DMX1057XR Question
Discussion in 'Audio & Video' started by Acjb2021, Oct 11, 2021.
  1. Oct 11, 2021 at 8:46 AM
    Acjb2021
    Acjb2021 [OP] New Member
    For those that have added this receiver and had the JLB system, is there anything in the menu or preferences options on the OEM head unit you lost that you wish you still had? Like any of the custom settings? I have a platinum and was curious on this as I know there is things you get 3-5 years of that you might lose or there maybe things you can set up on the OEM unit that may not be on the Kenwood. I am just getting acquainted with the thought of changing, but I can attest the stock unit sucks.
  2. Oct 12, 2021 at 8:27 AM
    liddown
    liddown New Member
    David
    AircareTundra likes this.
  3. Oct 13, 2021 at 9:09 AM
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    1037s and RR2 here... All the menu functions for vehicle settings are still there. Remote start still works, Toyota SOS works, Android app still works. Lost nothing, got a better head unit.
  4. Oct 13, 2021 at 9:15 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome
  5. Oct 13, 2021 at 7:02 PM
    Tundrafan23
    Tundrafan23 New Member
    I have a 2020 Platinum and I lost ZERO functionality after adding the 1057xr, I also absolutely love the new radio and audio system.
  6. Oct 16, 2021 at 7:47 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Same here...I love the 1007 well worth adding Nav in my opinion.
  7. Oct 27, 2021 at 1:42 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    I wish I could get my texted messages thru it without having AA on
  8. Oct 27, 2021 at 1:51 PM
    liddown
    liddown New Member
    David
    Instead of AA can you just bluetooth connect your phone?
  9. Oct 27, 2021 at 3:30 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    It's is and I still don't get the texts notifications
  10. Oct 27, 2021 at 3:36 PM
    DerfM
    South Dakota
    2021 TRD Pro MBM
    Do you get phone calls via BT? IF not, you probably have only music connected and not phone. Android allows for either or both. I intentionally don't connect the phone portion to BT.
  11. Oct 28, 2021 at 5:23 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    I get phone calls, music, an address book. I have check all the phone settings and head unit settings So I guess it doesn't have the ability to receive texted messages.
  12. Dec 24, 2021 at 6:32 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
  13. Dec 25, 2021 at 2:02 PM
    boostedtrdpro
    Jeremy
    Also, does anyone know if the DRV-A601W 4K camera or the DRV-A501 is compatible with the 1057 or the 1007? Seems like all they list is the N520 camera for these radios? I wanted something nicer with more memory card capacity…
  14. Dec 26, 2021 at 1:57 PM
    DerfM
    South Dakota
    2021 TRD Pro MBM
    You cannot use the factory microphone without cutting the amplifier to that microphone. I ran mine out the back of the radio, through the driver's side dash, up the driver's side A pillar where I attached it to the head liner in the upper corner of the glass. It's not in an obvious spot and has worked really well for me so far. Visor doesn't get it it's way there either.
    I didn't buy the SirusXM tuner, but yes, you would need to buy that tuner also. There is an addon module for the kenwood radios to take care of that for you.
    I have the 1037s which is basically the same as the 1057.
    boostedtrdpro[QUOTED] likes this.
  15. Jan 8, 2022 at 2:29 PM
    boostedtrdpro
    Jeremy
    Swore I had everything needed here to install this, but I’m missing how to retain the factory FM antenna here. Did I miss ordering an adapter?
  16. Jan 8, 2022 at 2:31 PM
    liddown
    liddown New Member
    David
    Here is what you need... https://www.crutchfield.com/product/item/default.aspx?i=12040LX11
    If your tundra model years falls with in the 2009 and up...
  17. Jan 8, 2022 at 2:35 PM
    boostedtrdpro
    Jeremy
  18. Jan 8, 2022 at 2:41 PM
    AircareTundra
    AircareTundra New Member
    JT
    Not sure where you are located but I took mine to Sound of Tri State in Dover DE for the install/replacement etc...etc....
    Love it. Looks great. Sounds fantastic. Yes I still have blue tooth through the android, can use my map on the phone and it would show up on screen if I opted to do that too, still has the backup camera on the screen, and still has Sirius.
    Was pricey as they replaced every factory speaker and put the JL audio sub specific for our Tundra crew max in, an amp for the four main door speakers and the sub, and the inline extras to retain steering wheel controls etc...etc...etc....
    But we'll worth the coin if you ask me.
    Added bonus on this Kenwood is I can still rock some old school CDs.
  19. Jan 8, 2022 at 2:43 PM
    boostedtrdpro
    Jeremy
    Best Buy FTW! Thanks again @liddown
  20. Apr 21, 2022 at 8:53 PM
    Martin78
    Martin78 New Member
    Martin
    2012 Tundra
    Lift
    I just purchased my truck and it had a Kenwood DMX 1037S installed. However, the microphone doesn't work when I make a phone call. I can hear the person on the other end but they can't hear me. Is it a simple setting change or am I missing something?
  21. Apr 21, 2022 at 8:56 PM
    someguyinhtx
    someguyinhtx 2018 Lifted 4x4 CM
    Lifted 2018 Black 4x4 SR5 Crewmax
    6" Pro comp lift
    You need the mic installed and plugged in.
    Martin78[QUOTED] likes this.
  22. Apr 21, 2022 at 8:58 PM
    someguyinhtx
    6" Pro comp lift
    The only thing you lose is the the gps info on the gauge cluster’s multi screen. I thought music would go too, but the RR2 does a nice job and all of that info comes over.
  23. Apr 21, 2022 at 9:17 PM
    Martin78
    Martin78 New Member
    Martin
    2012 Tundra
    Lift
  24. Apr 21, 2022 at 9:19 PM
    Martin78
    Martin78 New Member
    Martin
    2012 Tundra
    Lift
    I looked through the box and found the mic. I'll give it a try. Thank you.
    someguyinhtx likes this.
  25. Apr 22, 2022 at 10:55 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Did you ever hook up an HDMI cable to the back of the unit? Heard two things the newer cables won't work and you have to disconnect carplay to get it to work???
