DIY: Map Light Switch Replacement
Discussion in 'Lighting' started by csuviper, Nov 24, 2015.
  1. Nov 24, 2015 at 7:09 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I kept blowing a fuse and one of the map lights wouldnt work after installing LED bulbs so I decided to investigate the broken map light switch.
    Pulled the upper console down by removing 6 torx head screws and unplugging one electrical connector.
    The map light switch comes off by sliding it sideways off the prongs:
    Cracked the broken switch open to find that one of the terminals fried.
    Also found that the light connector popped off of one of its plastic numbs. With some pressure on the top it pops back into place.
    Found these switches on Amazon. Says it doesn't fit my truck but after install i found out that the switches do fit. They are an exact match.
    https://www.amazon.com/gp/product/B00FY81BUQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Existing switch is on the left, new on is on the right. Worked just fine when plugged in.
    Success!
    Found an awesome temp fix for the switch while you are waiting for the new switch to come in. Connect the inner two prongs with a connector. This allows the light to come on with unlock and the door being open. Obviously you can't turn the light on manually.
  2. Oct 4, 2016 at 12:05 PM
    FishingFreak4
    FishingFreak4 New Member
    Just joined to say that you are the man! I couldn't figure out what the heck was going on after my led light install. The switch and everything seemed to function fine on the drivers side, but the light would not work unless I pressed really hard on the switch. The switch ended up being the problem. Your make shift bridge to confirm the problem was the switch and not the circuit made my day. I now know for sure the switch needs replaced even though it seemed fine. Bro high five your way!
  3. Oct 4, 2016 at 12:25 PM
    NJMIke
    NJMIke New Member
    2016 Tundra Double Cab SR5
    Rial cast wheels. Looking for TRD Pro grill with chrome surround
    Awesome. Was looking for this switch on Toyota OEM parts websites and the best I could find was an assembly for $90+.
    csuviper[OP] likes this.
  4. Oct 4, 2016 at 4:08 PM
    csuviper
    Broomfield, CO
    Glad to help
    NewImprovedRon likes this.
  5. Feb 12, 2018 at 1:53 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Holy Camoly, over 2y later and this thread is still useful. That’s the part I need!
    NewImprovedRon and csuviper[OP] like this.
  6. Mar 20, 2018 at 7:16 PM
    johnnyk110
    johnnyk110 New Member
    2018 trd cement dc
  7. Mar 20, 2018 at 7:16 PM
    johnnyk110
    2018 trd cement dc
    Thank youuuu brother !! You just hooked me up big time
  8. Jun 30, 2018 at 8:51 PM
    Matthewadams888
    Matthewadams888 New Member
    Folding mirro
    Hello everyone from ATL GA, I am a new Tundra Owner and this is my first post. I had the same issue and after some research and calling around I ordered the part, it took a week to arrive from California and I just received the switch from local Toyota part store, and here is the part number. 84249-0C010 SWITCH, MAP LAMP. I paid around $60.00 for one, I hope this helps.
  9. Jun 30, 2018 at 9:43 PM
    csuviper
    Broomfield, CO
    Ouch $60.
    The one on Amazon that works perfect was $14
  10. Jun 30, 2018 at 10:06 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    I changed the whole upper console due to this stupid switch. Driverside was broken and couldn’t get it to work. Got an almost a new one from junkyard for $90.
  11. Aug 8, 2018 at 12:09 PM
    Tbone_AZ
    Tbone_AZ New Member
    Tripp
    2018 Black Tundra 4x4 TRD
    @csuviper
    A big thank you for this thread! I have a 2018 SR5 Tundra and your information was 100% accurate (even for replacing the rear interior swithces). While upgrading my lights to LEDs I must have screwed up both switches on the rear interior lights. I currently have the connectors in there while I am waiting for the switch. The connectors were a great test to make sure it was just the switches that were causing the issue and nothing else was wrong. I appreciate all of the detail!
  12. Jan 21, 2019 at 6:55 PM
    wwolvverine
    wwolvverine New Member
    2018 Tundra 1794
    Amazing How did you remove the entire Map light console like that? I would like to do the same with my 2018 1794 Tundra, are there diagrams? Thanks!
  13. Dec 15, 2019 at 4:52 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Just saying this is still helping people.
    Is the electrical system so shitty that you cook a switch when changing a bulb?
  14. Jan 30, 2020 at 6:22 PM
    Toshito
    Toshito New Member
    2017 Red Tundra Limited
    I had the same problem for fooling around to install new brighter leds and fried 1 of the switches. Found the problem that it was the switch but I was like- where in the world will I buy one like this? So I found this thread and thanks to Amazon link you posted I was able to buy. Just waiting for the new part to come in and fix. Thanks very much for posting this issue and your success. God Bless.
  15. Feb 23, 2020 at 3:24 AM
    freddyf
    freddyf New Member
    2017 Tundra TSS
    .new Tundra guy here, 5 years later and your post keeps helping owners.
    Thanks!!!
    csuviper[OP] and NewImprovedRon like this.
  16. Feb 23, 2020 at 6:30 AM
    csuviper
    Broomfield, CO
    Glad to help
    NewImprovedRon and Ruggybuggy like this.
