DIY pop and lock for a fraction of the cost
Discussion in '2.5 Gen Tundras (2014-2021)' started by jaredmillerdvm, Jul 18, 2018.
  1. Jul 18, 2018 at 9:25 AM
    jaredmillerdvm
    jaredmillerdvm [OP] Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    If a post similar to mine exist please delete.
    First step: purchase these items if you don't already have them
    20 feet of blue 16ga wire
    20 feet of green 16ga wire
    10ft of split loom(the last foot or so of my wire is exposed before entering the cab so get 15-20ft if it will bother you)
    2 posi taps
    2 Male bullet wire connectors
    zip ties
    Heavy duty actuator:https://www.amazon.com/Install-Esse...&keywords=effective+vehicle+security+actuator
    The two most important things: BEER and PATIENCE
    Step one: Remove tailgate panel with T30 torx bit
    Step two: pop the two clips using a flat head screw driver
    Step three: drill a hole in each clip just big enough to pass the two strands of wire. I think I used a 17/32 bit, 1/4 in might be better.
    Step four: tape wires to zip tie and feed through tailgate exiting where you previously removed the plastic clip. feed the wires through the holes you drilled then out underneath the tailgate.
    Step five: Once all the wiring is under the truck, feed the wire through the loom. Next, run the wire following the factory bundle towards the front of the truck. Stay away from the exhaust. Zip tie in place.
    Step six: Remove the rubber plug underneath the passenger side floor board. I cut a slit in the plug to feed the wires through. I used the same method as before with the zip tie. I pushed up on the styrofoam while feeding the zip tie with my wires to the door seal.
    Step seven: use the posi taps to tap into the correct wires: I followed the youtube video of the guy installing a pop and lock on his 2018. (2018s only) Green goes to red/orangish with silver dash and blue goes to white with silver dash. check wiring for different year models.
    Step eight: drill the hole in the actuator out to 17/32s(I think this is the size I used, start smaller and work your way up to be sure) then test to be sure it's a snug fit on the locking mechanism on the truck. Also drill out the slot on the support bracket with 1/4in bit, this will allow the 10mm bolt you will use later to fit.
    Step nine: mount actuator to supplied metal brace. I mounted the front of the actuator in the 4th slot.
    Step ten: the most frustrating part! Bend brace to correct height, it took a lot of bending and re-bending but be patient you will get it. I stopped and had a few beers during this process.
    Step eleven: mount to truck. I used the same location as what pop and lock suggest. remove the existing 10mm bolt and reuse to mount your actuator.
    Step twelve: test, test and test some more. Adjust the level and angle of bracket where the locking is the smoothest. During the testing, my locking and unlocking was reversed so i simply switched the wires from the actuator instead of messing with my posi taps. The blue wire from the actuator will connect to the green wire and the green wire from the actuator will connect to the blue wire. I also removed the black rubber thing that was on the actuator and trimmed some of the plastic where it would not rub on truck mechanism. you will see what I mean when you get to this step. Hope this helps. Here is a reference on bending/height.
    You can also refer to @BlueBottle DIY bed lights and pop and lock for more info.
    ACDC2ZZTop, mzim, wv00097 and 45 others like this.
  2. Jul 18, 2018 at 10:14 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    You sir are my hero. Great write up!! Thank you
  3. Jul 18, 2018 at 10:21 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Very nice! Saves good money!
  4. Jul 18, 2018 at 11:21 AM
    TundraNoCo
    TundraNoCo New Member
    Northern Colorado, FoCo
    2018 Toyota Tundra Platinum
    Bed lined, tinted all 5 windows, hose clamped tailgate, toolbox, steps, ESP rear seat storage bins, dash cam, anytime camera switch, console safe, pop a lock for tailgate and wheels/flares, sway bar. I have Techstream if anyone local needs it.
    I'm going to do this. Nice write up. Thank you for posting this.
    jaredmillerdvm[OP] likes this.
  5. Jul 18, 2018 at 11:25 AM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Very nice!
  6. Jul 18, 2018 at 1:45 PM
    jaredmillerdvm
    Anderson, SC
    My first attempt at DIY. Ask questions if I wasn’t clear on anything. Good luck!
    TreeCat, Inquiringone and Sunnier like this.
  7. Jul 19, 2018 at 9:17 AM
    neoflex
    neoflex New Member
    Charlotte. NC
    So essentially if we swap the wiring that goes to the interior per your instructions there should be no need to reverse at the actuator correct? I was about to order a Pop N Lock as I had it on my Tacoma and this is a must have but if I can get it done for $16 rather than $95 than I am all for the little extra work. Thanks for the write up!
  8. Jul 19, 2018 at 10:08 PM
    InfernoToyo
    InfernoToyo New Member
    Barty
    Inland Empire
    2018 Inferno Limited
    Awesome write-up. Might have to try this
  9. Jul 20, 2018 at 3:20 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Great write up!
  10. Jul 20, 2018 at 6:47 AM
    jaredmillerdvm
    Anderson, SC
    Yes that is correct. It was just easier for me to switch the wires on actuator
    Berdine likes this.
