DIY Maintenance Schedule / Products / Tips List
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cougareb, Mar 16, 2024.
  1. Mar 16, 2024 at 9:59 AM
    Cougareb
    Cougareb [OP] New Member
    2014 Tundra Limited Magnetic Gray
    I'm a relatively new truck owner (4WD 2014 Tundra Crewmax Limited; purchased in 2021). I'm new to working on my own vehicle, but my hope is to do more maintenance at home to save money, learn more about my truck, and to spend time working (and learning together) with my teenage sons.
    We used some helpful threads here to change the oil and filter about six months ago, which wound up working (mostly) well (...except for an embarrassingly large oil spill from tipping over the used oil bucket!)
    Can any of you share your DIY schedule / products / best practices for other "at home maintenance" you perform?
    (For example, how often should I perform things like brake fluid flush, coolant flush, and power steering fluid exchange? What other services should I be planning to do at home?)
    Damie Street likes this.
  2. Mar 16, 2024 at 10:04 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Welcome!
    I mainly just wait for the maintenance warning to come on (every 5k mi). That’s the que for oil and tire rotation. I just did the power steering fluid exchange (80k mi) just because it looked dirty.
    Trans, diff and transfer case fluids are every 60k, maybe more if you tow. Don’t forget to grease your u-joints.
    Keep in mind everyone drives their trucks differently, and everyone is gonna have an opinion whether it coincides with the manual or not. So check your manual, too. :thumbsup:
    bulldog93 likes this.
  3. Mar 17, 2024 at 9:15 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    -Oil & Filter: every 5k miles or 6mo.
    -Transmission Fluid (drain/fill): every 60k mi. or 6yrs. (Toyota ATF WS)
    https://www.tundras.com/threads/2020-transmission-drain-and-fill.88720/
    * Page 2 of this thread has a great how to video*
    -Coolant: (1st time) 100k or 5yrs. (2nd time, on) every 50k or 5yrs. (Toyota SLLC)
    https://www.tundras.com/threads/coolant-flush.122259/
    *Good how to video in this thread too*
    -Differentials: every 30k mi (75w-90)
    - Transfer Case: every 30k mi (Redline MT-LV)
    -Power Steering Fluid Exchange: every 60k mi(Dex III ATF)
    -Brake Fluid, change every 3 years (Dot III)
    https://youtu.be/jpiXOBRkZs4?si=KveFnb0PsUjtFOxf
    -Sparks Plugs: every 120k (OE)
  4. Mar 17, 2024 at 1:07 PM
    mgrs
    mgrs New Member
    '20 OR
    Great post.
    Would suggest investing in a toyota filter housing tool as well.
    bulldog93 and Red&03Taco[QUOTED] like this.
  5. Mar 17, 2024 at 1:15 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
  6. Mar 21, 2024 at 10:47 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    So I use auto transmission fluid in place of the power steering fluid?
  7. Mar 21, 2024 at 10:57 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Yes, many Toyota models use ATF in place of standard transmission fluid. At the end of the day ATF is basically a form of a hydraulic fluid, and our trucks have hydraulic power steering.
    Both my 1st Gen Tacoma and my 2018 Tundra call for Dex III ATF in the power steering systems.
    Damie Street[QUOTED] likes this.
  8. Mar 21, 2024 at 11:10 AM
    Damie Street
    Edsel
    South Carolina
    So valvoline max life (red bottle) is good to use?
  9. Mar 21, 2024 at 1:40 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    As long as it says it's Dexron III or Dex III yes
  10. Mar 22, 2024 at 5:58 AM
    Damie Street
    Edsel
    South Carolina
    I'm going to tackle everything except for the transmission (it intimidates me a little still, need to do a little more research) plus replace 5 wheels studs on the front that a shop stripped(SMH).
    Red&03Taco likes this.
  11. Mar 22, 2024 at 7:04 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    I get being intimidated by the transmission but honestly it's not bad at all. Err on the side of overfilling it (by adding an extra 1/2 quart beyond what drains), then crack the check plug open right when the pan temp reads 100°F, and let it diminish to a trickle, then seal it and call it a day.
  12. Mar 22, 2024 at 7:15 AM
    Damie Street
    Edsel
    South Carolina
    What temp reader to you use?
  13. Mar 22, 2024 at 9:50 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    I'd suggest the Veepeak OBDII dongle and the free Car Scanner ELM OBD2 app for your phone (Android). It's simple to set up and you can see ATF temp, coolant temp, etc. Most scan tools that will give ATF temp are well north of $100 and the Veepeak is $14. If you need iOS, then you can spend a few more dollars on the nicer Veepeak (I think that's the right version) and get the iOS version of the Scanner app.
  14. Mar 22, 2024 at 9:46 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    I use Scan Gauge II
