DIY Bed Liner
Discussion in 'General Tundra Discussion' started by Rustyscrew, Jan 29, 2020.
  1. Jan 29, 2020 at 11:05 PM
    Rustyscrew
    Rustyscrew [OP] New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I’m looking to do my own spray in bed liner. Anybody have any experience with these and have suggestions or tips?
  2. Jan 30, 2020 at 12:14 AM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    I do. I would highly recommend monstaliner. It worked well and looked good. I didnt use it for berliner but I sprayed my entire yukon exterior with it and it held up great. You can get different colors too.20130706_203329.jpg xl_20130115_211909.jpg
  3. Jan 30, 2020 at 2:55 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
  4. Feb 1, 2020 at 4:30 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    I used Monstaliner on the interior of my Jeep TJ. I used the rollers they supply instead of spray. Super easy but prep is the key.
  5. Feb 1, 2020 at 5:09 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    I was looking some at the Raptor Liner. It comes with the sprayer. Seems to have some good reviews, but just seeing what others have used.
  6. Feb 1, 2020 at 10:55 AM
    Wahayes
    Will
    2017 tundra limited
    Prep is definitely key. I prepped the same way you would to paint a car. I wet sanded the whole truck and went through the full progression of grits. Also wiped everything down with tack cloth and sprayed in a makeshift paint booth of PVC pipe and painter's plastic
    BravoDeltaRomeo likes this.
