DIY changing the oil and now i have a massive leak....???
Discussion in '2nd Gen Tundras (2007-2013)' started by oldschoolhdmike, Jun 4, 2016.
  1. Jun 4, 2016 at 2:20 PM
    oldschoolhdmike
    oldschoolhdmike [OP] New Member
    mike
    2007 tundra crew max 5.7
    not much
    i have done 1000's of oil changes. this is my first on my new truck. the oil change place wanted $160 bucks so i bought 0w-20 full synthetic mobil one and a filter kit with orings etc. changing the oil was no issue at all......but when i cranked it up to check everything before i put the skid plate back on it was pouring oil from the bolt right next to the filter housing....have no idea why....i never touched that bolt and it was not leaking there before.....what do i do....it is leaking really fast....i would probably not even make it to town
    05243f6f-873d-43b3-a284-654a57c9e18d_zps_ff5d6f2ec0a1264a990f3b1127ef3eabe1edd020.jpg
  2. Jun 4, 2016 at 2:42 PM
    That's odd...not stripped by chance?
  3. Jun 4, 2016 at 2:43 PM
    oldschoolhdmike
    mike
    not much
    stripped how? i did not even touch it? filter housing came off and on with no issues. it was not leaking a drop before....
  4. Jun 4, 2016 at 2:44 PM
    Get a different bolt and replace it to see if it stops.
  5. Jun 4, 2016 at 2:47 PM
    oldschoolhdmike
    mike
    not much
    i dont even know what that bolt it....i hate to take it out and make the issue worse....seems kinda odd to start leaking without even being touched.....from what i have found out it the net it looks like the oil cooler bolt but no clue why it just started leaking
  6. Jun 4, 2016 at 2:48 PM
  7. Jun 4, 2016 at 3:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Check to see if it's loose, as in finger tight. I'd gingerly snug it up. If that reduces the flow, then maybe one of the techs can chime in with a possible torque spec and some insight.
  8. Jun 4, 2016 at 3:47 PM
    Ouch! Don't drive anymore I've been wanting to do myself but I take to toyota dealer 80$ bout what u spend doing on own hope turns out well maybe big O ring not seated right??? And it's spitting out side???
    Dawgmech and tnbndr like this.
  9. Jun 4, 2016 at 4:13 PM
    oldschoolhdmike
    mike
    not much
    it was the casting of the housing. had a small crack in it. it was probably there before but when i took it off it just made the crack bigger.....went to the parts store got a new housing and now it is good to go.....
  10. Jun 4, 2016 at 5:03 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
  11. Jun 4, 2016 at 5:56 PM
    oldschoolhdmike
    mike
    not much
    mine is def not plastic.....it was cast aluminum is what it looked like
  12. Jun 4, 2016 at 7:24 PM
    Really?!? Plastic?!? Did not know that I just take to dealer to change...and the one u got is aluminum?!?! No issues with??? U change ur own oil???
  13. Jun 4, 2016 at 8:05 PM
    He is talking about the filter cap.
  14. Jun 4, 2016 at 8:18 PM
  15. Jun 5, 2016 at 5:35 AM
    mdavis
    Michael
    Rock Hill, SC
    Yep, all of our trucks come with a plastic oil filter housing. When you buy the aluminum one, you will need to change the tube in the center with the one in the plastic one. The tube that comes with the aluminum one is too short. Simple swap. I've had zero issues with mine but only have 12K on it. And yes, I change my own oil.
    HbbTundra08, Pudge and NewImprovedRon like this.
  16. Jun 5, 2016 at 6:37 AM
    Does it void warranty on truck for making any changes to it?
  17. Jun 5, 2016 at 6:39 AM
    Also that link you sent to Amazon that is the aluminum one?
  18. Jun 5, 2016 at 6:59 AM
    mdavis
    Michael
    Rock Hill, SC
    No, that won't void the warranty. It's a genuine Toyota part.
  19. Jun 5, 2016 at 6:59 AM
    mdavis
    Michael
    Rock Hill, SC
    Yes.
  20. Jun 6, 2016 at 1:59 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Is bet u put the oring on the filter in the wrong place
    P-Factor likes this.
  21. Jun 6, 2016 at 5:55 PM
    tibadoe
    tibadoe New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    I changed to the aluminum filter housing at first oil change - glad I did.
    mdavis likes this.
  22. Jun 6, 2016 at 7:42 PM
    Guess I'll get me one too
  23. Jun 6, 2016 at 11:29 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Here's what everyone should do on their first oil change..
    - Buy the cap socket.
    - Replace the plastic cap with the aluminum one.
    - Install a Fumoto (formerly "quikvalve") nozzle.
    Optionally: Use TRD filters and Royal Purple oil.
    Dawgmech, equin, Pudge and 1 other person like this.
  24. Jun 7, 2016 at 6:07 AM
    Do you know what brand dealers use???
  25. Dec 18, 2017 at 6:21 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    I basically have the same issue as the OP, I just bought the Toyota filter cap linked above to replace the Autozone one I bought which replaced the messed up OE one.
    @mdavis My question is , do I HAVE to switch out the shorter tube that came in the one I just bought (toyota aluminum)? It's in there much more solidly than my original stock one, or the aftermarket Autozone one I'm using now (that leaks).
  26. Dec 18, 2017 at 6:23 PM
    mdavis
    Michael
    Rock Hill, SC
    Yes, you have to switch the tube with your existing one. The one that comes with it is too long. You will not be able to screw the canister in with the new tube installed.
  27. Dec 18, 2017 at 6:30 PM
    Tundra Fan
    Toby
    Kinda confusing........hopefully this makes more sense.. I'm confused and I know what I'm trying to say, lol.
    The tube that came with the Toyota aluminum one is shorter than the plastic stock one (which I threw away because it wouldn't stay together), and shorter than the Autozone one I'm using in the truck now (which leaks). Basically the last 2 I've used have the long tubes and they don't stay in as solidly as the new one I just bought. Can I keep the short one on? It will definitely screw in because it's shorter than whats on there now.
  28. Dec 18, 2017 at 6:31 PM
    Tundra Fan
    Toby
    When I say "stay in", I'm referring to the tube inside the filter housing.
  29. Dec 18, 2017 at 6:39 PM
    mdavis
    Michael
    Rock Hill, SC
    You know what, I was wrong, the aluminum one does come with a shorter tube. Sorry, been awhile since I changed mine out. As far as you keeping the shorter one, I'm not sure if that would be ok or not. Wouldn't want to tell you wrong.
    Tundra Fan likes this.
  30. Dec 18, 2017 at 6:41 PM
    Tundra Fan
    Toby
    lol, no worries. Thats why I quoted your post because it mentioned the shorter one on the aluminum one. Anybody have an idea if I can keep the shorter one? What exactly do these tubes do other than keep the filter centered? Do they help disperse the oil through the filter?
