DIY Roof Rack
Discussion in 'Sequoia Builds' started by farnsrocket, Apr 23, 2021.
  1. Apr 23, 2021 at 5:27 AM
    farnsrocket
    farnsrocket [OP] New Member
    Went hardcore with my DIY rack project this week. Bought 12, 9"x2” 3/16” thick, stainless steel flat bars and bent them to the correct angle with a BFH and my bench vise. Drilled a hole in each one and mounted up one side of brackets with a piece of 1/8" silicon underneath to protect the roof. Still gonna need to do some tweaking (yes, I realize the split washer is in the wrong place on that one pic :D) but I’ve got them pretty close. My rails are two 8’ 1/4” aluminum angled pieces. Once I get those sitting level and at the right height, I will mark 2 holes on each bracket and drill those out. Then mount the rails to the brackets and measure the length in between the rails and order 7-8 aluminum extrusion pieces to fit. Oh yeah, I’ll also mark the top of each bracket sticking above the rails and cut this length off even with the tops of the rail. The problem with this roof and making brackets are the different heights and angles all 3 mounting points are to each other. This way, I'll just let the brackets point whichever way they go and just cut them flush with the rail.
    Was going to mount a 50" LED light bar in front but I may not do that now and just make a nice wind reflector for the front. I will paint it all black with truck bedliner/hammer finish paint and I should be good to go!
    MSU Tundra and S. Equoia like this.
  2. Apr 23, 2021 at 9:12 AM
    S. Equoia
    S. Equoia New Member
    Ontario, Canada
    2015 Sequoia
    Looking forward to this. Some company popped up on Instagram that was looking for interest in a full size roof rack. I can't remember the name but it's something that I want to pick up eventually.
    farnsrocket[OP] likes this.
  3. Apr 23, 2021 at 9:26 AM
    farnsrocket
    Yeah, most racks I've seen are upwards of $1k or more. :der:
    I wish I could weld, I could've done a lot more.
    I should be under $500 into this when I am all finished.
  4. May 20, 2021 at 12:43 PM
    farnsrocket
    More progress! I need to trim the tops of brackets level with the tops of the rails and paint it. It’s very sturdy, I can shake the whole truck with it!
  5. May 21, 2021 at 9:08 AM
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    Sweet!
  6. May 21, 2021 at 12:34 PM
    farnsrocket
    Finished!!!!!:bananadance:
    8’ x 51”
    Cost me just under $600 and I’m very happy with it..........it’s amazingly strong and would hold its own against any rack I’ve seen out there costing 2x or more! I wouldn’t want to do it again. Very tedious work with just hand tools in my garage. Getting all the holes drilled and lined up, especially in the stainless brackets sucked. :annoyed:
  7. May 28, 2021 at 11:32 AM
    nlaroy
    nlaroy New Member
    Nick
    So Cal
    2017 Inferno Crewmax
    LED bulbs, RCI Underwear, WKOR Sliders, Fox 2.5 w/ resi Front and back, Deaver leaf springs,
    Any wind noise or whistling?
  8. May 28, 2021 at 11:34 AM
    farnsrocket
    Yes! :D
    Definitely need to work on a deflector!!
  9. May 28, 2021 at 11:40 AM
    blizz86
    blizz86 New Member
    Those mount leg bends are pretty damn good for hand bending with a vise! Nice job!
  10. May 28, 2021 at 1:43 PM
    farnsrocket
    Thanks, I wasn’t sure how they’d turn out in the beginning but they all came out pretty consistent. I’ll send you a video of me bending them!
    edit: well, I have a video, I just can’t attach it.
    blizz86[QUOTED] likes this.
  11. Jun 17, 2021 at 6:21 AM
    farnsrocket
    Finally got around to finishing my wind deflector and installed it on my rack. I went from a giant deflector that rested on my windshield but flapped in the wind and was just too big, down to this smaller one that works great! Then I mounted my light bar and ditch lights……..just need to paint some of the brackets and wire up the lights.
    Brendybobby, e30cabrio, Beau and 2 others like this.
