Do these rotors look normal?
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra234, Aug 10, 2019.
  1. Aug 10, 2019 at 9:54 PM
    Tundra234 [OP] New Member
    I have a shimmy in the steering wheel when braking at speeds over 50 mph. I was rotating the tires and noticed the color pattern on the rotors. What do you guys think? These are Powerstops that have been on for about 6 years. My next step to look for warpage is to put the factory rotors back on.
  2. Aug 10, 2019 at 10:04 PM
    Put 3 lug nuts on, check for run out.
  3. Aug 10, 2019 at 10:06 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You have a hot spot. Something on your pad maybe causing irregular wear.
  4. Aug 10, 2019 at 10:07 PM
  5. Aug 11, 2019 at 6:06 AM
    This is both front rotors. I pulled the pads off but didnt see anything on them.
  6. Aug 11, 2019 at 6:09 AM
    I have one that i borrowed from a coworker. What is the best way to check runout since these are slotted and drilled? Also, what is the "out of limits" that indicate it should be replaced?
    Or could I use a digital micrometer?
  7. Aug 11, 2019 at 6:55 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    How much meat is on the pads?
    How does the back side of the rotors look?
  8. Aug 11, 2019 at 6:55 AM
    You can still check runout. Just keep the dial indicator out of the drilled holes. .002 is the limits.
  9. Aug 11, 2019 at 7:01 AM
    I would say about half of the pad is left. I will look at the back side today because I was curious as well.
  10. Aug 11, 2019 at 7:02 AM
    Thanks. I will check them out. Its just weird that its both front rotors with the hot spot.
  11. Aug 11, 2019 at 7:11 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    See if there are wear indicator tabs on your pads that line up with the stripe on your rotor. If they're bent a bit maybe they're dragging when you apply brakes.
    First I thought contaminant but seeing the same pattern on each side points to pads.
  12. Aug 11, 2019 at 7:23 AM
    The wear indicators aren't anywhere close to the rotor. On the pads that I have, the indicator is on the edge of the pad but the hot areas appear to be in the middle of the rotor?
  13. Aug 11, 2019 at 7:59 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Not trying to be negative, but I wouldn’t even waste my time to check that shit. Throw it all in the trash and start over with some new rotors and pads..
  14. Aug 11, 2019 at 9:53 AM
    Lee's rig
    Lee's rig Party naked
    Lee
    North nj
    2014 DC and 2014 single cab both 8' bed with 5.7
    To many
    had the same problems with my 2014 single cab. toyota could not fix and in fact crashed my truck and denied it. corporate did nothing.
    look up. " help me howard east coast toyota"
    and i agree with above post. just put all new on and be done with it.
  15. Aug 11, 2019 at 10:53 AM
    Like Jeremy suggested, you have 6 years on those rotors. Pretty good in my opinion. I would probably just replace rotors and pads, rebuild calipers as needed.
    At some point, maybe you had the front rotors pretty hot from something. At least both sides are showing signs of heat/wear evenly.
    Something else to check out when doing brakes. Check run out on the bearing hub when the rotor is off. This is 99.9% probably not your issue, but in the future if there is one side of a vehicles brake system giving you problems, check the bearing hub assembly.
    TheBeast and jeremyd[QUOTED] like this.
  16. Aug 11, 2019 at 11:32 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Make sure all the brake “rub” surfaces are clean and slightly lubed with a light coating of grease. Check the pins too. Clean and lube with grease. The pads my not be releasing fully and dragging after the brakes are released. Hope this helps.
  17. Aug 11, 2019 at 11:48 AM
    TheBeast The Beach
    you got 6 years out of the powerstop. that's good imo. my stock ones didn't last 4 years...
  18. Aug 12, 2019 at 8:03 PM
    So after digging in a little, this is the Z23 kit and it is 3 years old this week. Since I am running 34's now, should I replace them with the Z36 kit?
