Do I really need to get 10 ply tires?
Discussion in 'Wheels & Tires' started by Field Walker, Dec 2, 2018.
  1. Dec 2, 2018 at 9:17 PM
    Field Walker
    Field Walker [OP] New Member
    Ben
    New Mexico
    2018 SR5
    I’ve been looking at replacing my factory H/T tires. I do not see many load range “D” tires for 18” wheels. My primary use of the truck is running down farm roads while I check crops and Do some desert desert driving while hunting quail in the fall. Will load “C” do or should I just get the 10 ply? Don’t plan on hauling much with the truck, having a hard time seeing the need for the 10 ply.
  2. Dec 2, 2018 at 11:13 PM
    Load Range C exceeds your load and towing capacity. Should be good to go. The C will be better off-road as well.
    This is one of the only complains I have with the Tundra tire sizing. Very difficult getting anything else but a P Metric or LR E tire.
    If you ever wanted to change wheel/tire sizing, great time to do it. A 265/70/18 is a very common tire size, or go with a 17” wheel. That opens up the doors a bit for sizing.
    T-Rex266, Sunnier and Watt maker like this.
  3. Dec 3, 2018 at 10:43 AM
    WaTrout88
    WaTrout88 Toyota Family
    Ben
    Spokane, WA
    1978 FJ40, 2002 Tundra TRD, 2018 Tundra
    2002 Toyota Tundra - Billy's 5100 2nd Notch, 285/75/16 OEM Wheels + 1.5" Spacers, Archive Garage HD Leaf Springs, AG Bump Stops, Freedom Offroad UCAs, ARB Coil Springs 2887
    I just bought some 285/75/16 BFG KO2s, they only offer them in E and man they ride are lot stiffer than my previous tires. If they still offered a C, I would have gotten that instead.
    ColoradoTJ likes this.
  4. Dec 3, 2018 at 10:50 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    You Will hate E, they ride stiff even on these trucks even at 35psi. If you dont need the rating, IMO dont do it!
    Edit - i was running E in 285/75/17 Cooper AT3
    15whtrd and ColoradoTJ like this.
  5. Dec 3, 2018 at 11:14 AM
    WaTrout88
    Ben
    Spokane, WA
    @14burrito It would be tough to go back now but who makes a good AT similar to the BFG w/o the E rating?
    15whtrd likes this.
  6. Dec 3, 2018 at 11:21 AM
    Quebec
    Quebec New Member
    Keep in mind not all 10-ply/E rated tires ride the same.
    The Toyo OC AT2s I have in 285/75R17 are vastly stiffer and uncomfortable compared to my Yokohama GO15s in 285/75R17 which are a pleasure.
    Both same size. Both 10-ply.
    The GO15s are so nice I bought a 2nd set in 285/75R18.
  7. Dec 3, 2018 at 11:32 AM
    Load Index rating, and you are so correct.
    Watt maker likes this.
  8. Dec 3, 2018 at 11:50 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    What size do you need?
  9. Dec 3, 2018 at 11:51 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I gotta say though, IMO (while they are labeled ATs), those are two very different tires.
  10. Dec 3, 2018 at 12:35 PM
    15whtrd
    15whtrd Mr. Blonde
    This is my problem and why I don’t want to jump to a bigger tire. I don’t need E rated tires. But I feel that my P rated tires are probably more subject to puncture’s while offroading. I haven’t had it happen but I do like the way they ride. I think a C rated tire would be right up my alley. But I can’t find any. So instead I look for how heavy every tire I search for, will be. So far the Nitto Terra grappler‘s seem to be the lightest E rated 10ply tire that I can find. 52 pounds in 275/70/18
    ColoradoTJ and Watt maker like this.
