Do we have Transmission coolers ?? 2014 +
Discussion in 'Towing & Hauling' started by MillsTRD14, Aug 1, 2016.
  1. Aug 1, 2016 at 3:07 PM
    MillsTRD14
    MillsTRD14 [OP] New Member
    Aaron
    2014 Tundra TRD
    Ba mufflers 7 inch, Bilstein 5100 TRD strut bar, Firestone adjustable ride rite airbags, tow mirrors , BFGoodrich ta ko2 33s, TRD shift knob, blacked out emblems, tundra Pro grill......
    Ok so I'm about to head up the mountains with my camper then turn right around the next week and head to the Outer Banks can't wait !! . Here's my question Keith over at Dirty Deeds once told me that the transmissions in the Tundras are the same ones used in the Hino box trucks and they are very tuff transmissions. I believe him on that but where is the transmission coolers on the New gen Tundras ? Id love to see the transmission temperatures but I think they left that out on the very informative headsup display . What do you guys think ? Any easy way to hook up a transmission temp guage etc , and where is the dang tranny cooler ;) ????
  2. Aug 2, 2016 at 4:24 AM
    Ancient1
    Ancient1 New Member
    Tallahassee
    2012 rclb tundra 4x4
    On my 2012 it appears the trans cooler is part of the a/c condenser. The ultragauage shows trans temps 10 -15 degrees warmer than the Tacoma I traded.
    I am seeking additional info too.
  3. Aug 2, 2016 at 7:19 AM
    If you have the towing package, you have it.
    bandit likes this.
  4. Aug 2, 2016 at 7:26 AM
    ajstl
    ajstl New Member
    aj
    St. Louis, MO
    2015 Tundra
    That's a nice camper. I haul one as well, about 6800lbs. I know mine has a trans cooler, at least according to the dealer, since I did get the towing package. But it would be nice to see the trans temp. Anyway to add something aftermarket ?
  5. Aug 2, 2016 at 8:33 AM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    You can use a Scan Guage. It will read trans temp on the Tundras. I use one on my 2015. Comes in handy when towing.
  6. Aug 2, 2016 at 9:35 AM
    frogger
    frogger just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
    Trans cooler and Trans temp gague...3rd Gen doesn't have these? I guess us 2nd gen guys are "cooler" literally haha
  7. Aug 3, 2016 at 4:50 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    From what I'm reading the 3rd Gen Tundras have a integrated transmission cooler and engine oil cooler , trying to verify that now ;)
    frogger[QUOTED] likes this.
  8. Aug 3, 2016 at 4:59 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Also on another forum there is some chatter about a Android Torque app for your phone that you plug a Bluetooth device in your obd2 port that's monitors actual temperatures instead of a guage ....anyone got any data on this ?
    Thanks , yea I love it , wife really loves the kitchen in it . Its running about 7800 pds once I have everything in it for camping
  9. Aug 3, 2016 at 5:33 AM
    Okie
    Okie I'd rather be fishing!
    Patrick
    Tecumseh, Oklahoma
    2016 Black Tundra Crewmax
    I use the scanTool blue tooth for all my vehicles with the Torque app. Works really well and has saved me tons in repair cost. I haven't touched the surface of its capabilities. Basically if your vehicle has a sensor/input you can monitor via the torque app.
  10. Aug 3, 2016 at 7:23 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Thanks I just purchased it and got the OBD2 Bluetooth device on the way , man this thing looks awesome ! I can set alarm triggers for anything too !
    Law323 and Okie[QUOTED] like this.
  11. Aug 4, 2016 at 7:25 PM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Well so all my guage on it work flawlessly. ..except transmission guage and oil temp doesn't show
    I got mine hooked up and it shows everything except oil temp and transmission temp ? Am I doing something wrong ?
  12. Aug 4, 2016 at 9:04 PM
    Okie
    Patrick
    Tecumseh, Oklahoma
    @MillsTRD14 I hadn't had it connected to my 16 yet but my 1997 Mercedes, 2007 Jeep patriot, 2007 Chevy p/u and ol faithful my first tundra 2007 DC TRD all have read and operated flawlessly. I can't recall any of them other than the Chevy showing trans temp. I also us another app called OBDlink because it has Mode$06 and Mode$09 test monitors and will read PID values (o2 sensors ect...) basically where I've benefitted from this particular app was trouble shooting an ABS fault on the Mercedes down to high resistance on the rear diff sensor and on the jeep for a throttle plate to gas pedal disagreement. In both cases these sensors were good as far as the system was concerned during initial start/run cycles but the values they were displaying were out of design limits which I found in wire diagrams using Google. There are two Torque apps one being free and the other wasn't. Maybe I paid 19.99 not sure but maybe that might retrieve more data? I'll hook my scan tool up on the 16 in the next couple of days and see if I can locate trans and oil temps.
