DMH-WT8600NEX - Maestro RR questions
Discussion in 'Audio & Video' started by Hookee, Sep 10, 2021.
  1. Sep 10, 2021 at 7:14 PM
    Hookee
    Hookee [OP] New Member
    2016 Toyota Tundra
  2. Sep 10, 2021 at 7:31 PM
    rcjh0891
    rcjh0891 New Member
    Joel
    DFW
    2018 Tundra Platinum Crewmax 4x4 MGM
    I don’t recall it’s been a while since I hooked mine up and I had similar questions. I would suggest calling crutchfield since you got the ready harness like I did. They are very helpful. The Maestro should have came with a schematic that should help too.
  3. Sep 10, 2021 at 10:28 PM
    Hookee
    2016 Toyota Tundra
    I got her all figured out and works perfect.
  4. Sep 11, 2021 at 4:29 AM
    rcjh0891
    rcjh0891 New Member
    Joel
    DFW
    Good deal
  5. Sep 14, 2021 at 2:31 PM
    Ajalmazan1
    Ajalmazan1 Actually likes chrome
    Lincoln, NE
    2016 DC Limited
    Does the navigation show next to the speedometer like it does for the factory nav?
  6. Oct 8, 2021 at 6:44 PM
    Bigshow7938
    Bigshow7938 New Member
    How do you like the unit thus far?
  7. Oct 19, 2021 at 8:56 PM
    StefanoBills
    StefanoBills New Member
    Has anyone installed the Pioneer DMH-WT8600 in a 2019 Tundra? I have spent 2 weeks working with Maestro and Crutchfield on getting the rear view camera to work and am about to throw in the towel. I have tried multiple harnesses, radios and maestros. I can actually get the camera to work as a secondary camera, but when plugged into the rear view RCA jack it doesn't show a picture. Funny if I play with the RCA jack (of which, I have had 3 different copies of the harness to make sure it wasnt the harness and even hardwired one myself), it shows a bit of a scrambled picture. It is madness. I saw one post where someone with a 2017 tundra said pioneer is not compatible with the Tundra stock camera. Any thoughts or ideas?
  8. Oct 20, 2021 at 6:55 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    What if. I say what if. You buy this a try it? If it doesn’t work then return. Seems like you are running out of troubleshooting ideas. Seems strange that it doesn’t work with all the proper harness you have.
    https://www.axxessinterfaces.com/product/AX-TOYCAM3-6V
  9. Oct 20, 2021 at 7:15 AM
    StefanoBills
    Thanks, so you know if that harness is different than the crutchfield supplied camera harness? They provide a harness that hooks to vehicle backup camera harness and has the yellow RCA as well. I think the purpose is to step down to 6V.
  10. Oct 20, 2021 at 7:20 AM
    BrandonL812
    Brandon
    The maestro harness supposed to do the 6v. Not sure y it doesn’t work with your radio. I would try it just to see if it is the same result like now. But that’s just me. Since it’s getting you no where at the moment.
  11. Oct 20, 2021 at 7:35 AM
    StefanoBills
    Cool, I may do that. Crutchfield even tested the head unit and harness before shipping and it worked for them. Of course they didn’t check it on a tundra, but I’ve heard others have installed without an issue. Since it works when plugged into the second camera input and works with oem headunit, could be something in the maestro. However I even unplugged the maestro from the pioneer and same issue. I’ve tried two different maestros and flashed it around a million times.
  12. Oct 20, 2021 at 7:45 AM
    BrandonL812
    Brandon
    Yeah. There’s definitely something strange going on.
    Any specific setting in the pioneer radio that you may have overlooked?
  13. Oct 20, 2021 at 7:58 AM
    StefanoBills
    I’ve tried all the camera settings, changing from PAL to NEC, Auto, etc. Same issue. Be nice if I could assign the second camera as backup, but that’s not an option on pioneer, can’t even switch cameras when in reverse.
  14. Oct 20, 2021 at 8:01 AM
    BrandonL812
    Brandon
    That’s just weird. I don’t understand why the factory camera would not work with the radio. You have the proper harnesses.
    I would try that metra axxess harness and see. If it still doesn’t work. Maybe it’s the radio itself.
  15. Oct 23, 2021 at 5:42 PM
    StefanoBills
    Anyone know where the vehicle speed sensor wire is?
