DIY: Rear Differential Breather Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, May 25, 2016.
  1. May 25, 2016 at 9:51 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Tools needed:
    • 14mm wrench
    • Torx bit - T30
    • Dykes (diagonal cutting plyers)
    • Philips screwdriver
    • Drill
    Required parts:
    Optional parts:
    • New breather Part # 90930-03136
    Instructions
    1. Drop down and remove the spare tire.
    2. Remove the stock breather with 14mm wrench.
    3. Install union.
    4. Push new hose onto the union.
    5. Add hose clamp at union.
    6. Run the hose up to the bed following the brake lines.
    7. Zip tie the hose to the brake lines and frame as desired. Remember to leave enough extra for when the suspension droops down.
    8. Route the hose to desired location for the breather. Some has placed them in the gas cap compartment or bed. If needed you will have to drill a hole to feed the hose into these locations.
    9. Install breather and hose clamp in desired location. Secure as needed.
    Before pic of the breather:
    After the union and hose are installed:
    Here is the union and breather parts from the dealer (not my pic):
    Here is the hose i got:
    Comparison of the breather and the union:
  2. May 25, 2016 at 10:00 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    So here is a quick little write up for the diff breather mod.
    -Diff is hot, when you cross cool water it will vacuum that mud/water into your diff=costly repair. great $20 insurance plan.-
    I used 5/16 fuel line 12ft ish depending on how you decide to route.
    2 hose clamps
    teflon tape
    bunch of zip ties
    Cutters,pliers, star socket for the tails(forgot what size)
    E2887FEB-4EC1-4E83-AE05-5E57D54F7419_zps_585b42c8be6c7863a423b02ee05dfa2b48801065.jpg
    i used part # 90930-03136 and part # 90404-51319
    First remove your tail light/disconnect all the plugs and put aside(2 star screws+pins that you need to pull away from to remove). Look down inside and see where you would route the line. Look towards the top of the bed and see where you would like to mount the new breather on. Make sure breather is pointed upward(highest point possible.)
    BE58F6C7-2A7F-4843-90F9-AFD270DFB190_zps_5bea8f7208587d51e3c54d84891824e165a51e57.jpg
    This is the new adapter and old breather
    E16AA888-46C9-4A65-80DC-47B7143C03D3_zps_328d38c44c54a0e6ab8eac4f580ae6a1a19beb11.jpg
    New adapter mounted(teflon tape the threads)
    fuel line connected to new adapter,clamp and be sure to leave a good amount of slack for Flex.
    2A06D28B-B93C-401D-932D-A5F49EE46018_zps_804c34c718cf91cc55801f0d5fd8b7a00f81af70.jpg
    I ran the line above the frame zip tied green so I can easily distinguish the breather line. then went along the frame up into the taillight section.
    2A58F884-4D85-4115-BDE4-337C70B2A5B8_zps_f6d87970cbcd19718917988d8d6f4072d1023555.jpg
    D387E7C9-F5FC-48F5-A350-010366F2AEFF_zps_28b7b979a653dcb9ab981aa7d2d98b493b0318e1.jpg
    2643458D-9987-4038-92A3-69CBBC8CB0AE_zps_d4f582bcc9906f1c331107f5351db5083265fedc.jpg
    913661AA-1988-4AC7-8E17-F466051DFD41_zps_b88a5a8374b3dd4bc5a9d864acb768f6f3db85aa.jpg
    Then mount the new breather in clamp it ,clip all the excess fuel line, zip ties, and put everything back together.
    Really easy mod. I seen countless threads where ppl run clear fuel filter through. you can if you want to. I honestly don't see the point unless you want to see if you would get any "blow back"?
    But I opted to this simple.. just like our front breathers.
    here is a video of my taco running through a small river. I didn't have the diff breather on at the time on the taco, drained the fluid. and luckily no water mixed in.. but now breather is in the taco and tundra for peace of mind just in case situations like this occurs again.
    https://www.youtube.com/watch?v=CoUQUh1p--0
  3. May 25, 2016 at 10:10 AM
    csuviper
    Broomfield, CO
    Copied here: https://www.tundras.com/threads/diy-rear-differential-breather-mod.5253/
    If i would have known you already had it written up or where going to then i would have let you create the DIY, not me.
