DIY Truck Bed Slide
Discussion in 'General Tundra Discussion' started by BlackRiverGuy, May 12, 2019.
  1. May 12, 2019 at 4:44 PM
    BlackRiverGuy
    BlackRiverGuy [OP] New Member
    Chandler AZ
    2019 Tundra SR5 4x4 Offroad
    In Process ARE color matched Z type cap. Pro Comp 3/1 leveling kit. Nitto Grappler 295 70 R18's
    Thought I would post a few photos of an awesome DIY truck bed slide. Now CargoGlide and BedSlide make some really nice products, however I wasn't interested in dropping $1,500 to $2,000 for a good quality bed slide.
    So basically a weekend of design, layout, fabrication, assembly, and a total material cost of $170 achieved the end result in the pics.
    The unit itself is fairly low profile, 3" high, so theres not a lot of wasted space where a bed slide frame would normally take up room, especially ones I've seen that are fabricated from wood. This is more like a hybrid, the only wood used is the bottom bearing panel (3/8" plywood), and the actual sliding deck (1/2" pre-finished plywood) the rest of the material is T6061 aluminum bar (for support), "U" channel (side frame) and "L" angle (bed slide perimeter edge rail). The aluminum really gives this assembly some robustness and stability.
    This slide incorporates a total of 26 surface mounted roller bearings (16 on bottom panel) and (10 on upper rails of aluminum channel), sort of encapsulating the sliding deck, each bearing is rated at 75 lbs. load.
    Also no drilling into the truck bed, the unit is secured using the Toyota factory tie downs in the bed.
    It was a fun project, however going with the metal does offer some challenges, tools and machinery for fabrication vs. a total wood assembly, however just the weight and space savings was well worth it!!!
    WVI, Brown Bear, monaco730 and 20 others like this.
  2. May 12, 2019 at 5:12 PM
    Very nice job! :thumbsup:
    I would love to make this. Do you have anymore pictures?
    Wallygator likes this.
  3. May 12, 2019 at 5:33 PM
    BlackRiverGuy
    Chandler AZ
    Why yes I do! Enjoy! It was a really fun me and the wife project, she is pretty handy!!
    WVI, TheBeast, Sunnier and 6 others like this.
  4. May 12, 2019 at 5:34 PM
    That's nice! Thanks for sharing!
  5. May 12, 2019 at 5:37 PM
    Just amazing, I want to try this when it warms up.
    THANKS! For sharing.
  6. May 12, 2019 at 5:41 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Very nice build !!
  7. May 12, 2019 at 5:46 PM
    Blueknights75
    Ron
    Clayton, NC
  8. May 12, 2019 at 5:52 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    NICE handy work! Great job
  9. Sep 14, 2019 at 11:16 AM
    denali302
    denali302 Meh...
    Michael
    2017 Crew Max
    @BlackRiverGuy did you use flat bar on the underside of the top/sliding piece so that contacted the rollers on the base?
  10. Sep 14, 2019 at 11:41 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Great work! I may have to give this a go...
  11. Sep 16, 2019 at 9:01 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Dude so cool
  12. Sep 17, 2019 at 7:29 PM
    Notachickmagnet
    Notachickmagnet New Member
  13. Sep 17, 2019 at 7:31 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Beautiful mod OP:thumbsup:
  14. Dec 24, 2019 at 9:53 PM
    2chains
    2chains New Member
    Southern Ablerta
    How's the slide holding up and have you done any modifications?
  15. Dec 24, 2019 at 10:41 PM
    I feel like a handy man when I change the TP roll, and then there are guys like you doing this stuff!? o_O
    This is really awesome.
    Wallygator, 2chains and TheBeast like this.
  16. May 29, 2020 at 4:01 PM
    MgmSR5
    MgmSR5 New Member
    Ryan
    2016 CM Limited 5.7 Mica Sunset Bronze
    Not to revive an old thread, but I would love to hear how this has held up over the past year! OP, could you please update us on how it has done? Thanks!
    B.Ross likes this.
  17. May 29, 2020 at 5:34 PM
    TXTundra2722
    2015 Black Tundra
    Probably not going to get a response from the OP, they haven't been on in 10 months
  18. May 29, 2020 at 5:36 PM
    MgmSR5
    MgmSR5 New Member
    Ryan
    You’re probably right - anyone else done this slide or something similar want to share?
  19. May 29, 2020 at 9:55 PM
    2chains
    2chains New Member
    Southern Ablerta
    My diy...plywood slide with hardboard sheet under neath so it can slide easier. Picked up a tin of mistint $9.00 at Homedepot to treat the wood. ideal for lighter items groceries, sports gear. Added the handle with a leather belt as a strap but it's not as study as I'd like so I added the 1x2 at the edge and works great.
    Not my idea I found a youtube video and copied.
    Would like to hear if others have done similar or provide feedback for simple improvements.
    WVI and csuviper like this.
  20. Jun 2, 2020 at 2:32 AM
    Francisco
    Francisco New Member
    Francisco
    A good thing you can do its add couple more rollers on top and bottom at the very front,so when you slide it out it has more support when you fully extended
  21. Feb 8, 2021 at 2:26 PM
    msk59
    msk59 New Member
    Mohammad
    Nissan Frontier
    Minor modification
    Hello. I just joined this forum to send OP a message. I am building an exact sliding tray for my Frontier and wanted to know where did you get the 3 inch U Channels. I cannot find it anywhere. Can you please let me know. This is the most simplistic yet very good design.
  22. Feb 8, 2021 at 2:38 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Not to change the subject much but I have found used commercially made slides for a few hundred bucks and I would be amazed if you can make one that nice and that cheap?
  23. Feb 8, 2021 at 2:41 PM
    msk59
    msk59 New Member
    Mohammad
    Nissan Frontier
    Minor modification
    Do you have a link or name of the manufacturer?
  24. Feb 8, 2021 at 2:42 PM
    msk59
    msk59 New Member
    Mohammad
    Nissan Frontier
    Minor modification
    Ultimately my plan is to install a fridge on top on one side and a pull out drawer for a Stove and other storage stuff
  25. Feb 8, 2021 at 2:44 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Mine is a Bedslide if you are asking me?
    If you search fir that on craigslist or fb marketplace used ones will show up
  26. Feb 8, 2021 at 2:47 PM
    msk59
    msk59 New Member
    Mohammad
    Nissan Frontier
    Minor modification
    yes, sorry i was asking you. Thank you. I will check it out. I have a midsize truck (Nissan Frontier Nismo OffRoad).
  27. Feb 8, 2021 at 4:03 PM
    ezdog
    ezdog New Member
    Gateway To The West
    There are several companies that make these slides and looking on the used market is just a good way to get a nice one cheap.
    Bedslide is sort of a generic name and searching with it will get results is what I am saying.
    Many beds share dimensions so measure yours and make anyone selling one measure theres.
  28. Feb 8, 2021 at 7:21 PM
    msk59
    msk59 New Member
    Mohammad
    Nissan Frontier
    Minor modification
    Thank you ezdog for your input. I will keep an eye out for a used one but I checked the prices for my truck on the new one and it is about $900.00 plus shipping. Hopefully, the OP responds one of these days.
  29. Feb 8, 2021 at 7:24 PM
    msk59
    msk59 New Member
    Mohammad
    Nissan Frontier
    Minor modification
    Question: what type of rollers you are using or what mechanism you are using to slide the drawer in and out?
  30. Feb 8, 2021 at 8:30 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Did you try mcmaster.com for the u Channel?
    you can probably get everything you need for this build there