  13. Aug 5, 2016 at 4:00 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Ok well mine didn't work right away , I had to add another 2 sensor data points now it's working . Here is the information that worked on mine .
    For sensor 1 (Pan Temp):
    OBD2 Mode and PID: 2182
    Long Name: Transmission Fluid Temperature 1
    Short Name: Trans 1
    Minimum Value: 0.0
    Maximum value: 300.0
    Scale factor: x1
    Unit Type: °F
    Equation: ((((A*256)+B) * (7/100) – 400)/10)
    OBD Header to use: left blank
    For sensor 2 (Converter outlet temp):
    Long Name: Transmission Fluid Temperature 2
    Short Name: Trans 2
    Minimum Value: 0.0
    Scale factor: x1
    Unit Type: °F
    Equation: ((((C*256)+D) * (7/100) – 400)/10)
    trollrapala, 831Tun and Okie like this.
  14. Aug 5, 2016 at 10:43 AM
    Mike Tread lightly.
    south carolina
    Probably the way it's labeled in the app on his phone..
  15. Aug 8, 2016 at 5:54 PM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Yea I just need to relable one of them , one is for the pan temperature and the other is converter Outlet temperature. Works great !!!
  16. Aug 8, 2016 at 5:59 PM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    So my temperature towing up black mountain never exceeded 210 but what's interesting is when your on flat land and overdrive kicks in it will go as high as 230 but soon as it downshifts and RPMS rise temperature drops rapidly between 190-210 . Pretty cool !!!
  17. Aug 8, 2016 at 6:06 PM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Headed up the Mountain ;)
    Inquiringone, jfrd30, Law323 and 3 others like this.
  18. Aug 9, 2016 at 10:16 AM
    tacouser
    tacouser New Member
    Chicago
    Can I get some more info on that phone app you are using. Where do you get the app and the device you plug into the truck, and whats it actuall called.
    Thanks
  19. Aug 9, 2016 at 10:18 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    In the manual it says to keep it in "S4" instead of "D" when towing. Is that to keep it cool? I'm a towing newb.
  20. Aug 27, 2016 at 3:30 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Yes sir , sorry for the delay . You need 2 things , the app (Torque Pro) theirs a free version but the pro has alot more features and its only $5 , then the OBD2 Blue tooth scanner . Man I am serious anyone who isnt using this is crazy it is Awesome .
    https://www.amazon.com/gp/product/B00PJPHEBO/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    https://play.google.com/store/apps/details?id=org.prowl.torque&hl=en
    INFO :
    See what your car is doing in realtime, get OBD fault codes, car performance, sensor data and more!
    Torque is a vehicle / car performance / diagnostics tool and scanner that uses an OBD II Bluetooth adapter to connect to your OBD2 engine management / ECU
    Layout your own dashboard with the widgets / gauges you want!
    It can use the GPS to provide tracker logs with OBD engine logging so you can see what you were doing at any point in time
    It can also show and reset a DTC / CEL / fault code like a scantool. Helps you fix your car and helps keep repair costs down!
    Torque also features:
    * Dyno / Dynomometer and Horsepower/HP & Torque
    * Can read Transmission Temperatures (vehicle dependant)
    * 0-60 speed timings - more accurate than just using plain old GPS - see how fast your car is (or truck )
    * CO2 emissions readout
    * Customisable dashboard & profiles
    * Video your journey using the Track Recorder plugin with onscreen OBDII data overlay - a black box for your car/truck!
    * Automatically send GPS tagged tweets directly to twitter (for example if you are going on a road trip)
    * Massive fault code database for lookup of fault codes from different manufacturers
    * Theme support (choose from different themes to change the look of your dashboard)
    * Send logging information to web or email CSV/KML for analysis via excel / openoffice reader
    * Heads up display / HUD mode for night time driving
    * Compass (GPS Based) that won't suffer magnetic interference
    * GPS Speedometer/Tracking and realtime web upload capability - see what you were doing and your engine, at a point in time
    * Turbo boost feature for vehicles that support MAP and MAF sensors (VW & Golf / Audi / Seat etc supported)
    * Alarms and warnings (for example if your coolant temperature goes over 120C whilst driving) with voice/speech overlay
    * Car dock support
    * Graph data
    * MPG
    * Able to share screenshots to Facebook, Twitter, Google+, Email, etc
    * AIDL API for third party apps, A simple Telnet interface for developers to talk to the adapter, and an OBD scanner.
