Do I care if exhaust leak before muffler?
Discussion in 'Performance and Tuning' started by Berettafan, Sep 23, 2017.
  1. Sep 23, 2017 at 8:11 AM
    Berettafan
    Berettafan [OP] New Member
    2017 CM
    Swapped from trd back to stock exhaust on my 17 and discovered leak at joint before muffler. Can this damage anything?
  2. Sep 23, 2017 at 9:17 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    It won't damage anything. Do you feel air coming out or just condensation? If only condensation don't worry about it. The factory clamp sucks, if you play with it you might be able to get a better fit. I installed an aftermarket v band clamp and it seals much better. You don't have to, I'm just anal like that..
  3. Sep 23, 2017 at 9:18 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I'm not sure about your state, but where I live if exhaust leaks from anywhere upstream of the outlet it's an immediate emissions fail.
    4x4_Angel likes this.
  4. Sep 23, 2017 at 9:22 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    It will damage your mpg. It's a hassle, but it's worth it to figure out why it's leaking and to fix it.
    ColoradoTJ, GNTundra and Backslider like this.
  5. Sep 23, 2017 at 9:42 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Berettafan disregard my post! I thought it was after the muffler that was leaking. That clamp I spoke about is for the tail pipe. Try loosening all the bolts, moving the pipes around then tightening all the bolts little by little. Maybe the gasket fell off?
  6. Sep 23, 2017 at 9:45 AM
    Berettafan
    2017 CM
    Thanks al. I reused the gaskets so I'm guessing that's it. Will pick new ones up at parts store and do it right.
    ColoradoTJ likes this.
  7. Sep 23, 2017 at 12:02 PM
    Good choice. A leaking exhaust can poison you as well. (CO poisoning)
  8. Sep 25, 2017 at 4:28 PM
    Berettafan
    2017 CM
    All fixed. Napa had gaskets in stock. Only one pipe was leaking but I replaced both gaskets since both pipes had to be separated. Easy job, didn't have to fool with hangers.
    BlueBottle and Backslider like this.
  9. Sep 25, 2017 at 4:29 PM
    Berettafan
    2017 CM
    They also had a gasket for the rear clamp part. Bought that but don't feel any leak there so I'll just hold it for a while.
    BlueBottle likes this.
  10. Sep 25, 2017 at 4:58 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Is the gasket paper too? I’m loOkig for a metal one w no luck.
  11. Sep 25, 2017 at 6:21 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Funny enough, I just fixed the same issue. Autozone had metal gaskets where I am at. I ended up ordering the replacement gaskets from vendor on Amazon though. Just put them in today, sprayed the flanges with soapy water to see if it was leaking and it is not. I am hoping this will make my aftermarket exhaust sound batter as well. Perhaps I will get more power or better MPG, unlikely but you never know. Here is the link for the gaskets I bought:
    https://www.amazon.com/gp/product/B00FWPEW9I/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
  12. Sep 25, 2017 at 7:10 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Berettafan
    I’m curious why you returned your exhaust to stock?
  13. Sep 26, 2017 at 12:31 AM
    Berettafan
    2017 CM
    Blue the rear gasket is metal and kind of ring shaped. Clamp seems to be doing its job fine tho. Didn't use the soapy water trick, just put my hand near each joint.
    It does sound a bit quieter now that it's fixed.
    Go solo I swapped back for two reasons. Firstly I was becoming convinced I lost some bottom end power with the pro setup. Secondly the sound is nice but I don't always want it there. About as mellow as can be really but I personally only wanted to hear the growl at startup and on wot.
    Pbed85 likes this.
