Do cooled seats really work ?
Discussion in 'General Tundra Discussion' started by str8upballin, Feb 9, 2020.
  1. Feb 9, 2020 at 2:21 AM
    str8upballin
    str8upballin [OP] New Member
    I ordered the Katzkin leather with heat but may have time to switch my order to have the drivers side have the heat and cooling. What’s the verdict on cooled seats, is it with it, do they really make a difference. ?
  2. Feb 9, 2020 at 3:15 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    My wife has OEM heated and cooled seats in her Highlander which are awesome, they're on my list for my next truck.
    KarmaKannon and SIMPLYTHETRUTH like this.
  3. Feb 9, 2020 at 3:23 AM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    Not on the yodas, really don’t feel it as far as factory seating compared to others. Toyota a little behinds technology. Maybe on the new generation will be different....so to answer question
    Op1.. try it on drivers side before buying all, should have a warranty or refund don’t like.
    Op2.. just leather everything without all extra bologna.
    Op3.. leave it alone and wait and see what the new gen of the Tundra brings out with the technology now, because they sure already have the reliable patted down. Now for the technology which Toyota is lacking, compared to others. Good luck On your decision.
  4. Feb 9, 2020 at 3:30 AM
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
    On the highlander you do feel them but compared to others they take time to get the cool or heat you want. Also seems like not vented enough or designed right, Toyota is a little behind there technology. But made soon all will change!!!
  5. Feb 9, 2020 at 4:04 AM
    MT Madman
    Hawk Point MO
    They seem pretty quick to me, the cooling is actually a fan blowing on your butt and back, a good way to 'share', and the heat I can't really tell you because like leather in my tundra and only use the heat until the cab starts warming in the winter but the cooling would be nice on long trips.
  6. Feb 9, 2020 at 2:34 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I find the factory cooled seats work about meh at best. If you switch the A/C over to where the output is split between the dash vents and your feet, so that it blows some cold air under the seat, then the fans suck up some of that cold air, instant improvement to what it should be. I'm sure this would be the same with a katzkin kit.
  7. Feb 9, 2020 at 2:37 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    The degreez actually cool the air (using a peliter device) it blows on the seat. My buddy's raptor has the cooled seats, and its really nice.
  8. Feb 9, 2020 at 2:47 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    They do leave something to be desired when it’s roasting outside and you expect your ass and back to be frozen quickly, but I’ve heard aftermarket ones are better powered. What I’ve (accidentally) found is that the cooling is much more noticeable when you accidentally leave it on in the winter time. That’s when my ass gets froze and I start wondering wtf is going on and realize what’s happening. I then have a renewed sense of appreciation for their power. Get them, you’re going though all this work anyways...
  9. Feb 11, 2020 at 6:25 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    loved them on my genesis.....
  10. Feb 11, 2020 at 7:08 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Heated seats are so Awesome to keep food 'piping' hot on the way home, woohoo!
  11. Feb 11, 2020 at 7:28 AM
    TacomaLC
    TacomaLC New Member
    Chip
    T-town
    2020 Tundra Voodoo 2000 Tundra LTD Red (rest in pieces)
    Cooled seats work great! Only on the Platinum and 1794 Editions I believe.
  12. Feb 11, 2020 at 8:21 AM
    I havent tried them on a Tundra, but a Ford Explorer, and Chevy Tahoe. They worked great!
  13. Feb 11, 2020 at 8:26 AM
  14. Feb 11, 2020 at 8:54 AM
    gm125800
    gm125800 New Member
    2018 GMC Sierra Denali
    They're average at best. The ones on our expedition start cooling fairly quickly. i get it that they are not truly air conditioned but it helps regardless. The ones on the Tundra cooled, they just took a little longer.
    This was on a 2017 1794 Crewmax i had years ago.
  15. Feb 11, 2020 at 9:20 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Let's make sure we are clear on what is on Toyota's.....
    They market them as cooled, but all it is is a fan in the seat blowing air. If you get in a hot truck in the summer and the cab is 100 degrees, it is blowing that air through the seat.
    I have to be honest, they do not cool at all and are pretty much useless. We have them on my Platinum and 17 4Runner and you can not even tell they are on.
    Other manufacturers have actual air conditioned seats. Those work great! I have ridden in some GMC and Fords with those features and they really work well.
    If cooled seats are a draw in buying a Tundra you are going to be severely disappointed.