    * Works on tablet devices like the Motorola Xoom, Dell Streak, Samsung Galaxy Tab and Nook
    Works on any vehicle that uses the OBD 2 standard (most vehicles built after 2000, but can work for vehicles as far back as 1996) if in doubt check with your manufacturer first or look for 'OBD2' on written on a big white label in your engine ba
    Jaxn99, Yota303 and Okie like this.
  21. Aug 27, 2016 at 3:38 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    No dont do that , turn the tow mode on and let the motor and tranny do the work ;)
    astro-jason likes this.
  22. Aug 27, 2016 at 3:51 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Another trip in the bag OBX baby , what a awesome trip !!! Wild Horses , Lighthouses , 11 Miles on 4X4 Beach (had to drop it in 4 low lock once ) did I mention the OCEAN right :)
  23. Aug 27, 2016 at 4:02 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    This truck truly has been nothing but a blessing to us , It does what ever I need it to do and ask for more , thanks TOYOTA for building one tuff ass truck !!!!!!
  24. Aug 27, 2016 at 4:11 AM
    George14
    George14 New Member
    West Virginia
    2014 Tundra SR5 Dc TRD Off Road 5.7L with tow package
    None
    Nice looking rig
  25. Aug 27, 2016 at 4:40 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Thanks !!!
  26. Sep 9, 2016 at 5:58 PM
    Newsbear
    Newsbear New Member
    2016 Silver Toyota Tundra SR5 Access CAB
    Is there one of those Bluetooth devices for an I-phone?
  27. Sep 9, 2016 at 6:22 PM
    Newsbear
    Newsbear New Member
    I found one on Amazon but its says wi-fi. Will that work?
  28. Sep 22, 2016 at 7:24 PM
    Krohsis
    Krohsis New Member
    2016 Toyota Tundra SR5 CrewMax, 5.7L, Red
    Ok, we just bought a 2016 Tundra, trading in our 2014 Tacoma. Pretty disappointed in transmission temps on the new Tundra, and we haven't even towed yet. Temps just driving around town or cruising on the freeway run from 185-220*. Those are unacceptable temps for towing, not to mention just driving around. I appears the transmission has two systems for temp control of the trans. One is back at the tail of the trans, where engine coolant is used to control temps on the trans. Also, it appears the transmission lines run up to the A/C condenser, perhaps being used for both the A/C and the trans. The biggest problem I see with the system after a brief look is the use of engine coolant for temp control. If those lines are not controlled with a thermostat, hot coolant, 190-212* will be heating the trans fluid to that temp. So no cooling of the fluid will start until the trans fluid temp exceeds the water temp. Does anyone know if the water lines to this heat exchanger are controlled by a separate thermostat? Secondly I question how efficient the A/C condenser that shares double duty with the transmission is at cooling. The temp differential between the transmission torque converter, the hottest temp sensor to the pan temp sensor is about 15-20 degrees. My 2014 Tacoma had a large B & M cooler I put on it and the temp differential with it at those two points was 25-33*. So all in all I'm disappointed in this system. Does anyone on the forum work as a Tundra Mechanic, and can you enlighten us on this system? Has anyone put a supplemental cooler on their Gen 3 Tundra? Has anyone disconnected the engine coolant portion of the system and seen improvement of heat reduction? And finally, what kind of transmission temps are people seeing towing heavy, i.e in excess of 7000 lbs? Thanks guys!
    Johnsonman likes this.
  29. Sep 23, 2016 at 5:53 AM
    Ancient1
    Ancient1 New Member
    Tallahassee
    While driving my trans temp usually mirrors the engine temps. When stopped, in gear, the trans temp can go above 220. Placing it in park cools it back down.
    Tundras are well engineered with nearly bullet proof components but I'm not overly comfortable with the spikes in trans temps.
    Gear cruncher on TW is a transmission guru....he may be able to shed some light on the subject.
    Note: under hood temps often exceed 140, when stopped, and that may contribute.
    NewImprovedRon likes this.
  30. Sep 23, 2016 at 6:42 AM
    Kaerntner
    Kaerntner New Member
    2016 tundra sr5
    Wondered the same thing....maybe that's why the A/C doesn't really get cold enough?Will keep an eye on this thread
