can get away with a 1/4" shim spacer to correct a lean. No problems.
