Tundra Mods
Discussion in '2.5 Gen Builds (2014-2021)' started by Jego, Jan 28, 2021.
  1. Jan 28, 2021 at 7:00 PM
    Jego
    Jego [OP] New Member
    Orlando
    PR
    2018 Tundra 1794
    Hello,
    Here are some DIY videos that would like to share and get some feedback and ideas too :).
    I am currently modifying the stock side mirrors to add marker lights. If it doesn't look like I expected then I plan to replace it by tow mirrors that already has marker lights on it. :)
    This is how it looks so far but I am going to replace the lights by clear lights to see how it looks.
    I will upload more details soon!
    Here are some of the completed mods...
    Hood Scoop
    https://youtu.be/WO1P3yB1B2A
    ReadyLIft Leveling Kit
    https://youtu.be/EokSDg-D9BU
    Spidertrax 1.25in wheel spacers
    https://youtu.be/7kqap3EC7Fc
    Interior Led lights
    https://youtu.be/xB3Re-nrDBo
    Exterior Led lights
    https://youtu.be/18Vh-pIxVbs
  2. Jan 29, 2021 at 4:52 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Clear lights arrived!
  3. Jan 31, 2021 at 4:38 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
  4. Jun 2, 2021 at 5:44 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
  5. Jun 4, 2021 at 9:26 AM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    okcowboy likes this.
  6. Jun 4, 2021 at 9:46 AM
    Taco-Spike
    Two Trucks
    Nice Job
    Really dig the Hood scoop mod
    Edit: did you get your scooped painted or did you have it painted?
    Jego[OP] likes this.
  7. Jun 4, 2021 at 10:38 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Great write up! Just added more to my todo list.
  8. Jun 4, 2021 at 2:03 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    I went to a local shop. It came unpainted. I got couple of quotes from 100 to 150.
    Taco-Spike[QUOTED] likes this.
  9. Jun 4, 2021 at 2:15 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    It all looks great IMO.
  10. Jun 4, 2021 at 3:01 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Thanks!
  11. Jul 25, 2021 at 8:40 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Shadowfax1 likes this.
  12. Jul 25, 2021 at 10:14 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    How long have you had the radio in? Any issues with it so far? Do you still have xm?
    Ernie68 likes this.
  13. Jul 25, 2021 at 11:35 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
  14. Jul 26, 2021 at 2:12 PM
    SuperWhitePro19
    SuperWhitePro19 New Member
    2019 Trd Pro Tundra CrewMax
    Sitting on 275/65r18 duratracs, truxedo sport soft roll topper, home install bed lights
    These look amazing! do they work as turn signal as well?
  15. Jul 26, 2021 at 8:02 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    I went to few local shops to get it painted. I got different quotes from 100 to 150.
  16. Jul 26, 2021 at 8:03 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Thanks I am glad you like it. :yes:
  17. Jul 26, 2021 at 8:14 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    These aren't but I am thinking that you can easily make a mod to it and make it work as turn signal too. Just need a relay for each side. For example you can connect the marker light circuit to the N.C. pin of a relay and the coil to the signal circuit. Then when the turn signal is on it will change the state of the relay to the N.O. pin making the marker light to blink each time the turn signal is on. I will make a test to see if it works and let you know.
  18. Jul 26, 2021 at 9:13 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Around one month. This unit came without XM. It started recently to pop-out from the top section. The geometry of the frame isn't aligned at all with the top section in the dash. This unit came with brakets but I didn't see a place in the unit to attach these brakets. I will double check that because this brakets can solved the pop-out issue.
    Here you can see how it is misaligned in the top section.
    I can go with it as it is, if it doesn't pop-out from the top anymore after brakets install. I will check this and will include all details in my second video but will definitely let you know the details as soon as I found a workaround for this.
    Side view:
    Brakets:
    Other than that is working as expected.
  19. Jul 28, 2021 at 11:04 AM
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    There is a spot on the top middle that you need to notch out in order for it to sit correctly. Skip to 4:55 for reference. This might help with it sitting better flush
    https://www.youtube.com/watch?v=jXugTcGjC00
    bulldog93 likes this.
  20. Sep 18, 2021 at 6:35 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    The installation and initial setup for the Tesla Style radio.
    https://www.youtube.com/watch?v=REIQXi2dxqw
    Pending for my the 3rd and last video of this topic:
    • Fix Frame pop-out issue
    • Fix break light issue
    • Rear Speakers Conf.
    • Customizations
    • Audio QA
    • Review
    SCIF likes this.
  21. Jan 12, 2022 at 2:13 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    SCIF, bulldog93 and TucsonTundra1794 like this.
  22. Jan 16, 2022 at 7:15 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Almost set for the next mod!
    TucsonTundra1794 likes this.
  23. Mar 6, 2022 at 7:19 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
  24. Apr 29, 2022 at 3:09 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
  25. May 17, 2022 at 11:31 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
  26. May 25, 2022 at 2:44 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
  27. May 25, 2022 at 3:51 PM
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    ALV the balls you must have to drill into your hood.
  28. Aug 11, 2022 at 10:25 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    I received yesterday a new semi bumper winch. Other mod to my queue. Still have few of them pending. I can't wait to install it. Hopefully at some point during the next weeks. The bumper looks great out of the box, I hope the same after install it.
    mav7021234 likes this.
  29. Sep 3, 2022 at 6:08 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
  30. Sep 6, 2022 at 9:39 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
