DIY: Fog Light Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Mar 13, 2014.
  1. Mar 13, 2014 at 1:52 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Esenjam, TreeCat, ACDC2ZZTop and 8 others like this.
  2. Mar 13, 2014 at 3:38 PM
    Hopefully we can do this, this wknd!
  3. Mar 17, 2014 at 10:31 PM
    Beer'd_n_yotas
    Beer'd_n_yotas New Member
    2013 Super White Tundra
    Plasti-dipped and lowered!
    I used the Eddie write up. It is well written and simple to do.
  4. Mar 18, 2014 at 7:24 AM
    csuviper
    Broomfield, CO
    Well we did not continue with the Eddie V1 because the 2012 plugs and wiring appeared different than the tutorial. We decided to do additional research before continuing so we didn't cut the wrong wires.
    @Beer'd_n_yotas , did your plugs and wiring look the same as the tutorial?
    JTP likes this.
  5. Mar 18, 2014 at 7:52 AM
    csuviper
    Broomfield, CO
    Found this comment in regards to 2012 wiring after asking if there were updated instructions for 2012-2013
    "Never mind. The wiring is almost 100% the same as in the earlier models. I just wasn't looking far enough into the dash."
    This leads me to believe we weren't looking in the right spot.
    JTP likes this.
  6. Mar 18, 2014 at 9:59 AM
    We were under the kick panel, and could not locate any resemblance...
  7. Mar 18, 2014 at 10:42 AM
    csuviper
    Broomfield, CO
    True. I will look at mine tonight and investigate each connector to find the match. The location might be different but hopefully the connector is the same.
    After looking at it again the pink wire is under the steering column and the grey under the kick panel. We didn't look at under the steering column. oops
    TTund16 likes this.
  8. Mar 19, 2014 at 1:36 AM
    Beer'd_n_yotas
    Mine is a 13 and it was correct as far as I remember. And you do need to pull the kick panel and connect to the wires at the base of the steering colum. Need me to take a pic?
  9. Mar 19, 2014 at 7:34 AM
    Please do..we pulled my kick panel, but could not find a resemblance for the life of us.
  10. Mar 20, 2014 at 11:28 AM
    csuviper
    Broomfield, CO
    Ok here is what we weren't doing . The lower plastic section of the dash needs to be removed to get the the top plugs where the pink wire is. Use a 10mm socket to remove the two lower bolts and pull to pop the clips off.
  11. Mar 21, 2014 at 1:24 AM
    Beer'd_n_yotas
    Glad ya figured it out. I totally forgot to get a pic for you.
  12. Jan 15, 2016 at 9:55 AM
    Tpehl66
    Tpehl66 New Member
    Troy
    Rockdale,Texas
    2016 Trd pro quicksand
    295/70/18 cooper maxx
    Has anyone done this mod on a 16 pro yet?
  13. Jan 15, 2016 at 5:54 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Can it be done to work on the factory switch? Or this is just on all the time?
  14. Jan 15, 2016 at 8:37 PM
    csuviper
    Broomfield, CO
    Wolves with the switch. Stock it can't turn on with brights or without the low beams on. With mod it will turn on with parking lights, low and heigh beams.
    Rex Kramer likes this.
  15. Jan 19, 2016 at 5:37 AM
    dyvet2004
    dyvet2004 New Member
    Maryland
    2016 Limited Tundra 5.7 Double Cab Trd Off Road Package
    Nfab nerf bars, Bilstein 5100's Front and Rear
    will this mod work on a 2016 tundra?
  16. Jan 28, 2016 at 9:39 AM
    Tpehl66
    Tpehl66 New Member
    Troy
    Rockdale,Texas
    I can confirm this does work on 16 pro cm
    MDHinSD likes this.
  17. Mar 30, 2016 at 7:12 AM
    T@c0123
    T@c0123 New Member
    07 sr5 tundra double cab
    Do we have to use a 22 gauge wire? My local stores only sale 18 - 8 gauge wire, so is it ok to use the 18 gauge wire?
  18. Mar 30, 2016 at 7:18 AM
    csuviper
    Broomfield, CO
    You don't need to but the wire you tap into is very very small.
  19. May 24, 2016 at 6:06 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I did this today. Thanks for info, Brian.
  20. Aug 8, 2016 at 1:11 PM
    Freeride15
    Freeride15 New Member
    Pat
    2016 tundra platinum
    Toytec lift, trd exhaust, trd sway bar, 20×9 fuel vapor d569 with +20 offset, 305/55/20 mickey thompson atz
    My fog lights come on when it's parked for no reason. Any ideas, love the extra light with my high beams on but worried about bat going dead.
  21. Oct 25, 2016 at 2:31 PM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    2016 CrewMax Platinum
    Finished this mod last night on my '16 platinum CM. My rigid fogs should arrive this afternoon. I'll get a pic posted as soon as it's dark again. My phone battery died last night from using it as a work light...
  22. Oct 25, 2016 at 2:42 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    So this will let you turn your fog lights on and off, independent of your headlights? I want to run my fog lights, when my headlights are off and only my DRL are on. Also, have my fog lights on when my HIGH beams are on.
  23. Oct 25, 2016 at 2:47 PM
    csuviper
    Broomfield, CO
    Parking lights off/DRLs on = no fog lights
    Parking lights on = fog lights on if switch is turned on
    Headlights on = fog lights on if switch is turned on
    High Beams on = fog lights on if switch is turned on
    TTU19 and PR_02 like this.
  24. Oct 25, 2016 at 2:49 PM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    Yes, this allows them to be on with park lights and high beams. However they don't come on with auto Drl, the light switch has to be at least in the park light position. But I can verify that fogs with high beams and fogs with park lights do work.
    14tundraman and TTU19[QUOTED] like this.
  25. Oct 25, 2016 at 2:55 PM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    I did misunderstand the "harness side" at first, and made the jumper for the plug side. Quick troubleshoot and made the jumper for the harness side (wire side) and it worked as advertised. Thanks for posting All the write ups!
  26. Oct 25, 2016 at 8:25 PM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    Picture is terrible, but here's a pic of the fog light mod and the new rigid sae fog lights.
    I have the amber covers on the way...retrofit headlights will be next
    nikatnite79 and (deleted member) like this.
  27. Oct 29, 2016 at 6:24 PM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    I thought I would mention that after I drove the truck I noticed that the fog lights bounced from larger bumps in the road. When I got back, I checked to make sure everything was tight. But the lights are attached by a piece of sheet metal. It does look like I could slide the lights forward slightly and possibly reduce the bouncing(not much though). I want to keep the lights how they are(tucked in a bit). So for now I have some thick rubber that's not visible, but holds the lights rock solid. No more bouncing. I like the rigid mounts, there is a bit of a different install on platinums vs crome(metal) corners. Perhaps that's contributing to the bouncing.
    Anyway the rigid SAE fog lights are amazing. Puts the stock fogs and headlights to shame. Turning on my headlights is almost unnoticeable. The SAE fogs have such tight cutoff, but the light from the fogs project farther than the headlights. Very happy with both the mounts and fogs, the mounts could be more rigid though.
  28. Oct 30, 2016 at 9:07 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    So no one is having an issue with the fog lights randomly coming on after the truck has been turned off for 15-20 min? This would be on the 2016 models btw
  29. Oct 30, 2016 at 9:28 PM
    Great mod! Have anytime fogs w DRLs n low n high beam jus wish ther was a brighter bulb out ther for my '14
  30. Oct 31, 2016 at 8:42 AM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    No issues so far with the fogs coming on by themselves on my '16 CM
