Do I need tow mirrors?
Discussion in 'Towing & Hauling' started by HappyCamper7424, Oct 16, 2020.
  1. Oct 16, 2020 at 12:41 PM
    HappyCamper7424
    HappyCamper7424 [OP] New Member
    I plan to buy a '21 in the next few months to use as a tow vehicle for a new travel trailer. The travel trailer would be at least 22' but not more than 25' long. Some models that I'm looking at are only 7' wide. What is everyone's opinion about the need for tow mirrors for a trailer of that length and width?
  2. Oct 16, 2020 at 12:47 PM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Couldn't hurt. I don't think anyone could argue the extra visibility is a plus even for a smaller trailer. Mine is 24" an 8 ft wide. I started with some cheap clip ons to get by. But they vibrated horribly. Was lucky to get some OEM style tow mirrors off a buddy for 20 bucks. It was the best 20 bucks I've spent on the truck. If you plan to tow more then a couple times a year I think it's worth the investment.
  3. Oct 16, 2020 at 2:17 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  4. Oct 16, 2020 at 2:19 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I have a similar sized trailer and installed towing mirrors. They are great when you are towing, they are terrible the 300 other days a year. I swap mine on and off for my summer towing season and suddenly my world is better.
    johnnyv5 and frichco228 like this.
  5. Oct 16, 2020 at 2:29 PM
    I had tow mirrors on my 07. I don't tow much but I miss the tow mirrors. I plan on putting a set on my 14. Not a fan of the smaller mirrors. :lalala:
    YeeYeeTundra and Cpl_Punishment like this.
  6. Oct 16, 2020 at 2:41 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Just my experience on vehicles with tow mirrors- they are GREAT for towing. If you are not towing then they have some pretty bad blind spots to the point of being a little sketchy. So just like anything you change from stock- lift, wheels, big tires, tow mirrors- there are trade offs and benefits.
  7. Oct 16, 2020 at 2:43 PM
    Interesting, I find the opposite to be the case for me.
    Tracy Perry likes this.
  8. Oct 16, 2020 at 2:50 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My trailer is 20x7.5 wide. I don’t “need” tow mirrors, but i really want to add them for safety
    Black Wolf likes this.
  9. Oct 16, 2020 at 3:10 PM
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    GODZILLA and mountainpete like this.
  10. Oct 16, 2020 at 3:29 PM
    I am considering something similar. Have you had any issues with rub/wear marks on the mirrors where these clip on?
    TTund16 likes this.
  11. Oct 16, 2020 at 3:39 PM
    danno266
    danno266 n00b
    My mirror caps are black, and these do go on pretty tight, I start at the top and get them hooked, then spread just a little to get over the bottom and push to clip them on. They certainly aren't going anywhere, and the vibration really isn't too bad. I haven't noticed any scratching or scarring. This is my second summer with them, so I've put em on and off about 5 or so times.
    TTund16 and GODZILLA[QUOTED] like this.
  12. Oct 16, 2020 at 3:51 PM
    mountainpete
    I also have a set of these. I put a piece of bicycle inner tube to prevent any marks. Zero issues.
    Tow mirrors are much better than the clip ons, especially on the passenger side, but they are 70% as good for 20% of the cost.
    TTund16 and 2018TundraLimited like this.
  13. Oct 16, 2020 at 3:55 PM
    danno266
    danno266 n00b
    I couldn't commit to the semi-permanent tow mirrors. Getting in and out of the garage is important to me. It's already tight and I've rubbed at least once with the factory mirrors :frusty:
  14. Oct 16, 2020 at 3:58 PM
    mountainpete
    Power folding upgrade! I did that with my regular mirrors and it’s glorious.
    danno266[QUOTED] likes this.
  15. Oct 16, 2020 at 4:19 PM
    I've had lots of experience with tow mirrors, but I don't tow often enough to warrant the permanent swap. I also don't care for them aesthetically on the Tundra.