  17. Nov 22, 2020 at 11:22 AM
    Jessehee
    Jessehee New Member
    Jesse
    2014 Toyota Tundra
    New here. Had my truck since new in 2014. Changed the interior lights. Map light switch blew the other day. Found this form. Worked great. I’ve ordered the switches, but the wire connecter is killing my battery till the new part arrives. Did I do something wrong? Pulled the fuse. Issue is gone. Would like my lights to work till the part comes.
  18. Jan 14, 2021 at 12:59 PM
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    ok, so im sorry to dig up an old thread like this, but i havent seen it asked/answered anywhere.
    im glad there is a way to fix if it it happens, but is there a way to avoid having this happen? would it be easier if i take down the overhead console before i go breaking something? ive never been nervous about swapping bulbs before. im almost embarrassed to ask!
    jdl25 likes this.
  19. Jan 19, 2021 at 5:53 AM
    idiggplants
    PA
    2013 DC 4wd
    perfect. thank you! i got them swapped out last night and made sure they were turned off before i put them in.. used some smaller led bulbs that i had when i did my corolla.
    https://smile.amazon.com/gp/product/B00EPA7CZC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    only 4 leds, but they are still brighter than stock. im not sure how people are using the leds with 24 of the same friggin leds! i might go slightly brighter in the dome, but im definitely leaving these in the map lights!
    thanks again!
  20. Jan 30, 2021 at 10:21 AM
    JeffVV
    JeffVV New Member
    Jeff
    2006 Tundra Limited Double Cab
    Wow - what a life saver. I have a 2006 Tundra Limited. The Homelink lights went out a while back and found a link to replace them with LEDS. In doing so, probably while the units was hanging from the roof by the connector wire, the map light switch came apart. When I snapped it back together it no longer clicked on/off. I pulled the other apart to see what I was missing and that one stopped work too. I've been looking for a replacement console but did not find one without the sunroof switches. Then I found this link and saw I can just replace the switches. Great news. And I saw those switches earlier on Amazon but they did not say they worked for a Tundra. But the looked exactly like the ones in my truck. So I'll order those and get them replaced. I'll also order the led replacement lights. But I do have a question. To install those switches, it looks like you have to pop them apart and then align the 3 wires inside and snap back. Is that correct? And you have to wiggle the old switches out of the round slot on the harness and snap the new ones end. Is that correct? Anybody have a problem doing that? I don't want to break them when I snap the new ones in. It looks like they are in there pretty tight. And thanks for all the info. This is really good stuff.
  21. Feb 5, 2021 at 10:00 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  22. Aug 28, 2021 at 7:19 PM
    Njbuffington
    Njbuffington New Member
    Nathen
    2021 Tundra limited CM 4x4
    None
    This is wild! I have the same issue. I removed the console, pushed the tabs back down flattened out the plastic weld that came loose. Now the bulb does fit snug with everything reinstalled almost perfectly. The problem I’m having is that when pushing the switch in/out I get only flicker and the other lights are sometimes affected. The light does stay on when I continually push it in. I think the to switch button is toast.
  23. Dec 14, 2021 at 4:55 AM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    Amazon still has these switches, and I’ve got a set on the way. Still an extremely useful theead
  24. Jan 23, 2022 at 9:13 PM
    nightcrawler
    nightcrawler New Member
    Eric
    2008 Tundra Crewmax Limited
    Thanks for this thread. While I was installing LED lights into the passenger side map light, I somehow bumped the switch out of place. If I remove the metal plating, I am hoping the switch will drop down. I guess my question is; am I going to have to take off the entire overhead console to put the switch back into place?
  25. Mar 9, 2022 at 1:48 PM
    SHAYNDRA
    SHAYNDRA New Member
  26. Mar 9, 2022 at 10:31 PM
    csuviper
    Broomfield, CO
  27. Jul 18, 2023 at 8:54 AM
    jdl25
    jdl25 New Member
    I'm about to replace the map lights on my 18 with LED bulbs.
    Is there a procedure to reduce potential damage to the switches? Make sure they are all off before removing the bulb and installing the new one?
    What a great thread.
  28. Jul 18, 2023 at 9:10 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Use a good quality led bulb. Make sure the light is off when replacing. Shorting the terminals is what causes the switch to fail. It's the weak link and fails before the fuse blows.
  29. Jul 18, 2023 at 11:26 AM
    jdl25
    jdl25 New Member
    It went well. I replaced the front two map lights and the rear dome lights.
    I rolled down the windows because it was hot.
    I got in and hit the lock button. Keys out of the ignition. Lights went out.
    I was very light handed with it. I made sure to use only enough force to get the bulbs set.
    The hardest part was getting the old bulbs out. They were tight. I wrapped a small piece of gorilla tape to them and they came out.
    So far so good.
    Ruggybuggy likes this.
  30. Sep 11, 2023 at 10:22 AM
    Mint34
    Mint34 New Member
    2014 SR5 Double Cab
    Still the most detailed write up! Much appreciated.
    On the OP: "Also found that the light connector popped off of one of its plastic numbs. With some pressure on the top it pops back into place" - Are those copper connectors broken on the sides? Mine looks similar to that 6th photo, causing flickering in the bulb. Debating whether the copper connections should be soldered or simply pressed back onto the tiny plastic numb mount.
