DIY: Bed Tie-Down Ring Addition
Discussion in 'General Tundra Discussion' started by csuviper, Sep 1, 2014.
  1. Sep 1, 2014 at 8:42 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The bed of most Tundras lack tie-down rings. This mod adds the much needed tie-downs for things like dirt bikes and camping gear. I did not create this mod, actually found in on Tacomaworld and installed these when i had my Tacoma.
    Parts you will need:
    Tools you will need:
    • Step drill bit with a Drill
    • Cut off wheel with an Angle Grinder
    • Vice or Vice Grips
    • T-55 Torx with a ratchet
    Directions
    1. Place the tie-down rings in a vice or clamp them tight in vice grips. It is much easier if they are placed in a vice. If you purchased tie-down rings with a 1/2" diameter hole already, you can skip step 1 and 2.
    2. Use the step drill to open up the holes in all of the tie-down rings to 1/2" diameter. If you purchased tie-down rings with a 1/2" diameter hole already, you can skip step 1 and 2.
    3. Add some black paint of your choosing to the holes that you opened up to avoid rust.
    4. Remove the truck bed retaining bolts. You only need to remove the ones that you plan to add tie-down rings to.
    5. There are two options for this step.
      1. Option 1: Clamp down the washer on the bolt in the vice. Use the grinder with cut off wheel to cut or notch a part of the washer off to the bolt head.
      2. Option 2: Grind down the bolt retention ridges or use a hammer to remove the washer from the bolt.
    6. Place the bolt into the tie-down rings and install them back into the bed of the truck.
    Simple as that you now have additional locations to tie down what you want.
    Removal of the bed retaining bolts
    T-55 Torx socket
    Step drill bit used to open up the holes to 1/2" diameter
    Washer too big for the tie-down
    Another view of the washer being too big for the tie-down
    Paint added to the holes
    Notched washer
    Bolt with notched washer installed in the tie-down
    Installed
  2. Sep 1, 2014 at 9:43 PM
    Next DIY mod you need to do...spray in bed liner
    Brink, ToyoD, JuanTon21 and 6 others like this.
  3. Sep 1, 2014 at 9:48 PM
    csuviper
    Broomfield, CO
    Lol. It probably wont be a DIY. I will most likely get it done by a professional with warranty. The good stuff.
    ToyoD, Homar23 and T-Rex266 like this.
  4. Sep 3, 2014 at 10:48 AM
    csuviper
    Broomfield, CO
  5. May 18, 2015 at 7:13 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I can't believe I didn't see this til now, great DIY.
  6. May 18, 2015 at 7:39 PM
    csuviper
    Broomfield, CO
    Yea, @Sean266 was the only one to respond to the thread until you 8 months later.
    MotoTundra likes this.
  7. May 18, 2015 at 7:43 PM
    I think I still have some
    d-rings left over...but I plan on doing line-x so I'm not sure i care to install them...
  8. May 18, 2015 at 7:46 PM
    :smash:@csuviper - your abused bed paint scratches make my OCD go crazy
  9. May 18, 2015 at 7:53 PM
    Mike Tread lightly.
    south carolina
    Csviper knows how to make sean go stir crazy now. Sean you should have seen my bed on my tundra with that plastic bedliner before it went to bedrug. all I can say is alot of sanding and alot of primer/epoxy down to seal it.
    NewImprovedRon likes this.
  10. May 18, 2015 at 7:55 PM
    csuviper
    Broomfield, CO
    It's because I know how to use the bed for what it's meant for rather than just looking at it :)
  11. May 18, 2015 at 8:05 PM
    :spy: Brian knows my OCD has limits...haha I had him help me find a small squeak the other week....ended up finding his instead lol.
    Squirrel2021 likes this.
  12. May 18, 2015 at 8:11 PM
    csuviper
    Broomfield, CO
    Yep. Stupid hood latch squeak
  13. May 20, 2015 at 11:08 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    doing this soon.
  14. May 27, 2015 at 12:45 PM
    csuviper
    Broomfield, CO
    Saw you completed your install. Post up your pic up here as an example.
  15. May 27, 2015 at 12:51 PM
    I forgot about your mod. I went thru it once a few months back before I officially signed on. I need to go back and re-view your mods again.
  16. May 27, 2015 at 3:43 PM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
  17. May 28, 2015 at 6:29 PM
    How much should I expect to fork over to the dealer for a pack of D rings?
    Guzcarr likes this.
  18. May 28, 2015 at 6:47 PM
  19. May 28, 2015 at 6:52 PM
    Checked the site. Should be good to go. Getting major hail now. Hope truck doesn't get thrashed. Major hail.
  20. May 28, 2015 at 6:55 PM
    Poured here on the way back from the gym for about 5 mins...not raining now...last few days (during the day) have been beautiful. I've been driving around with some windows down at 730AM, and in the evening.
  21. May 28, 2015 at 7:06 PM
    Whew!! No apparent dings. Shooter marble size. Truck was parked under a big tree. Now covered with a bazzilion leaves.
  22. May 29, 2015 at 8:01 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    got off an army surplus site thats listed in the diy thread its $6 or something
  23. May 29, 2015 at 8:13 AM
    csuviper
    Broomfield, CO
    Is either $20 for two of the OEM Toyota ones or $6.50 for five of the ones i used from the Army Surplus site.
    Black Wolf likes this.
  24. May 29, 2015 at 4:57 PM
    I'll go for the $ 6.50 for five. That was easy.
  25. Jul 26, 2015 at 9:14 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Great idea for the tiedowns mod!!
    swtrader and Black Wolf like this.
  26. Jul 27, 2015 at 6:13 AM
    Ditto on that. Need to do this ASAP. I keep forgetting about this mod.
  27. Nov 5, 2015 at 6:58 AM
    Oper8r
    Oper8r New Member
    Stuttgart
    Sold my 2016 TRD PRO - Currently in BMW 535d Wagon
    So, the bed of my truck came with what seems like a good quality spray in bed liner and don't feel it is a good idea to attempt to remove any of the bolts. Has anyone used these cargo control rail systems?
    I'm just wondering if there might be issues with installing them in the ruts of the bed, i.e. do they sit up too high? Do I have to pre-drill? Do they handle enough weight to be worth the install?
    dcsleeper408 likes this.
  28. Nov 5, 2015 at 11:09 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    ToyoD and splitfuse like this.
  29. Nov 5, 2015 at 5:29 PM
    Tacogrande
    Jeremy
    HA! So a Dodge dealer is good for something after all. LOL I think i will order 4.
    swtrader likes this.
  30. Mar 17, 2017 at 7:40 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    I know this is an old thread but I have a couple questions...
    First, I did this in my Tacoma and had a HELL of a time getting one of the bed bolts out. Heat, blaster, etc took me about 2 hours. I don't want to go thru that again.
    In addition, the bed bolts are too close to the center of the bed for me - I want the tie downs closer to bed walls. So, what I'm looking to do is install tie downs in the bed NOT using the bed bolts. Has anyone went this route? I thought about just drill a hole thru the bed, spray some paint to prohibit rust, then bolt/lock nut the tie down on? Seems easy enough which is what is causing me to think I'm missing something.
    Getting a spray in liner soon so I want to make sure I at least drill the holes prior to the liner. I'm told drilling through the spray in liner will void warranty.
