DIY: VLED footwell lighting Install
Discussion in 'Lighting' started by stuckinohio, Dec 17, 2018.
  1. Dec 17, 2018 at 2:44 PM
    stuckinohio
    stuckinohio [OP] MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Disclaimer:
    This is a DIY, If you are not comfortable with any of the steps outlined in this DIY, then do not attempt this project. That said, I can not be held responsible for any damage that occurs to your truck as a result of your decision to follow the information contained within this thread.
    Step 1:
    Dis-assembly:
    I removed the glovebox undercover on the passenger side first.
    There are a total of (5) clips that need unset. (4) black molded in clips and (1) yellow clip.
    A plastic trim tool or flat head screwdriver will do the trick.
    Work from the passenger door toward the center console (right to left).
    Leave the yellow clip for last.
    In order to center the LED, I measured the footwell to ensure even light coverage.
    The driver and passenger side both have about 24in of width on the IP (instrument panel)
    Centered is 12" from center console, or about 8" from the edge of the yellow clip feature.
    I set the led diode back from the edge to recess it so the diodes were not visible when entering the vehicle.
    The Vleds have adhesive backing on the diode , but in the nature of robustness, I drilled small holes and ziptied it in place.
    The diodes have (2) connectors on each end. I cut off (1) connector and heat shrunk the end closed. (shown on left). Then drilled a hole large enough to feed the lead through.
    Notice, I used the left ziptie to clamp both the led diode on the bottom and the wiring to the undercover. The intent is to clamp the wire so it doesn't get kinked through the hole and so it doesn't stress the solder connection to the led board.
    The LVED kit provides 4' or so of jumper wire to go from passenger side to driver side.
    Since i cut off the extra connector from the LED, I soldered and heat shrunk that connector onto the jumper wire. I snaked the jumper line from the drivers side to passenger along the dashboard insulator (compressed jean material thing on firewall)
    Snapped the wiring connectors together and installed the glovebox undercover.
    Pull the the jumper wire slack back to the drivers-side.
    Passenger side complete!
    The driver side was a little more complex. There are not a lot of options to mount the LED in a hidden location.
    Again, the blue Sharpie (circled) is 12" center so that is the target location.
    I had some aluminum 1" L-Bracket material laying around and whittled it down to the above condition. I started with a 6" section but cut close to 1" of it off. Same principal with the zipties.
    Above is the bracket mounted. I used the studs on the hanger beam. The nuts are M8.
    I added a backer washer between the knee bolster stud and bracket.
    The last step is connect the wiring.
    The + wire is the wire with the White Dashing on it.
    Test continuity before crimping the connectors.
    Summary:
    The LVED footwell kit is a pretty well put together kit and is easy to install.
    No soldering is required and is plug and play into the parking brake light.
    I did do some soldering to save the connector i cut off the passenger side diode.
    My one complaint is that the DIY 2-pin Duo connectors that needed installed on the jumper wire didn't give a great "click" feedback when pinched together.
    Good luck and comment with questions
    Warreng, tonedraw and Charliebrn like this.
  2. Dec 17, 2018 at 2:44 PM
    stuckinohio
    Mark
    oHIo
    2018 SR5 Crewmax
    light1.jpg lights2.jpg lights 3.jpg Night Pictures:
    TheBlackPearl and anthonygan like this.
  3. Dec 31, 2018 at 3:25 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Great write up with pics.Thanks for posting. VLEDS makes a great product.
  4. Mar 4, 2019 at 7:58 PM
    tundra403
    tundra403 New Member
    KG
    2018 Tundra SR5 4x4 TSS Off Road - MGM
    -Internal LED Lights -Added VLED's Footwell light strip
    I just added mine.. they must have modified them because mine are brighter. Also ran them differently than you did.. I also chose not to cut it because they have a rear kit I want to add soon for the back of driver and passenger seat.. I may go back and redo mine like you did yours on the passenger side at least.
  5. Jul 16, 2020 at 12:29 PM
    BAZZMAZZA
    BAZZMAZZA New Member
    B-ROCK
    2017 TUNDRA Crewmax
    I used plenty of this write up for my own install.
    Thank you!
  6. Sep 29, 2020 at 4:33 PM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Thank you for the write-up and pics. I followed your passenger side to the letter and only added some cloth wrapping on the top of the panel to keep any rattling of the wires at bay. My 2017 had a knee airbag on the driver side, so ran the wires through a slit in that panel to manage them. With the airbag there, I have to rely on the 3M tape to keep that side in place.
    all in all, a great improvement in the cab!
  7. Oct 27, 2020 at 5:15 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Where did you guys mount the light on the drivers side, those of you that didn't use the Aluminum bracket?
  8. Oct 27, 2020 at 5:55 AM
    Charliebrn
    NW Ohio
    I used zip ties to attach it to the slot in the knee airbag cover, running the wires through that slot. Left it looking very clean but far enough back that you don’t see the lights themselves.
  9. Nov 6, 2020 at 7:44 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Has anyone ever extended the four Vled footwell lights with puddle lights over your running boards? Pushed wiring from puddle lights into the last Vleds female connector and they worked. Didn’t want to try my luck beyond that and quickly disconnected. Just wondering because I’m about to connects the wires more permanently so I get the boards lighting up as well when opening the doors.
  10. Nov 6, 2020 at 7:48 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I'd like to know this as well. I have the same VLED kit installed and would like puddle lights under the running boards.
