DIY Video: Installing Illuminated Light for Side Mirror Switches
Discussion in 'General Tundra Discussion' started by nk1794, Jul 9, 2018.
  1. Jul 9, 2018 at 9:10 PM
    nk1794
    nk1794 [OP] Always torque to spec
    San Jose, CA
  2. Jul 9, 2018 at 9:29 PM
  3. Jul 9, 2018 at 9:35 PM
    nk1794
    San Jose, CA
    I'll post picture tomorrow.
  4. Jul 9, 2018 at 10:12 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Interested as well
  5. Jul 10, 2018 at 10:13 PM
    nk1794
    San Jose, CA
    The first LED I used was too dim so I swapped it out with a brighter one. Now the problem is it's too bright. :annoyed::D
    https://youtu.be/fNbjMT6SZmE
    TXRailRoadBandit73 likes this.
  6. Jul 10, 2018 at 10:15 PM
    How bout a colored one? Red, blue, green?
  7. Jul 10, 2018 at 10:17 PM
    nk1794
    San Jose, CA
    I'm ordering a blue one but I think it's going to be just as bright. I'm wondering if there is a way to add a dimmer. More research....
  8. Jul 10, 2018 at 10:18 PM
    Great work! Keep us posted!
    nk1794[QUOTED][OP] likes this.
  9. Jul 10, 2018 at 11:14 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Just run a few resistors on the power wire to dim the light. Typically your white LED's are going to have more lumens, so you may need a few. Judging by the brightness in the vid, you may need 2-4. The blue LED's will likely have less lumen (in the same size), so you may only need 1 or 2 resistors.
    'Just another thought I had after watching your first vid....
    Might there be a way to put a small blue LED in the switch? I know it would only work if the white lettering has a clear backing, like the other switches. I've never really looked at the switch to much. :notsure:
  10. Jul 11, 2018 at 7:03 AM
    nk1794
    San Jose, CA
    Thank you, sir. I'll have to play around with that. I was tempted to take the back of the switch off to see if those letters have clear backing. I'll look for a used switch on Ebay to experiment with.To be continued...
  11. Jul 15, 2018 at 7:32 AM
    nk1794
    San Jose, CA
    Tundra_Dawg, saybng, Skippy and 3 others like this.
  12. Jul 15, 2018 at 7:46 AM
    nk1794
    San Jose, CA
    Thanks. Yes I did that.
    NewImprovedRon likes this.
  13. Jul 15, 2018 at 7:54 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Your videos have been great! Thanks for posting!
    nk1794[OP] likes this.
  14. Jul 15, 2018 at 7:55 AM
    nk1794
    San Jose, CA
    Thank you, sir. :cheers:
    Berdine[QUOTED] likes this.
  15. Jul 15, 2018 at 8:46 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  16. Jul 15, 2018 at 8:48 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I think I have a second one. It was 2 for 1. Wish I knew when I picked up the compressor.
  17. Jul 15, 2018 at 8:49 AM
    nk1794
    San Jose, CA
  18. Jul 15, 2018 at 9:28 AM
    nk1794
    San Jose, CA
    It’s OK. It’s good to have a spare.
  19. Jul 19, 2018 at 8:58 PM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    I cuss Toyota every time I pull into my garage at night when can't find the button. Good job
  20. Jul 19, 2018 at 9:16 PM
    nk1794
    San Jose, CA
    Thank you, sir.
  21. Jul 23, 2018 at 10:26 AM
    nk1794
    San Jose, CA
    Skippy and porkitt like this.
  22. Jul 23, 2018 at 11:37 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    @nk1794 Do you have a link for the lights?
  23. Jul 23, 2018 at 11:55 AM
    nk1794
    San Jose, CA
    The link should be in the description section.
  24. Jul 23, 2018 at 8:16 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Those the UV LEDs?
  25. Jul 23, 2018 at 8:55 PM
    nk1794
    San Jose, CA
    Nope, just regular LEDs.
  26. Jul 24, 2018 at 6:21 AM
    Cuzican
    Cuzican New Member
    Louisiana
    Just curious, in the video they looked really purple and I wasn't sure if it was the camera or the color of the light. I bought a couple of the UV LEDs just to play with, they weren't very bright, but they are true UV and did make every bit of white lint glow.
  27. Jul 24, 2018 at 6:54 AM
    nk1794
    San Jose, CA
    It's the camera. The LEDs are actually blue. These are not that bright but that's how I like them.
  28. Jul 24, 2018 at 8:03 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Thank you for sharing...added on my list.
  29. Mar 21, 2021 at 12:10 PM
    Grumpy
    Grumpy New Member
    2020 Barcelona Red Tundra 1794 TRD
    BedRug liner 2 Undercover Swing Cases Weather Tech floor liners ARE CX-REVO Color matched Shell Toyota Aluminum Oil Filter Housing Stahlbus Engine Oil Drain Hayden Transmission Cooler MIC Tuning Taillight Bar
    Big thanks to the OP, nk1794!
    I have cursed this unlit switch many times as I try to fold in the mirrors when I am in public parking spaces. This is both as a courtesy to neighboring parking spots, and as a defense to protect a set of very expensive mirrors.
    Seriously, Toyota, how many cents does the LED in the switch module cost?
    I chose an Oznium Premium Side View LED Bolt (in RED) P/N 3955 (off Amazon $17.98 for two). I chose the right angle style as it directed the light on the switch. I decided on the Red LED as it went with my Barcelona Red 1794. Also, the red light doesn't affect your night vision.
    The right-angle style sticks out a bit more than the OPs, but that doesn't seem to be a problem.
    I ran a trial with it taped in place and plugged into the power port for a week. I installed it permanently in this morning. It took about 30 minutes.
    Here is the link to what I used:
    https://www.amazon.com/gp/product/B07N6GKHP4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    saybng likes this.