  16. Oct 16, 2020 at 8:43 PM
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    I recently put on some tow mirrors from Boost, and I can tell you I love them. I tow my 26' long, 7' wide Micro Minnie and they made a big difference. Contrary to the lack of visibility comment above, I have the opposite experience; I find I get lots more visibility with them and love just driving around with them. I will concede there is a larger spot blocked in FRONT of you from the size of the mirror, but it's not sketchy or anything once you get used to it. I also upgraded to power folding and that makes tight spots fine. I like the boost mirrors way more than the Tundra ones, and you can upgrade later, so I wouldn't let it hold you back from getting a truck that doesn't have them if you decide you do want them. I installed myself and it wasn't the most difficult thing I've done on the truck at all.
    Do you NEED them? No - I towed my 7' wide trailer without them, but the first time towing yesterday with them was a significant improvement.
  17. Oct 17, 2020 at 4:15 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    Tow mirrors make your truck faster and they look more manly.
  18. Oct 19, 2020 at 6:31 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
  19. Oct 19, 2020 at 9:21 AM
    Ah. I see. So they're like truck nuts hanging off your hitch?
    JLS in WA, TTund16 and Cpl_Punishment like this.
  20. Oct 19, 2020 at 9:33 AM
    mountainpete
    Unless you offroad in areas with heavy trees and the branches get caught in that hole in the arms and then twist and smack back.
    Did I mention I swap my mirrors back and forth? :bananadance:
    JLS in WA likes this.
  21. Oct 19, 2020 at 9:37 AM
    Fishhead
    Fishhead New Member
    I tow my wife's horse trailer a lot while my wife tows our travel trailer. As said above, while towing, I really do like towing mirrors. If I didn't tow a lot I would switch back to the stock mirrors.
    I also tow a 21 foot bass boat and honestly, it doesn't really matter for it either way.
  22. Feb 7, 2021 at 4:49 AM
    Hawkdriver19
    Hawkdriver19 New Member
    2017 CrewMax SR5 4WD White w/ XP Blackout kit
    I am going to be taking my family on a cross country adventure, moving from Alabama to Alaska in a few months. I’ll be towing a uhaul 6x12 double axle enclosed trailer. With a trailer this size, does anyone recommend tow mirrors or should I be fine without them?
  23. Feb 7, 2021 at 5:05 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    I towed the exact same (U-Haul?) trailer across the country a couple of years ago when I moved from NJ to AZ with a 2008 4Runner, which is narrower than a Tundra. No problems seeing behind me at all. That trailer at 6 feet is narrow enough.
    Cpl_Punishment likes this.
  24. Feb 7, 2021 at 5:27 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    You should be fine with standard mirrors.
  25. Feb 7, 2021 at 6:13 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    how much more do the tow mirrors stick out vs stock mirrors?
  26. Feb 7, 2021 at 6:39 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I rented a 5x10, if I recall correctly, and it was so narrow that I couldn't even see it in the mirrors. I suspect you'll probably be ok without for a 6 foot wide trailer.
  27. Feb 7, 2021 at 6:40 AM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
  28. Feb 7, 2021 at 6:46 AM
    Hawkdriver19
    Thanks for all the input! We towed a 29’ TT a few months ago, just to get away from everything during the height of unrest/uncertainty due to covid and the election. That was uncomfortable with the standard mirrors, to say the least. I was hyper-sensitive to being able to see while towing, but feel much better about the small size trailer and the comments.
  29. Feb 7, 2021 at 6:49 AM
    Hawkdriver19
    MaxYota, thanks for the suggestion. I like the new design with taller convex portion. How hard was it to remove the factory mirror from the housing?
  30. Feb 8, 2021 at 10:08 AM
    MaxYota
    Murf
    MS Gulfcoast
    It was an easy push/pop up then unplug the old and plug in the new(I believe I put the left wire to the top pin of the new mirror) then a hefty pull down/pop to install. Took about 10 minutes to do both.
