DIY:TRD Skid Plate Installation
Discussion in 'General Tundra Discussion' started by nk1794, Apr 15, 2018.
  1. Apr 15, 2018 at 11:04 AM
    nk1794
    nk1794 [OP] Always torque to spec
    San Jose, CA
  2. Apr 15, 2018 at 11:38 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I’ve been eyeing that Wilwaukee power wrench. Is that the 3/8 Rachet Fuel?
    Do you know what’s the difference w the fuel and can you remove bolts manually with those?
  3. Apr 15, 2018 at 12:07 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Nice job and good video! I’m impressed with how little frustration you let show while you went through the learning curve on the bolt retaining clips. Looks like that took almost 1/2 your time.
  4. Apr 15, 2018 at 3:05 PM
    nk1794
    San Jose, CA
    The rachet is 3/8 but not the Fuel version. I have both 1/4 and 3/8. The tightening power is good but loosening power is not that good. Sometimes I have to turn it manually to get it started.
    I think the Fuel version has smaller motor, more power, and if I'm not mistaken they are also using less power than the none fuel version.
    BlueBottle[QUOTED] likes this.
  5. Apr 15, 2018 at 3:08 PM
    nk1794
    San Jose, CA
    Thanks. That's right "bolt retaining clips" for the life of me I coudn't remember what they were called. Yes, that part took the longest.
    Thanks :thumbsup:
  6. Apr 15, 2018 at 3:23 PM
    nk1794
    San Jose, CA
    View from driver's side for reference. Front differential drain plug is accessible w/o removing the plate.
    ChucklesToy, gosolo and 15whtrd like this.
  7. Apr 15, 2018 at 3:41 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  8. Apr 15, 2018 at 3:43 PM
    nk1794
    San Jose, CA
    I go with one of these M18 for more torque. The smaller one has 3 level torque settings. Good compact size and much lighter than the bigger one. The bigger one is a beast. I dont use it that much.
    Thanks :cheers:
    NewImprovedRon and gosolo like this.
  9. Apr 15, 2018 at 4:13 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Do the m12’s and m18’ share the same charger?
  10. Apr 15, 2018 at 4:18 PM
    nk1794
    San Jose, CA
    A combo charger is available.
  11. Apr 15, 2018 at 4:22 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks. You def know how to help me spend some moneys!
    :spending:
  12. Apr 15, 2018 at 4:23 PM
    nk1794
    San Jose, CA
    So what are you getting?
  13. Apr 15, 2018 at 4:24 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Maybe a 3/8 rachet fuel and an m18 1/2 impact.
  14. Apr 15, 2018 at 8:52 PM
    nk1794
    San Jose, CA
    Do you think the TRD skid plate makes the truck more aerodynamic and improving MPG? :D
  15. Apr 15, 2018 at 9:08 PM
    nk1794
    San Jose, CA
    @csuviper
    feel free to add this to the list, sir.
  16. Apr 15, 2018 at 9:32 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yep
    NewImprovedRon likes this.
  17. Apr 15, 2018 at 9:33 PM
    nk1794
    San Jose, CA
    Thanks
  18. Jun 29, 2018 at 3:59 PM
    Berettafan
    Berettafan New Member
    2017 CM
    no kidding. I cussed up a storm doing mine.
    great video, thanks OP!
    nk1794[OP] likes this.
  19. Jun 29, 2018 at 5:14 PM
    nk1794
    San Jose, CA
    Thank you, sir. :cheers:
  20. Jan 3, 2019 at 7:39 AM
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    Anyone else do this? Do you need to order the hardware kit? Any better options out there? About to change my oil and I don’t want to have to r&r the skid plate every time. TIA
  21. Jan 3, 2019 at 7:46 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    While I understand the desire to not remove the skid plate I would gently point out that the removal of the skid plate does allow you, the DIY owner, the chance for an extended "eyes on" the underside of your engine. A good ole fashioned look around.
    For me, I've been removing Toyota truck skid plates since 1986 so it's second nature. And, again, I want to look around while I'm on my back down there. The standard Tundra steel skid plate is a pain compared to my other trucks (1986 truck with steel plate, 4 bolts, 1997 T-100 truck, still have, plastic skid plate with 4 bolts).
    TXDrifter and gosolo like this.
  22. Jan 3, 2019 at 9:46 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Good point about visual inspection. If I had it to do over again, I would not have bought the TRD skid plate. Not only was it insanely expensive for what it is, but since the install I have been taking it to the dealer for oil changes anyway, so the vision of an access door to the oil filter was a waste of money in my case.
    In a series of misdiagnosed belt-related issues, which turned out to be a bad tensioner, I have had the pleasure of taking the TRD skid plate on and off to swap the belt a few times and the 30 secs it took me to swap the belt, removing and reinstalling the TRD skid plate makes a quick belt swap a total pain in the ass.
    In that series of thinking I was buying poor quality belts, I had a Toyota dealer swap in a belt and they completely dicked up the rear hardware mounting to include losing one of the rear aluminum mounting sleeves. The skid plate started making a loud popping noise. I am good at removal and install now;) I went as far to add some rubber padding on the metal-to-metal contact areas, but mostly its about properly using the supplied mounting hardware. Although, its BS that the TRD skid has metal-to-metal contact...Toyota should supply some sort of nylon/rubber bushings.
    I'd be happy to work a deal with someone who wants a TRD skid and I would take their stock skid plate. No I wont ship it...too big.
    Pissed that I threw away the stock skid, otherwise I would have swapped it out and sold off the TRD skid already.
    glowblue likes this.
  23. Mar 2, 2019 at 1:40 PM
    Yotatundraaah
    Yotatundraaah My tundra stays hungrry
    Southern CA
    2016 Silver Sky Tundraaaah
    Kings suspension Built Right ufc 295/70-18 Toyo AT2 18" XD bully wheels Baja designs foglights Baja designs ditch lights Rago fabrication ditch brackets Tiger auto rock slider Extang solid fold 2.0 cover Read more....
    Any problems with the trd pro skid plates? Like noises/rattling?
  24. Mar 3, 2019 at 9:12 AM
    nk1794
    San Jose, CA
    No noises or rattling.
  25. Mar 3, 2019 at 10:34 AM
    Yotatundraaah
    Southern CA
    Thanks for the reply
    I was debating to get the trd pro skid or rci.
    However the rci does not cover the whole under frame as suppose to the trd pro skid plates
  26. Mar 3, 2019 at 10:42 AM
    nk1794
    San Jose, CA
    Right, that's the reason I went with the TRD.
  27. Apr 17, 2020 at 11:16 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Thanks for the helpful video, I saw it on YouTube first then saw you were part of the forum — appreciate the pointers!
  28. May 4, 2021 at 8:14 AM
    ntedward
    ntedward New Member
    Neil
    2018 Tundra Crewmax TRD Sport 4x4
    Thank you! This video helped me out and I got it installed quickly.
  29. May 4, 2021 at 8:30 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    That goes without saying, I'll bet OP gets 19-20MPG now. The RCI skid plate is even better, guaranteed 22 MPG
    :rolleyes: (when going downhill with a tailwind)
  30. Aug 16, 2021 at 6:22 PM
    browniemix33
    browniemix33 New Member
    New Hampshire
    2017 Metallic Grey Tundra Limited 4WD
    Following!
