DLR > That was easy
Discussion in '2.5 Gen Tundras (2014-2021)' started by too tall, Jul 25, 2016.
  1. Jul 25, 2016 at 4:13 AM
    too tall
    too tall [OP] New Member
    Lack of daytime running lights bugs me. Putting the headlight switch to the "on" position than using the remote to shut it down is ok not perfect.
    Put a cap over the sensor. This is perfect.
    PS - 'Merica
    Yotalover88, 2cID and Law323 like this.
  2. Jul 26, 2016 at 8:34 AM
    Benni
    Benni New Member
    2016 Limited
    I never noticed that sensor until reading your post. Explain the operation of DRL & how that functions with the sensor over which you placed your hat.
  3. Jul 26, 2016 at 3:21 PM
    too tall
    This is a daylight sensor and affects several things. If your headlight switch is in the "Auto" position than when the sensor detects darkness it will cause the headlights to power on.
    The only downside to putting a hat over the sensor is that it will cause the NAV/Radio to dim during daylight which can make it hard to read.
  4. Jul 26, 2016 at 4:54 PM
    Benni
    Benni New Member
    2016 Limited
    That is interesting, I haven't driven at night since I bought the truck. Tonight I'll take a little rride .
  5. Jul 26, 2016 at 5:05 PM
    Is this on all models
  6. Jul 26, 2016 at 5:07 PM
    too tall
    I've no clue however these sensors are very common.
  7. Jul 26, 2016 at 5:38 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Solution to your radio dimming when you use your headlights during the day is to go into setup (while not driving) and change the setting to radio bright all the time. Won't display option while you are moving
    NewImprovedRon likes this.
  8. Jul 27, 2016 at 2:58 PM
    too tall
    Dewd. Thank you.
