DIY maintenance versus Toyota Care with engine recall in mind
Discussion in '3rd Gen Tundras (2022+)' started by buzzkill42, Jan 7, 2025.
  1. Jan 7, 2025 at 6:46 AM
    buzzkill42
    buzzkill42 [OP] New Member
    Joe
    2024 Tundra 4x4
    I wanted to get the thoughts on doing your own maintenance versus the dealership with the engine recall in mind.
    I prefer to do it on my own but don't want to risk having potential future engine troubles declined to be covered.
    How do others feel about this? Anyone with a new engine that did their own maintenance have experience to share?
    This is not meant to discuss the engine failures themselves, there are other threads for that.
    Thanks in advance!
  2. Jan 7, 2025 at 7:09 AM
    scarecrow87
    scarecrow87 New Member
    Shane
    TX
    Silver 2023 Tundra SR5 TRD
    I change my own oil in between their recommended 10k miles. I change every 5k and it’s easy and cheap to do on your own. I don’t think that’ll matter if/when you end up having to replace the engine under recall
  3. Jan 7, 2025 at 7:15 AM
    buzzkill42
    Joe
    2024 Tundra 4x4
    Thanks and that was a compromise I had considered too.
  4. Jan 7, 2025 at 7:17 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    It's a recall, the engine will be replaced regardless, but seeing yours is a 24, it's not part of the recall. So, do as you wish. I have a 24 and will not even take mine in for the free services, I do all maintenance myself. I just enter it on the Toyota app. So it all still recorded, & keep my receipts for parts.
  5. Jan 7, 2025 at 7:22 AM
    buzzkill42
    Joe
    2024 Tundra 4x4
    Good point, I forgot about the ability to record maintenance on the app.
  6. Jan 7, 2025 at 10:02 AM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    What? That’s a thing? Where in Toyota app do you see that? I must be blind
    ScottieBones likes this.
  7. Jan 8, 2025 at 9:27 AM
    JDAZ
    JDAZ New Member
    Where in the app is this? This is one of my disappointments coming from the Tacoma that had something like 25 service items you can label in the radio.
  8. Jan 8, 2025 at 9:37 AM
    Maine TRD PRO
    Maine TRD PRO New Member
    2023 Ice Cap Tundra TRD PRO(Rioja Red interior)
    Man some of you have PTSD or something. The engine recall is only non hybrids build dates 2/23 and older. There’s literally no reason to consider it if you have a 2024 Tundra. In 2029 y’all still gonna be posting about what to do about the recall on your new truck
    ScottieBones and caboj like this.
  9. Jan 8, 2025 at 9:47 AM
    lapoolboy
    lapoolboy New Member
    It's in the "Service" menu under "Make an Appointment". Then go to "Service History". Not very intuitive, but that's where you'll find it.
  10. Jan 8, 2025 at 10:26 AM
    Libagui
    Libagui New Member
    Librado
    2024 midnight black Toyota Tundra Limited, TRD offroad
    Don't risk it, just a couple buds and you won't risk any warranty claim in the future.
  11. Jan 8, 2025 at 12:06 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I got the prepaid maintenance up 85K. I change the oil myself at 5K intervals. The dealer will do their 10K. I take it in every 5K so they can rotate the tires.
    buzzkill42[OP] likes this.
  12. Jan 8, 2025 at 1:06 PM
    buzzkill42
    Joe
    2024 Tundra 4x4
    See post #9, it's a little bit buried but it's there.
  13. Jan 8, 2025 at 1:31 PM
    Brit84
    Brit84 New Member
    I'm clicking "make an appt" and see no "Service History" for me to enter anything. It only shows the dealer to contact...
  14. Jan 8, 2025 at 1:47 PM
    Raven67
    Kentucky
    After you click "make an appointment" give it a second & the rest of menu should pop up like this...Screenshot_20250108_164500_Toyota.jpg
    ScottieBones and buzzkill42[OP] like this.
  15. Jan 8, 2025 at 2:08 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Thanks for this.
    Just entered my 3 oil & filter changes.
  16. Jan 8, 2025 at 2:10 PM
    BlackNBlu
    Rich
    MN
    Same. Easier and quicker to DIY for me and skip the dealer. Plus no worries about stripped or cross-threaded skid plate threads.
  17. Jan 8, 2025 at 2:13 PM
    DesertDwellerFeller
    DesertDwellerFeller New Member
    Coming soon...
    Depends on if I run out of glue and colored paper
    Just document everything like you are your own personal shop and if you want to cover your basis, send fluids away for analysis and you'll have all that documentation too.
  18. Jan 8, 2025 at 2:14 PM
    Brit84
    Brit84 New Member
    Nothing after 20 mins
  19. Jan 8, 2025 at 2:26 PM
    BlackNBlu
    Rich
    MN
    My first thought is to close out of the Toyota app and fire it up again. Reboot essentially.
    Then try again.
  20. Jan 8, 2025 at 2:28 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    I don't think you can do it from the app. I record mine through the Toyota Owners portal on their site.
  21. Jan 8, 2025 at 3:08 PM
    Raven67
    Kentucky
    Yes you can, I've added mine with app.
  22. Jan 8, 2025 at 3:10 PM
    JDAZ
    JDAZ New Member
    It's there. I found it. I wish you could edit the titles. It's a very "clunky" app and that's putting it mildy. Hiding it in the Schedule an appointment bubble is weird
  23. Jan 8, 2025 at 5:16 PM
    Woocawachie
    Dickens
    Philadelphia
    Thank you so much. I bought this truck from a Toyota dealer, as used, with 15k on odometer. But there was no service records at all on CARFAX, I followed your instructions and now I have a history showing up from all the previous services. Amazing. Not sure who put them there, dealer or previous owner, but I’m glad I know that it was serviced
  24. Jan 8, 2025 at 5:23 PM
    JDAZ
    JDAZ New Member
    No problem. Funny you mentioned that. I was going to mention that too as I found much more detailed service description, one says the fuel tube recall was done, but yet it shows in the recall is still active. Even had the dealer I bought the truck from calling me saying they have the parts and want me to bring it in. Might have to call that dealer and ask them what the deal is
    Woocawachie[QUOTED] likes this.
  25. Jan 8, 2025 at 5:33 PM
    lapoolboy
    Happy to help bud! :thumbsup:
  26. Jan 8, 2025 at 6:23 PM
    Woocawachie
    Dickens
    Philadelphia
    Seems like the official fix for it just became available. I also had a dealer call me today about it, going in next week to fix it
  27. Jan 9, 2025 at 5:12 AM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    What you’re seeing in the Recalls may be the temporary fuel line fix. A tube wrap/protector was placed over suspected spots that might rub through the plastic tubes, while the permanent fix was in the works. I had the permanent fix done before Thanksgiving.
  28. Jan 9, 2025 at 5:21 AM
    Woocawachie
    Dickens
    Philadelphia
    Any idea what the permanent fix is? Probably a new clip or something
  29. Jan 9, 2025 at 5:23 AM
    JDAZ
    JDAZ New Member
    You're probably right as the Recall has an "A" in it and the notation has a "B" in it.
  30. Jan 9, 2025 at 5:24 AM
    JDAZ
    JDAZ New Member