    SIMPLYTHETRUTH likes this.
  16. Feb 11, 2020 at 9:22 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    I used a different approach then having cooled seats. My truck an SR5 didn’t have it. I ended up removing my tint and replaced with ceramic tint. My truck now on 100 degree plus days have a temp inside the truck at about 70 degrees. I ended tinting all the windows including the windshield.
  17. Feb 11, 2020 at 9:25 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    Actually Fords and Chevy’s are fans as well on the seats. The only manufacturers I’ve seen actual ac seats with ducts have been on Mercedes and BMWs. Primarily their upper end vehicles.
  18. Feb 11, 2020 at 9:25 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I haven't tried the cooled seated; but my heated leather seats are awesome in my 2020 Pro. It doesn't get crazy cold out here so I've only used them a couple of times when it's been in the 30s when I leave for work in the morning - but my wife always turns the passenger side one on, she says it helped relax the muscles in her back while she was pregnant. I saw a couple of people say they didn't notice the heating, but I definitely did, and it works fast, within a minute or two my buns are getting toasty.
    This is a damn good idea, I wish I would have used it for that sooner!
  19. Feb 11, 2020 at 9:32 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    When we had my expedition with the cooled seats option. It worked better if the AC was blowing on the floor vents. But after a while even on hot days it did very little to cool you down. Unfortunately I don’t think they use enough fans in the seat. Think about it a small person and large person are going to feel different in those seats anyways. Might work for some but not others.
    Funny thing though, My old man has a 18 Mercedes S class. His AC seats will definitely freeze your balls off. Not to mention you can a massage when driving down the road. We did a 18 hour consecutive road trip on that car. Normally in any other vehicle I would be tired and beat up. This car I was tired, but not beaten up and no sore back. Wish I could say the same for my Tundra...:D
  20. Feb 11, 2020 at 9:54 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    Cooled seats are definitely nice. My platinum has them. Although I haven't tested them out in the summer yet because I haven't had the truck for that long, they definitely cool my ass off after I leave the gym. I notice it almost as soon as I turn them on. This is my first vehicle with them and have to admit that I never knew I wanted it until I had it.
  21. Feb 11, 2020 at 10:05 AM
    CTPlatinum
    CTPlatinum New Member
    2020 Tundra Platinum 4x4
    None Yet
    Couldn't disagree more! The Heated/Cooled seats in the 2020 Tundra Platinum are awesome in my opinion, they are every bit as nice as any comparable Ford, Chevy, Ram, etc.
  22. Feb 11, 2020 at 10:22 AM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    I have the Katzkins with heated and cooled seats. The heater works great but the a/c seats aren’t that great. I have a 20 minute commute and they barely start working just a few minutes from the house. Another complaint is the fans are louder than I’d like.
    For comparison I’ve had a/c seats on several fords and my brother in laws ram. All of them were 100% better than the Katzkins Degrees. Just my opinion but I feel like I would have been just as happy with heated only
  23. Feb 11, 2020 at 10:22 AM
    WestexSBK
  24. Feb 11, 2020 at 10:42 AM
    TacomaLC
    TacomaLC New Member
    Chip
    T-town
    Actually, They are marketed as "heated/Ventilated" which is much different than cooled. I find them to be effective. Not as effective as my Land Cruiser, but effective. YMMV.
  25. Feb 11, 2020 at 2:23 PM
    Breathing Borla
    Northern Illinois
    my heated seats work good
    the whole vented thing, not so much, Toyotas suck at this.
    my ram the venting worked really well, you cant even really tell mine are on in my platinum tundra
  26. Feb 14, 2020 at 7:00 PM
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
    Mercedes is the top dog all around when it comes to technology. Shit they have a bus that can drive itself. But the Mercedes truck upload_2020-2-14_21-49-5.jpg
    this thing would be a beast to all makes and put everyone to ashamed. But I guess if you have the money nothing matters. But I guarantee you if you have the money you still want more. I’m just happy I have a somewhat reliable truck that’s not a Ford,Chevy,Dodge, or what else. I’m happy with my 4.6 Tundy that gets 20mpg plus I can still smoke the shit out of tires and pull the shit I need. So basically what I’m saying is that Toyota with or with out all the fancy shit that’ll break when warranty runs out, is still the number 1 truck in my book. And they came along way from the 1st T100 Tundy.