  11. Jul 20, 2018 at 7:30 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Thanks for writing this up!
  12. Jul 20, 2018 at 7:34 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Thanks for the write-up! Friend of mine and I have these actuators and have been waiting to install...I think we will get to it now lol
  13. Jul 30, 2018 at 9:21 AM
    InfernoToyo
    Barty
    Inland Empire
    How’s it holding up? Any issues yet. I have ordered same actuator and just waiting when I have some free time to install
  14. Jul 30, 2018 at 5:59 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Got her done. The 20’ of wire was a good call - perfect amount needed for his CM.
  15. Jul 31, 2018 at 5:19 AM
    jaredmillerdvm
    Anderson, SC
    No issues yet!
  16. Aug 7, 2018 at 2:09 PM
    InfernoToyo
    Barty
    Inland Empire
    Finally had some free time and installed the popper. Working good so far. Thanks for the write up...made it so much easier
  17. Aug 7, 2018 at 2:24 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    What did you guys do to lock the eye on the pin? My eye portion of the actuator spun, so I used Gorilla Super Glue to solve that, but I made a "U" and had to nut and bolt it to the actuator arm.
  18. Aug 7, 2018 at 2:29 PM
    InfernoToyo
    Barty
    Inland Empire
    I was having trouble at first with the actual eye coming off the pin. After moving around actuator and getting a better angle I didn’t have to glue it down I was thinking about it or adding a small hole to the pin and secure it with a small cotter pin.
  19. Aug 7, 2018 at 4:06 PM
    MT1794PRO
    MT1794PRO New Member
    Paul
    2014 MGM 1794 CM
    Debadge, Dechrome, TRD Pro Grille, 2018 Headlights, Amber Grill Lights, Carbon Wrapped Wood Trim, Pace Edwards Switchblade Tonneau....
    This is sweet, thanks for the write up, will be giving this a go soon!
  20. Aug 10, 2018 at 1:23 PM
    neoflex
    neoflex New Member
    Charlotte. NC
    Had a Pop and Lock on my 2016 Tacoma and the last few weeks without it on the Tundra made me really realize how spoiled I was by having it. I had some down time at work this morning as they sent me to another station that was short staffed and also much slower to fill in. After getting our morning duties done I pulled the truck in and got to work. The actuator kept popping off the locking mechanism driving me nuts. I came up with a work around. It was either this way(zip-tie) or duct tape.:rofl: Seems to be holding up well and we shall see how it holds up long term. In the end I’m a happy camper. Saved a bunch going this route rather than ordering the Pop and Lock and overall it was an easy install. Reversed jaredmillerdvm's wiring instructions under the kick panel so the green and blue stayed consistent front to rear.
  21. Aug 10, 2018 at 1:33 PM
    jaredmillerdvm
    Anderson, SC
    mine is still going strong after drilling out the hole on actuator but if it fails zip tie is in its future. good job!!!!!!
    aperezsh and neoflex[QUOTED] like this.
  22. Aug 10, 2018 at 1:36 PM
    neoflex
    neoflex New Member
    Charlotte. NC
    Thank you for the write up sir, thanks to you I was able to get it done for a fraction of the cost.
  23. Aug 10, 2018 at 1:48 PM
    jaredmillerdvm
    Anderson, SC
    I drilled the hole out with a 17/32 bit(i'm pretty sure this is the size). snug fit and hasn't budged since.
    4x4_Angel likes this.
  24. Aug 10, 2018 at 2:01 PM
    SnrDisregardo
    Wade
    IL
    I tried that but there wasn't enough room for it all to move properly. Would love to see this in action.
  25. Aug 10, 2018 at 3:25 PM
    rodm1
    rodm1 New Member
    Thanks!
  26. Aug 10, 2018 at 3:31 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Nice write up! Was actually talking last night about wanting to do this... now i can do it and actually afford it. @Squatting Pigeon we could do this too
  27. Aug 10, 2018 at 4:06 PM
    neoflex
    neoflex New Member
    Charlotte. NC
    I will try and pull the cover off the tailgate tomorrow to take a video. Be sure not to tighten the zip-tie super tight. I left a little bit of play in it. Sorry I probably should of mentioned it in my last post.
  28. Aug 10, 2018 at 4:17 PM
    Pudge
    CT
    I just ordered all the parts needed on Amazon for just under $20. I already have the electrical connectors.
  29. Aug 10, 2018 at 4:28 PM
    Pudge
    CT
    What wires did you non 2018 guys tap into? I was planning to use the ones @BlueBottle used for my 2015. @texasrho83
  30. Aug 10, 2018 at 4:34 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    My truck came with the auto tailgate lock, but I’m game to help you with this!
    I love messing around with electronics and wiring.
    4x4_Angel[QUOTED] likes this.
