DIY: ABS Sensor Guard Install
Discussion in 'General Tundra Discussion' started by csuviper, Mar 8, 2017.
  1. Mar 8, 2017 at 7:36 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Below is the install as completed on my 2012 5.7L Rock Warrior Crew Max. Should be the exact same process for all 2007+ Tundras.
    The ABS Sensor Guards are sold by SDHQ. http://store.sdhqoffroad.com/2007tundraabsvacguards.aspx
    Link to SDHQ Install Instructions
    The reason I am installing is because the ABS sensors are unprotected, easy to break and expensive. @Sean266 paid ~$200 to replace one already. The guards are bolt on and will protect the sensors from rocks.
    The kit includes:
    • (4) ABS Guards (2 driver and 2 passenger)
    • (4) M6 - 1.0 x 45 bolts
    • (4) M6 Flat Washers
    Tools needed to complete the job:
    • 10mm socket / wrench
    • 5mm allen wrench
    Here are the guards in the package:
    Here is everything needed for this install:
    Start by turning the wheel out so you have room to work.
    For the front guards, remove the factory 5mm allen bolt holding the sensor. Install the guard on the appropriate side using the provided hardware and adjust so the bottom plate is parallel to the ground and tighten. Use some PB Blaster if they don't come off easy right away.
    For the rear guards, remove the 10mm nut and stud. One of two things will occur here. Either the nut will come off and leave the stud in place or the nut and stud will come out together. The latter occurred for me. If the nut only comes off then pull the sensor out and remove the factory stud using pliers. Install the guard on the appropriate side using the provided hardware and adjust so the bottom plate is parallel to the ground and tighten. Use some PB Blaster if they don't come off easy right away.
    When completed you will have 2 bolts, 2 studs and 2 nuts remaining that can be recycled or saved for future opportunities.
  2. Mar 8, 2017 at 8:21 AM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    how often do these things break?
  3. Mar 8, 2017 at 9:45 AM
    TheBeast The Beach
    very detailed.
    Piece of mind. Beer. Priceless.
    CaptSpaulding likes this.
  4. Mar 8, 2017 at 10:20 AM
    csuviper
    Broomfield, CO
    Have not broke one myself but now I don't have to worry. @Sean266 broke one on his 2014 so now he added these guards as well.
  5. Mar 8, 2017 at 10:30 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks Brian for this write-up. Something I didn't even know I needed to mod, gee thanks!! Another project, as if I don't have enough of those for this truck. (jk) All joking aside great instruction manual!
    WillTunBlack20 and T-Rex266 like this.
  6. Mar 13, 2017 at 3:39 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Awesome write up!
    WBW, geno0506 and T-Rex266 like this.
  7. Mar 13, 2017 at 5:54 PM
    PermaFrostTRD
    Northern NY
    Great write up!
    T-Rex266 likes this.
  8. Jan 22, 2018 at 8:56 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    These are on my list!
    Thanks for doing a DIY on them, it will come it handy.
    WillTunBlack20 likes this.
  9. Jan 22, 2018 at 4:29 PM
    geno0506
    geno0506 New Member
    Michael
    Thanks for the great write up!
  10. Jun 11, 2022 at 5:26 AM
    Mizterusa
    Mizterusa New Member
    2007 Toyota Tundra crewmax SR5 TRD
    S&B intake, MBRP dual exhaust and a killa sound system
    Is there really a need for these??? I got 160k on my 06 CM and have never knocked one off or have ever heard of anyone losing one.
    Jeff_1974 likes this.
  11. Jun 12, 2022 at 5:45 AM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    Interesting. I would guess that a lot of off roading might be a situation that these would help. But if you have a pavement queen, I am thinking they might not be so necessary. I would actually worry about them creating a collection point for dirt/debris, which could build up and cause corrosion to the plug end of the wire harness. Time will tell.
  12. Jun 12, 2022 at 6:17 AM
    AJTundy
    AJTundy New Member
    2020 Tundra Crewmax SR5
    Leer 100XR truck cap, 5100's on the middle setting. Ikon Add A leaf, Cooper Discover ATX3 275/70/18, Genuine Cooling Systems transmission cooler, chrome delete.
    When I had my leaf pack installed, the shop that installed them accidently broke one of my sensors taking my old leaf out. They covered everything and took care of me but those sensors are fragile, and they are about $400 each.
  13. Jun 12, 2022 at 2:16 PM
    Mizterusa
  14. Jun 12, 2022 at 2:36 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    You don't have to play off-road to hit something in the highway.
    bulldog93 likes this.
  15. Jun 12, 2022 at 3:05 PM
    Mizterusa
    They can take a beating.... If you actually look at one there is a protective cover. If ur really worried about em then there's a few other "delicate" items you might also want to baby!!! $250 for a $50 set of sensors on Amazon.... Lol