  4. May 25, 2016 at 10:28 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    hah all good. your pictures are better.
    Ohannon7 likes this.
  5. May 26, 2016 at 11:53 AM
    riksidney
    riksidney New Member
    Erik
    2016 Toyota Tundra TRD Pro Quicksand
    dcsleeper408 likes this.
  6. May 26, 2016 at 12:12 PM
    csuviper
    Broomfield, CO
    I am reusing the existing one. It fits in the hose just fine.
  7. May 26, 2016 at 1:58 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    ..I forgot but does our front need a breather, too?
    Hotwire and dcsleeper408 like this.
  8. May 26, 2016 at 2:01 PM
    csuviper
    Broomfield, CO
    ShawnTRD, Skew12, Hotwire and 3 others like this.
  9. May 26, 2016 at 5:53 PM
    15whtrd
    15whtrd Mr. Blonde
    Next on the to do list!
    Inquiringone and nlaroy like this.
  10. May 26, 2016 at 7:00 PM
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Ordered the union today. Thanks for posting this.
  11. May 26, 2016 at 7:07 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Ya I love little mods like this. I'm going to make this my weekend project.
  12. May 27, 2016 at 8:18 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    20 minute job! 30 minutes with a couple cold ones.
  13. May 27, 2016 at 11:39 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
  14. Jun 21, 2016 at 9:02 PM
    Tracker
    Tracker New Member
    Shane
    Just ordered up the parts!
  15. Jun 22, 2016 at 2:16 PM
    Tracker
    Tracker New Member
    Shane
    I went red to match my TRD sway bar
  16. Jun 25, 2016 at 10:41 AM
    Tracker
    Tracker New Member
    Shane
    Pretty good match to my sway bar. I'm just waiting for the rest of the stuff to come in.
    Skew12, geno0506, Wrongside and 3 others like this.
  17. Jun 30, 2016 at 8:25 AM
    Tracker
    Tracker New Member
    Shane
    Union still hasn't arrived :(
  18. Jul 1, 2016 at 12:05 AM
    Tracker
    Tracker New Member
    Shane
    The Amazon link above
  19. Jul 14, 2016 at 10:26 AM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
  20. Jul 14, 2016 at 2:35 PM
    bandit
    bandit New Member
    Duh Tundra
    No worries! glad to help! Post pics up after!
    SouthBoundSteve likes this.
  21. Jul 14, 2016 at 7:05 PM
    I got lazy and ordered the ARB version $50. Should take 20 minutes and one beer for install:
    Correction: $70 (68.40)
  22. Jul 15, 2016 at 9:26 AM
    The ARB is just a fancy version of the diff mod discussed here which is quite good by the way. And mod is cheaper in cost. There really isn't a great advantage when used on our Tundra since Toyota positioned the transfer case breather and front diff breather high up. Not sure why Toyota dropped the ball on the rear diff. The ARB actually allows up to 4 breathers if you need them which we don't.
    Rileymor likes this.
  23. Jul 15, 2016 at 9:36 AM
    TheBeast The Beach
    looks like you can hook up 4 breather lines on the ARB. Please post pictures when you install it. thanks.
  24. Jul 15, 2016 at 12:22 PM
    I'll post pics after I get it and yes I'll probably run it up to the tail light area. The DIY diff mod is really very good.
  25. Jul 15, 2016 at 8:01 PM
    Mike Tread lightly.
    south carolina
    I will bite where you get it for 50.
  26. Jul 16, 2016 at 7:25 AM
    Typo. Should have $70.( Actually $68 and change.)
  27. Jul 16, 2016 at 8:30 AM
    Mike Tread lightly.
    south carolina
    Spoiler you.. you had me looking all over for it at 50 bucks..
    geno0506, SouthBoundSteve and bandit like this.
  28. Jul 16, 2016 at 9:06 AM
    bandit
    bandit New Member
    Duh Tundra
  29. Jul 16, 2016 at 9:29 AM
    Mike Tread lightly.
    south carolina
    bandit[QUOTED] likes this.
  30. Jul 16, 2016 at 9:30 AM
    bandit
    bandit New Member
    Duh Tundra
    quick google search and they have a military discount too
    NewImprovedRon likes this.
