DIY: Replacing climate control lighting
Discussion in '1st Gen Tundras (2000-2006)' started by rwds13m, Sep 19, 2019.
  1. Sep 19, 2019 at 7:38 AM
    rwds13m
    rwds13m [OP] New Member
    Tundra
    2006 Tundra Crew Cab Sr5
    Hey there,
    New here and wanted to share a quick DIY for those if you who can’t see your climate control knobs at night. Unless you have a short, your issue will most likely be burnt out bulbs. Here’s how to replace those!
    EDB9BE69-3D3A-4CDD-B3DB-0B33D52D6C56.jpg Remove 5 bolts. Be care full not to drop the ones near the vents in the vent (magnetic screwdriver recommended). Once bolts are removed pull trim out starting from the top. Be gentle but subtle.
    This is what your see when the trim is out. I’ve circled the three bulbs that are responsible for the lighting of your knobs. Simply twist counter clockwise and pull. It’s only one click away.
    Simply pull off the bulb from the switch. They should slide right out. They come covered with these green covers and the bulbs themselves have a coat of paint on the tip. I think they just wanted to dim them down so they aren’t too bright.... I chose all out brightness and installed non modified bulbs C8FB5CFF-F9C5-4F64-8008-76E9FE16D515.jpgCBFEE9FF-6401-43A4-A351-725684155584.jpg
    You’ll need some “168” replacement bulbs. I purchased a set of ten on eBay for $7-$8 shipped. Box has info of eBay store I purchased from as reference.
    At this point reverse the process. Push the the bulb into switch, twist and click back on (test by turning on headlights), reinstall trim and 5 screws. Let there be light
    Very easy process. Took me 5ish minutes. I hope this helps at least one of you.
    Weagle, mtntop, skywalker474 and 14 others like this.
  2. Sep 19, 2019 at 7:53 AM
    rwds13m
    Tundra
    Did this on my phone. Should have read over it to correct some of the auto corrects before posting. Hate when my phone switches my words up . Either way, hopefully you understand what I was trying to convey.
    TRDFerguson likes this.
  3. Sep 19, 2019 at 9:24 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Nice write up. You can also throw LED's in there for a modern look, FYI.
    Chimi1, Tundra2 and Sangre Kid like this.
  4. Sep 19, 2019 at 9:50 AM
    rwds13m
    Tundra
    Im OCD about cars. If I installed LEDs there I would need to do it on every other accessory to match May do so at some point in the future. I’m not apposed to it at all
  5. Sep 19, 2019 at 11:50 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Understood. Several of us have converted every interior light to LED. Our trucks are surprisingly easy to take apart. I can tell you the instrument cluster looks a lot nicer with LED's. Do a search here and you can find a lot of pictures on the subject.
    two2cal and FrenchToasty like this.
  6. Sep 20, 2019 at 2:19 PM
    gooseman
    gooseman New Member
    Bruce
    03 TRD Ex
    Super sound system
    Anyone know if there is lighting in the armrest control panels. I've had my 03 Tundra since new, and we feel we remember that there was lighting in those controls. Removed the unit from the door panel but it doesn't want to seperate after removing the 3 tiny screws holding on the bottom section. Don't want to force unless I know for certain there is a bulb to be found. Any advice helps.
  7. Sep 21, 2019 at 2:41 PM
    rwds13m
    Tundra
    Not sure I’ll definitely check it out for you next time I drive the truck at night. Mine could be out too so ‍♂️
  8. Sep 21, 2019 at 3:13 PM
    gooseman
    gooseman New Member
    Bruce
    03 TRD Ex
    Super sound system
    any help is huge! just relamped entire dash and climate control panel to led. awesome in deep blue. overheads and courtesy all in 6k white. exterior all in 6k white except for front directioals that are amber. just don't want to miss anything if i can help it.
  9. Sep 22, 2019 at 4:26 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Anyone know the bulb number for the driver's kick panel courtesy light?
  10. Sep 22, 2019 at 4:54 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    In my 2004, Driver side footwell and glove box both use type 37 incandescent or type 74 LED.
    NUDRAT and tvpierce[QUOTED] like this.
  11. Sep 22, 2019 at 6:58 AM
    gooseman
    gooseman New Member
    Bruce
    03 TRD Ex
    Super sound system
    i used number 194 in a LED in that location
  12. Sep 22, 2019 at 5:10 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Those that have replaced their climate control and such lights with LEDs- Are they annoyingly bright and are you able to dim them? I really wouldn't mind getting a nice green LED setup that would sort of match the gauge cluster. I know I at least want to do the ring around the key cylinder. I was a member did that in red and it was awesome looking.
  13. Sep 22, 2019 at 5:59 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Not at all. And yes, you can dim them. The LEDs inside are really nice. Once you switch you'll wish you had done it earlier, especially the instrument cluster.
    Tundra2 likes this.
  14. Sep 22, 2019 at 6:03 PM
    KarmaKannon
    Utah
    Some junk
    Looks like I have my next project after I button up my front end and finish some storage/bed stuff.
  15. Sep 22, 2019 at 9:14 PM
    Bulldogs2741
    Bulldogs2741 New Member
    OP thanks for the post! It was one of those things that was just bugging me since I bought my Tundra a couple months ago. Quick and easy, and got it done right before church.
    06’DCXSP and pock like this.
