Do I have a problem with my Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by gdiep, Nov 29, 2016.
  1. Nov 29, 2016 at 8:15 AM
    gdiep
    gdiep [OP] I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    When the Tundra is running, I can smell some type of "burning" smell from near the front passenger side wheel well. It smells "hot" like something burning.
    This doesn't appear to be normal to me, but I'm not sure. And there are no CEL's.
    What do you guys think?
    2014 Tundra CM 5.7l with approx. 21000x
    I just bought this about 2 months ago and have always had this since I bought this.
  2. Nov 29, 2016 at 9:47 AM
    TheBeast The Beach
    maybe mouse nest or some kind of debris in the engine compartment ?
    also did you install a new exhaust by any chance ?
    ColoradoTJ likes this.
  3. Nov 29, 2016 at 9:52 AM
    Crewmax Chris
    Crewmax Chris Paper Airplane Enthusiast
    Lewiston, ME
    2013 Tundra SR5 DoubleCab
    Possible something found it's way between the rotor and caliper?
  4. Nov 29, 2016 at 9:54 AM
    gdiep
    Syracuse, New York
    I'll take a good look around the engine compartment. Nothing related to the brakes, because it smells hot when I start the car and leave it idling.
    Crewmax Chris likes this.
  5. Nov 29, 2016 at 9:57 AM
    Crewmax Chris
    Lewiston, ME
    Does it smell like hot metal or something like a plastic piece against a hot part of the engine that is out of place?
  6. Nov 29, 2016 at 9:58 AM
    gdiep
    Syracuse, New York
    Exhaust is stock.
  7. Nov 29, 2016 at 9:58 AM
    gdiep
    Syracuse, New York
    Smells like something burning or melting, but I've looked and haven't seen anything obvious.
  8. Nov 29, 2016 at 10:02 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Oil leak? You're going to have to stick your head in there and look around.
    NewImprovedRon likes this.
  9. Nov 29, 2016 at 10:03 AM
    TheBeast The Beach
    if you have a leaf blower..just blow air in the engine bay to remove any debris....I do it once a month
    AnonVet and thumper7799 like this.
  10. Nov 29, 2016 at 10:04 AM
    gdiep
    Syracuse, New York
    I don't think so, as I've not noticed any oil on my driveway.
  11. Nov 29, 2016 at 10:04 AM
    gdiep
    Syracuse, New York
    Good idea.
  12. Nov 29, 2016 at 10:08 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It could be burning off. Either way, you're going to have to stare at it in order to determine the cause.
  13. Nov 29, 2016 at 10:13 AM
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    Does it have seat heaters?
  14. Nov 29, 2016 at 11:00 AM
    gdiep
    Syracuse, New York
    No seat heaters.
  15. Nov 29, 2016 at 11:02 AM
    Maybe something got into headers area??? Debris of some sort or something came loose touching them
  16. Nov 29, 2016 at 11:14 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Like the other said, you may need to get up close and personal down there to narrow it down. Too hard to tell with that info alone, but I wonder if something blew up from the roadway, like a plastic bag or something, that is causing it.
    Good luck!
    JBSTOY, driverdog and NewImprovedRon like this.
  17. Nov 29, 2016 at 11:15 AM
    gdiep
    Syracuse, New York
    It smells like that at idle, right when I start the truck in the morning without driving it.
  18. Nov 29, 2016 at 11:19 AM
    cdkenne
    Corey
    KS
    Depending on date of first use, it should still be under 3/36 warranty.
  19. Nov 29, 2016 at 11:22 AM
    gdiep
    Syracuse, New York
    No wiring work done recently, other than retrofit headlights. However, this started before the retrofits. I am under warranty still, but wanted to understand this first before taking it to the dealer (first to eliminate any simple issues like burning debris, then to point the dealer to the problem in case they are not all that interested in diagnosing the problem).
    Crewmax Chris and NewImprovedRon like this.
  20. Nov 29, 2016 at 11:26 AM
    cdkenne
    Corey
    KS
    The only burning smells I've dealt with on a vehicle with that low of miles (besides cam cradles) are seat heater controllers burning up and dust in the vents when the heater is first turned on for winter.
  21. Nov 29, 2016 at 12:47 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    I had one of those plastic grocery bags hit my exhaust on my last truck - ran over it on the highway and thought it was gone. Guess again...it immediately stuck to the head pipe, and where the tail pipe goes over the rear axle. I didn't know what it was for a while because it smelled like burning brakes or petroleum/asphalt type of a smell and not really a plastic smell. After a lot of looking around, crawled under the truck to see it and then used a heat gun to melt it and paint scraper to peel it off. Could be something like this - even after scraping it off, it took a while for the smell to go away.
    JBSTOY, Tomcat, driverdog and 2 others like this.
  22. Nov 29, 2016 at 12:50 PM
    TheBeast The Beach
    my thoughts too
    MotoTundra likes this.
  23. Nov 29, 2016 at 12:56 PM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Could you use a infrared thermometer and see what areas are getting abnormally hot and then diagnose from there? Just an idea?
    Tomcat likes this.
  24. Nov 29, 2016 at 1:53 PM
    gdiep
    Syracuse, New York
    All great ideas guys. I'll make sure I check it out thoroughly this weekend. By the time I get home from work during the weekday, it's pitch dark. I think I have a better chance of spotting something in the daylight.
  25. Nov 29, 2016 at 3:20 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Keep us updated!
    driverdog likes this.
  26. Nov 29, 2016 at 3:57 PM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    I drove over a plastic grocery bag on the road once and it flew up and melted to me exhaust. Took a long time to burn completely burn off even after scraping it off. Just a thought...
    Tundraplatinum likes this.
  27. Nov 29, 2016 at 5:50 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Very common see this all the time at the shop, they smell horrible and stay there forever. usually take a die grinder and sand them off
    cdkenne likes this.
  28. Nov 29, 2016 at 6:54 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Were there any issues with the Cam Towers leaking on the 14s, or was that issue resolved by that model year?
    Marty McFly likes this.
  29. Nov 29, 2016 at 7:04 PM
    Some 14's had the cam tower leak. I was thinking this may be OP issue ...but I just let it be.
    Wynnded and BlueFalconActual like this.
  30. Nov 29, 2016 at 7:10 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Sean beat me to it.