  16. Sep 23, 2019 at 5:43 AM
    gooseman
    gooseman New Member
    Bruce
    03 TRD Ex
    Super sound system
    the hvac panel dims with the instrument cluster. it is nice
  17. Sep 23, 2019 at 7:42 AM
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Now THIS is how to introduce yourself: with a well-written and nicely illustrated how-to. As somebody who was trying to figure all this out last night - and gave up on precisely these knobs - a hearty thank you!
    And, crucially, this thread: https://www.tundras.com/threads/tundra-replacement-bulbs.233/
    @rwds13m could you get who ever is in charge of that thread to update it with your climate control bulb numbers?
    Also, ideally, all the other buttons and switches (2WD/4WD, recirc, AC, etc.)?
    As a side note, it would be REALLY handy to have that list turned into a table, complete with the NUMBER OF BULBS required in each location. And "beam angles", too, while I'm at it. I might even volunteer to get it started, if that helps.
    Can somebody help me understand the following terms:
    stepwell (superbrightleds.com at least)
    step / courtesy light (on that tundras.com bulb listing)
    footwell (which I understand, but is NOT on the tundras.com listing)
    interior door (which I understand, but is NOT on the tundras.com listing and is on superbrightleds.com)
    PS <pseudo-IT nerd alert> change your headunit bluetooth password. :-D
    NewImprovedRon likes this.
  18. Sep 23, 2019 at 7:53 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @TX-TRD1stGEN was it you that made that handy chart for all the LED's?
  19. Sep 23, 2019 at 12:11 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
  20. Sep 23, 2019 at 1:00 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
  21. Sep 23, 2019 at 1:05 PM
    NomadicFrog
    Mark
    Flagstaff, Arizona
    Thanks, but I was referring to LED beam angles - when searching on superbrightleds.com, for example, there are often choices of 32, 90, 120, 360, etc, as in the angle of the beam they project.
    I can imagine that this might matter as the same bulb types might be used in very different applications, for which it would be useful to know the ideal beam angle.
    TX-TRD1stGEN[QUOTED] likes this.
  22. Sep 23, 2019 at 1:10 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    The bulbs being removed have very wide beam angles so I would go wider if possible.
    NomadicFrog[QUOTED] likes this.
  23. Oct 20, 2020 at 10:03 PM
    pock
    pock New Member
    USA
    2005 Access Cab 4.7L V8 4x4 SR5
  24. Oct 21, 2020 at 4:07 AM
    Professional Hand Model
    Hand Protectors
  25. Oct 21, 2020 at 4:56 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  26. Oct 21, 2020 at 7:21 AM
    pock
    pock New Member
    USA
    Just marking my territory. I want to upgrade my head unit and figured I could get some
    New bulbs installed.
  27. Oct 24, 2020 at 3:36 PM
    pock
    pock New Member
    USA
    Just finished this. Not that I had problems seeing my climate control. But it looks great at night.
    Thanks for the write up!
  28. Feb 2, 2021 at 8:04 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  29. Feb 6, 2021 at 7:56 AM
    dantanna1
    dantanna1 New Member
    This LED/upgraded lighting conversion on my 04 DC has been quite the odyssey for me. With help from the chart, here's what I've accomplished without an inordinate amount of frustration.
    -Blue map lights, door lights and dome lights- T10s
    -White LED overhead light
    -New headlights and fog lights
    -A really nice new third brake light/cargo lamp replacement unit here's the link on Ebay , just a real game changer for the look
    https://www.ebay.com/itm/Red-High-M...ight-For-2000-2006-Toyota-Tundra/131475874884
    as was this one.
    https://www.ebay.com/itm/For-2005-2...-Tundra-SMD-License-Plate-Lights/233311773186
    New LED reverse lights as well. Got a bunch of stuff on order that should be here in a day or two, or three months... whichever comes first. Also am in the process of getting refunded for front blinkers that were heralded as anti-hyper flash and the lights went crazy the moment they were installed. Need a recommendation on front and rear LED blinkers, not sure if buying the switchbacks is worth it. Anyone who's experienced that product I'd appreciate your review. I guess the total for a complete turn signal LED replacement is 6 bulbs, correct? Four in front, two in back. Also, need to know your reviews on the brake light bulb replacement in the rear.
    Here's a couple of products in my queue. If anyone as info or would suggest heading in a different direction, please share.
    Now, here's a question for those in the know (this forum seems to be rife with people who know a bunch.)
    There are five tiny bulbs housed in the dome lighting assembly, you know the one with the sunglass holder and dome light controls. It's an easy enough piece to detach, a couple of phillips screws and pop off the unit, then disconnect the harness. Tried replacing them with t5's and of course a no-go, too big. So is there an LED replacement for these five bulbs and more importantly WHAT THE HECK ARE THEY ILLUMINATING?!
    For everyone's edification, the OEM part number is 90010-09015. Just want to know if I should bother with replacement, they all seem to be working, but I'm not even sure what they control. And, yes... I'm an idiot.
    For the record...
  30. Feb 6, 2021 at 3:39 PM
    Mt.Andoo
    Mt.Andoo New Member
    Andrew
    Brunswick, GA
    2000 White Toyota Tundra SR5
    Just went out to the garage with a screwdriver and some LED's I had laying around from an old project. Threw em in and now my nightly frustration is a Christmas light show. Thanks for the inspiration to get off my butt and do an easy but rewarding job!
